Old 27th January 2006, 05:42   #1
jkarp
jkarp's Avatar
Garage: 2000 Silverstone M5 and 1998 Silver M3
is this my clutch slipping?
From a stop, if I'm making a 90 degree right hand turn, it used to be that I could make the rear end slide out easily by giving the car a lot of gas and cranking the wheel.
Now, the RPM's just raise and the back end doesn't break loose. I'm assuming this is my clutch slipping, right? Does this mean that it will fail me completly soon or might I have some time left?
thanks... josh
jkarp is offline
Old 27th January 2006, 06:51   #2
TiSiBeast
TiSiBeast's Avatar
Garage: 2000 E39 M5 TiSi, 2002 Jeep GC Gray
Sounds like a clutch slip to me. How many miles on the current clutch and do you drive it hard alot?
Current Toys: 2000 M5 with lots of goodies, 1997 993 Targa mostly stock, 2002 Jeep GC all set for offroad, 2004 Acura TL bone stock
TiSiBeast is offline
Old 27th January 2006, 06:59   #3
EM5PWR
EM5PWR's Avatar
Garage: 02 M5
you can smell it !!! LOL
EM5PWR is offline
Old 27th January 2006, 07:24   #4
jkarp
jkarp's Avatar
Thanks for the replies guys. I've had the car for 18,000 miles. I'm not sure when (if ever) the stock clutch was replaced. I'm at 80k total, so I'm assuming it's been changed at some point knowing the M5 clutch. How long might I have before it's completely useless? Anyway to tell?
thanks again... josh
jkarp is offline
Old 27th January 2006, 07:39   #5
a_ok2me
a_ok2me's Avatar
Garage: M5
A test I always use is to put it in 4th and floor it. If the rpm jumps, then the clutch is getting bad. If it really jumps, say over 2500 rpm from where you are, then it's getting close. What ever happened to the nav and blinkers?
a_ok2me is offline
Old 27th January 2006, 07:52   #6
jkarp
jkarp's Avatar
a_ok,
Thanks for the tip. Do you do the "4th gear test" from a stop or while driving? If driving, at what speed?
As far as the blinker problem, it ended up being my trunk mounted radio. I think it got wet and shorted out, and therefore affected my instrument cluster. Since I needed to get a new radio anyway, I am upgrading to MKIV nav computer and Sirius.
...josh
jkarp is offline
Old 27th January 2006, 08:23   #7
a_ok2me
a_ok2me's Avatar
Garage: M5
a_ok,
...josh
I usually do it while moving when the rpm is low, say <2000 rpm, in a high gear. Then, floor it. If the clutch is still good, then the car will chug along feeling like it needs to be in a lower gear while the rpm needle slowly moves up. If the clutch is getting bad, then the needle will jump and then fall back down. You can't miss it. The speed and gear doesn't really matter as long as it's higher than 4th. Try it at 4th gear at 2000 rpm. It's too hard to test it in a low gear because low gears are naturally jumpy.
a_ok2me is offline
Old 27th January 2006, 08:44   #8
HSR
Garage: 00 BLK M5
I had that happen on mine. When they put the new clutch in it had life on it but the pressure plate was toasted.
HSR is offline
New Sachs Power Clutch tripleD E39 M5 and E52 Z8 Discussion 13 12th April 2005 22:04
Stage 3 (6-puck ceramic) clutch 1st impressions 1badm5 E39 M5 and E52 Z8 Discussion 11 2nd November 2004 22:00
Clutch Slipping plisken E34 M5 Discussion 5 31st August 2004 01:28
Yet another clutch theory/technique thread greg E39 M5 and E52 Z8 Discussion 8 18th March 2004 18:55
slipping clutch fais2000 E39 M5 and E52 Z8 Discussion 9 28th September 2000 04:34
Page generated in 0.15535 seconds with 11 queries
