Old 24th January 2006, 21:01   #1
KBK
KBK's Avatar
Garage: E39/Anthracite Metallic
help identifying this lightened flywheel
I bought this off ebay a while back for 200 buckaroos, I've had it for a while and I'd like out figure out who made it. I've looked around at lightened flywheels, and haven't found anything that looks like it.
I bought it before I figured out that the car performs fine already and I've largely decided to leave the car alone. I'm going to put itback on ebay but I'd like to know a bit more about it.
It has a tiny 'winged' tire stamped into it, and that's about it.
I'm using a linux based machine here at work so I'll have fun figuring out how to get a photo uploaded.
ps; I think the guy who sold it to me is a member here on the forum! he went to a dinan upgrade and the original lightened flywheel (this one) is not capable of handling the greater stress, so he ditched it after 4000 miles, he says. could it be a Dinan unit?
KBK is offline
Old 25th January 2006, 20:03   #2
KBK
KBK's Avatar
bump. TTT. etc.
Turner motorsports maybe?
Bueller? Bueller?
There must be someon on this board who recognizes this flywheel.
The starter 'ring' gear is fully separate and brings the rotating mass up to 14lbs. Aluminum part is 9 lbs.
The majority of the rotating mass is at the center area, which keeps the inertia down. Both good and bad.
KBK is offline
Old 26th January 2006, 23:54   #3
burtsplash
Garage: 1999 black M5
This ring gear, I'm sure, is coming off an automatic tranny car.
Now for the aluminium part, could it be home made or modified by your e-bay seller? On my opinion, it could be...
burtsplash is offline
Old 27th January 2006, 03:13   #4
KBK
KBK's Avatar
It's a pro built item, for sure. I've looked at everyone's different flywheels, and haven't found a perfect match yet. The 'winged tire' stamped into it is the big giveaway as to it's origins..but I can't seem to find out who uses the logo. I've not found any picures of a Dinan flywheel yet, so it's till on the list. maybe somene can remove my ignorance of that.
The seller did get back to me as of yesterday. He is a forum member and even tried to have a few of the forum members help him figure it out at an earlier date. So far, it's all guesses.
KBK is offline
Old 27th January 2006, 03:18   #5
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i have my oe flywheel at home, and could post a pic this weekend if it's any help. fwiw, dinan cuts down an oe unit, any part numbers?
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 27th January 2006, 03:41   #6
KBK
KBK's Avatar
No part numbers anywhere on this flywheel. Just the tiny winged tire logo. Is the original aluminum? I thought it'd be steel.
KBK is offline
Old 18th May 2006, 00:52   #7
Stage2Pat
Stage2Pat's Avatar
Garage: M3 Estoril Blue
I have the same flywheel.It was sold to me as a Dinan. It came with a LUK clutch.
Pat Sweeney
00 M5 Jet/Imola
01 M5 LMB/LMB
70 GS Stage 2 10.75@125
95 525 5sp
06 Trailblazer SS
Stage2Pat is offline
Old 18th May 2006, 01:11   #8
howler
howler's Avatar
Garage: 2003 Sterling Grey, M5
Sales Feedback: (4)
It is definitely not a Dinan product.
I just installed the Dinan flywheel on my M5 last week.
Bob
FORMER CARE GIVER OF:
'03 M5 Sterling Grey/Black Sport/Aluminum Trim
Dinan:
Headers
Stage I lightened Duel Mass flywheel
High Performance Clutch
Cold Ir Intake System
High Flow Throttle bodies
Tuned Velocity stacks
High-flow air mass meters
3.45 differential
Stage V software,
Stage III suspension
Stage II Dinan/Brembo Brake Pkg.
Strut Tower Brace
Shock tower brace______________________________
OZ Superleggera III wheels w / Goodyear F1 GS-D3
Carbon Fiber rear diffuser
Tubi Cat-back exhaust
UUC EVO 3 SSK/DSSR
Euro Clear corner Xenons
V-1 w / Stealth One
Lidatek LE-30
AC Schnitzer pedals
OE Fire Extingusiher
OE First Aid Kit
howler is offline
Old 18th May 2006, 01:22   #9
Stage2Pat
Stage2Pat's Avatar
Did you install an aluminum flywheel or a steel one?
Pat Sweeney
00 M5 Jet/Imola
01 M5 LMB/LMB
95 525 5sp
06 Trailblazer SS
Old 18th May 2006, 01:28   #10
Laidback
Garage: Camaro lol:)
Sales Feedback: (25)
did you ever ask the guy what brand it is?
"Illegitimus non carborundum"
Laidback is offline
Dual Mass Flywheel .vs. Lightweight Flywheel--What Performance Differences Do You See Anita E39 M5 and E52 Z8 Discussion 33 15th February 2005 17:06
Owners of Dinan S2 Package with Stage # 1 flywheel, I have a question for you....... FAST 5 E39 M5 and E52 Z8 Discussion 4 9th November 2004 17:27
Dinan Flywheel help please. Stevus E39 M5 and E52 Z8 Discussion 14 29th November 2003 06:26
TECH: Roundel got me in a tizzy--VAC's lightweight flywheel!! Teutonaddict E39 M5 and E52 Z8 Discussion 7 22nd September 2003 17:46
Upgraded flywheel? gsfent E39 M5 and E52 Z8 Discussion 1 7th February 2003 00:31
Page generated in 0.14157 seconds with 12 queries
