Old 24th January 2006, 19:57   #1
rsimhamb
Garage: 2001 BMW M5
SES Light Intermittent
Hi Folks,
I have seen the SES light come on intermittently since Sunday this week. The car coughed/sputtered only once since that time and has been driving normally since.
I had the car scanned for faults by the folks at the Driving Machine in Cupertino. Here is a list of what they came up with:
ENGINE FAULTS
8 inlet camshaft sensor, bank 2, signal
134 instrument cluster, CAN time-out
113 Inlet VANOS, bank 2, function
184 Inlet VANOS, bank 1, function
179 Catalytic converter, conversion, bank 2
WHAT DO I DO TO ADDRESS THE ABOVE FAULTS? IS A TRIP TO THE DEALERSHIP THE ANSWER?
LIGHT FAULTS
Wire Dimmer to Potentiometer
Turn signal flasher, front right, faulty
Turn signal flasher, front left, faulty
Right fog lamp faulty
Left fog lamp faulty
Rear left fog light faulty
Rear right fog light faulty
Right reversing light faulty
ALL OF THE ABOVE ARE WORKING WITHOUT FAULT AND AS EXPECTED
Fyi - the SES light is currently off.
Thanks,
Ravi
01 Royal Red, Caramel Int, No mods (yet)
rsimhamb is offline
Old 24th January 2006, 21:07   #2
ard
ard's Avatar
I'm not going to be much help, but I will caution you: sometimes a bad camshaft position sensor can cause VANOS errors. Also, you can get 'bad cat' errors due to other camshaft/fue/air discrepancies... It looks like your codes are generic OBD codes, not BMW specific. If indeed the CPS is bad, replace that and reset. It certainly is the cheapest...if you then get vanos probelms...well..sorry.
I'd say a very good indy, or dealer, is the way to go- make sure you get the print outs of any disagnostics they run, and demand that they explain what and why they are recommending what they propose.
(I had a bad CPS with vanos errors- the vanos errors were due to faulty signals from the cps. SES would come on and off, when it was on car drove like carp.)
The other errors may be a bad ground wire or sensor somewhere. Having a schematic and someone well versed in the wiring might help pinpoint it...
ard is offline
Old 24th January 2006, 21:49   #3
Mth_degree
Garage: '98 540 (for now)
Yep, sounds like it could be the cam position sensor. Either replace it and see what happens, or clear all the codes and swap the inlet cam sensors over and see if it throws a code on the opposite bank.
As for the lights - it sounds like a fault with the LCM - probably just a momentary glitch. Im not sure what could have caused the CAN timeout fault either - maybe a temporary fault in a certain module giving an invalid bus signal?
Either way I would suggest you investigate the cam position sensor, then reset all the codes and see which ones come back.
Mth_degree is offline
Old 24th January 2006, 21:52   #4
rsimhamb
Garage: 2001 BMW M5
Thanks Guys!
Is the CAM sensor something I can replace myself, or will require a qualified technician?
Ravi
rsimhamb is offline
Old 24th January 2006, 22:01   #5
Mth_degree
Fairly easy diy. Lots of info here :
TECH: Replacing intake Camshaft Position Sensor...
BTW that thread refers to the bank 1 sensor, but your fault seems to be on bank 2 (opposite side of engine, but with similar procedure). There are 2 similar sensors on each head - the one highest up and nearest the centre of the engine is the intake one which you are interested in.
Old 24th January 2006, 22:16   #6
rsimhamb
Garage: 2001 BMW M5
Thanks - I will lookm into replacing the sensor asap.
Ravi
rsimhamb is offline
Old 24th January 2006, 22:29   #7
sick nick
Garage: 2002 bmw m5
cam sensor
ive just gone through the same deal its the exhaust cam sensor 5-8 driver side. easy to replace need a 5mm allen wrench, do it from under the car.if u where smart u would just replace both sides and get it over with. 1 goes the other is not far behind. u fix 1 problem a lot other codes clear up.
sick nick is offline
Old 3rd February 2006, 04:04   #8
rsimhamb
Garage: 2001 BMW M5
OK Folks - took the beast to the dealership today. The diagnosis is that the catalytic converter needs to be replaced. I'll have the car back on monday as the delaer has to wait for the part. The repair is entirely covered by CPO. Thank heavens.
Cheers,
Ravi
rsimhamb is offline
Old 3rd February 2006, 04:19   #9
ard
ard's Avatar
Cheers,
Ravi
I have significant doubts.... but at least you get free new cats.
A
ard is offline
Old 3rd February 2006, 04:20   #10
Anzir
Anzir's Avatar
Garage: Silverstone 2000 M5
Cheers,
Ravi
Something tells me your camshaft position sensors should also be switched out as well.. but it's never a bad thing to get free cats!!
Anzir is offline
modded exhaust today, then ses light 5 mins later M5 foe E39 M5 and E52 Z8 Discussion 10 18th August 2005 19:50
SES Light - Engine Misfire! x703jko E39 M5 and E52 Z8 Discussion 24 8th March 2005 20:49
Can an un-reset Service Indicator cause intermittent SES light? greg E39 M5 and E52 Z8 Discussion 15 8th May 2004 06:01
Intermittent SES light on with reduced power - little hope of fixing it :( ColinM E39 M5 and E52 Z8 Discussion 16 5th September 2003 20:49
TECH: SES light on... BlueBomber E39 M5 and E52 Z8 Discussion 5 9th May 2002 18:21
Page generated in 0.16309 seconds with 11 queries
