Old 27th January 2006, 20:49   #21
baldy_bonce
baldy_bonce's Avatar
Garage: BMW M5/ Le Mans Blue
Hi guys, long time no speak... this warranty shake up is not good.
Mine runs out in June 07 so a long time to wait
baldy_bonce is offline
Old 27th January 2006, 21:04   #22
alantd
alantd's Avatar
Garage: 09/02 E39 M5; Carbon Black; Stock
Break caliper seized, wrecking a set of front disks and pads.
£800 from Munich Legends to replace the lot - including the caliper.
Warranty Company (Auto Protect) say that it "isn't a mechanical failure as seizure is something that happens over time" so they won't cover it!
They're also dragging their heels over a replacement instrument binnacle with faulty pixels.
Rubbish I'd say and I'm signed up to them for 3 years!
Edit: Car only has 20K miles!
02 Carbon Black Stock
05 Land Rover Defender
alantd is offline
Old 27th January 2006, 22:22   #23
Rampage
Rampage's Avatar
Garage: MY 00 E39 M5 SilverStone
Expires: June 12th (ish) '06
Def interested....
I'd be looking for complete drive train, aircon, electrics (inc mirrors, dash, nav etc) and mechanical items such as the sunroof. Can't think of anything else that would scare me to replace that I haven't already...
Cheers
-Steve
MY04 Audi S4 Cabriolet
MY00 E39 ///M5 Silverstone, Silverstone Now SOLD
...Seriously empty wallet...
Buckinghamshire, England
Rampage is offline
Old 29th January 2006, 12:03   #24
sumo69
Garage: E39 M5 Silverstone
I can't figure how to update list of expiry dates!!
Anyhow, mine is due 11 April 2006.
Re wish list - comprehensive engine cover (inc VANOS and MAFS), drivetrain, catalyst failure, all electrics(incl seat motors),dashboard/SATNAV/TV ,Aircon and Xenon headlights!
Also, what will their position be re modified vehicles?
What max single and annual claim limit will there be??
My 2p worth!
Sumo
sumo69 is offline
Old 29th January 2006, 12:27   #25
cableguy
cableguy's Avatar
Garage: 2003 996 GT2
Sumo
Cut & Paste is the easiest option.
Welsh :
cable guy : 21st July 2006
286 bhp :
sumo 69 : 11th April 2006
Tin : 31st March 2006
Rampage : 12th June 2006
Manx M5 :
Evil Vanos :
gmajor:
maxm5: Nov'06
david s ? :
C.
2003 996 GT2 - Brutal...
cableguy is offline
Old 29th January 2006, 16:33   #26
welsh_willo
welsh_willo's Avatar
Garage: Avus Blue e39 m5
Send a message via MSN to welsh_willo Send a message via Skype™ to welsh_willo
the uk warranty proposal
Welsh : end of April 2006
286 bhp :
Manx M5 :
Evil Vanos : asap : no bmw warranty
gmajor:
maxm5: Nov'06
david s ? :
Tin your up first it seems : we need 10 cars to get a better deal
please see list options this is £827 for 12 months 80k 6 year old car
can you all vote for core and extended req. put stars as value rating 5 is max
Component Cover -Component Cover - The following components are covered against Mechanical Breakdown (as defined elsewhere in this document) of those items listed below. Please note that parts not listed are specifically excluded.
ENGINE
All components contained within the cylinder block and head including pistons, rings, crankshaft, big end bearings, manifolds, rocker assembly, timing chains, timing gears, distributor drive.
TURBO UNIT
All components including inlet and exhaust turbine shafts, bearings, bushes, wastegate devices. Turbo cover ceases at 7 years or 80,000 miles (whichever comes sooner}
GEARBOX
All components contained within either manual or automatic transmissions including gears, bearings, clutches.
CLUTCH
All components including clutch plate, clutch cover, thrust bearing and or release bearing. Limited to one clutch repair during the warranty duration.
DIFFERENTIAL
All components including gears, pinions, bearings, shafts
DRIVE SHAFTS
All components including propshaft, drive shafts, C.V. joints, couplings.
BRAKES
All components including servo units, cylinders, valves.
STEERING
All components on steering systems including power steering units, rams, pumps, reservoirs, steering box.
SUSPENSION
All components including control arms, bushings, ball joints, pins.
BEARINGS
All components including wheel bearings, seals, hubs, flanges, where mechanical breakdown has occurred causing sudden stoppage of their function.
COOLING SYSTEM
All components including radiator (excluding external damage), matrix, water pump, head gasket, thermostat.
VENTILATION
All components including heater assembly vents, tubes, controls. E.C.U. l All components including solid state control units, triggering units, distributor, coil.
ELECTRICS
All components including motors, solenoids, relays, alternator, starter motor, switches, computers.
FUEL SYSTEM
All components including fuel pump, carburettor, sender units, gauges, air flow meters, accumulator fuel distributor, regulators.
AIR CONDITIONING
All components including compressors, pumps, reservoirs.
LOCKS
All components including regulators, handles, locks, catches (excluding accidental damage).
SEALS
All major oil seals and gaskets.
CASINGS
Casings are covered if they have been damaged by any of the listed parts.
SATELLITE NAVIGATION SYSTEM
EXCLUSIONS
Cylinder head cracks, damage caused by frost, overheating or as a result of a lack of anti-freeze, all normal maintenance items such as but not limited to plugs, points, filters, breather valves, valve cover, gaskets, plus parts that require periodic replacement such as but not limited to high tension leads, rotor arms bulbs, ancillary belts, hoses, exhausts, tyres, fluids, batteries, in-car entertainment systems, alarms, immobilisers, normal wear items, non-manufacturer approved parts.
welsh_willo is offline
Old 29th January 2006, 17:42   #27
stevie53
stevie53's Avatar
Garage: 2000 E39 M5 Imola Red
welsh willo
I've just came across this thread and would be very interested about joining the group buy for the warranty, hope you don't mind but I've added my name name on at the end.
286 bhp :
Manx M5 :
gmajor:
maxm5: Nov'06
david s ? :
stevie53 : 25 Sept 2006
stevie
06/94 M5 6spd (Artic Silver) Gone to car park in the sky
09/00 M5 (Imola Red) again
stevie53 is offline
Old 29th January 2006, 18:00   #28
Craig T
Garage: E39 M5 in Carbon Black with Caramel Interior
Hi
Just seen this thread and will also be interested.
Hope you don't mind, added myself to the list:
286 bhp :
Manx M5 :
gmajor:
maxm5: Nov'06
david s ? :
craig t: 23 Sept 2006
thanks.
Craig T is offline
Old 29th January 2006, 18:06   #29
Rampage
Rampage's Avatar
Does this mean the price is flexible based on mileage? Mine is only @ 53.5k (ish) and do less than 5k a year...
Interesting that under "SEALS" they state "All major seals & gaskets" and then in "EXCLUSIONS" gaskets are listed as being excluded? So would they include the head gasket or would it be down to how they feel on the day?
Is there an excess to pay?, a limit on cost per claim?, number of claims per year? Do they have agents they expect you to use for repairs rather than the stealer? What is there policy on mods?
And this statement concerns me "Please note that parts not listed are specifically excluded."
I'd want it as comprehensive as possible so 5 * for all the items excluding:
TURBO UNIT
Obviously not an M5 specific warranty then... unless of course I have one fitted without knowing it
I'd prefer to see:
Covered:
Engine, drive train, electrics, aircon etc
Exclusions:
Minor items inc, service and general wear and teare items, tyres, petrol, blah blah blah
Don't get me wrong I'm not trying to be a party pooper, but before I commit I would want to read all the small print first. And to be honest you are only talking £200 less than BMW...
-Steve
Rampage is offline
Old 29th January 2006, 19:09   #30
welsh_willo
steve re cost# not if your mileage is over 60k##
big problem is for those whose cars ar over the 60k limit
welsh
Adding MODS to your car and warranty being possibly affected................ FAST 5 E39 M5 and E52 Z8 Discussion 1 6th November 2003 22:44
"Aftermarket vs. Factory Warranty" NJ M5 E39 M5 and E52 Z8 Discussion 2 12th April 2003 21:47
Important info to anyone wanting to aviod gearbox problems DavidS E39 M5 and E52 Z8 Discussion 14 8th April 2003 04:35
Need info!! - Has anyone had a cupholder replaced under warranty? M5xtc E39 M5 and E52 Z8 Discussion 11 23rd July 2002 18:49
UK Extended warranty on European Import Mac E39 M5 and E52 Z8 Discussion 4 17th April 2001 20:10
Page generated in 0.30323 seconds with 12 queries
