Error code A2: "A2-Crankshaft/Camshaft..." - BMW M5 Forum and M6 Forums
Old 21st January 2006, 06:01   #1
sick nick
Garage: 2002 bmw m5
got a problem NEED HELP.....
Alright guys, I’m coming up with a code that is (A2-Crankshaft/Camshaft position corrolelation cyl #5-8) What does this mean, which sensor is this and were is it located??? Car is really down on power. Feels like the timing is retarded. Slugish.Then all of a sudden it will just run good again. No body seems to be able to tell me what could possibly be wrong. Any body that could get back to me with any help or info would be greatly appreciated.
Thanks Again,
Tim
sick nick is offline   Reply With Quote
Old 21st January 2006, 07:32   #2
ard
Super Moderator
ard's Avatar
I had that failure, along with a few others:
Crankshaft/Camshaft Position Correlation, Cyl #5-8
Exhaust Camshaft VANOS position control, Cyl #1-4
Exhaust camshaft VANOS position control, Cyl #5-8
“Blatty” Exhaust note, poor acceleration (timing retarded?)
Confirmed CPS(Cam Position Sensor) failure - it would come and go. It did set the SES light on the dash.
I pulled the codes, to make sure I knew what was up, then had the dealer do it under warranty.
There are a few posts/threads on part costs and doing the swap yourself.
A
Old 21st January 2006, 09:15   #3
sick nick
Garage: 2002 bmw m5
need help
ard thx for the reply. i failed to say i replaced exhaust cam sensor on pass side head. im i right that cyd,s 5-8 are on pass side of engine?
Old 21st January 2006, 10:51   #4
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
I believe 5-8 are drivers side on LHD cars.
Old 21st January 2006, 13:22   #5
Jan Falk
Garage: M5 E39 Carbon Black
I've just canged a cam position sensor cyl.1-4 and it's on the passenger side on LHD cars.
Good luck, Jan
Jan Falk is offline   Reply With Quote
Old 21st January 2006, 17:31   #6
ard
Super Moderator
ard's Avatar
Hmmm. That would have been useful info in the original post....
Sounds like you have a spare CPS that is still good ...
Look at the bright side: it probably WOULD have failed...
A
Old 22nd January 2006, 08:42   #7
sick nick
Garage: 2002 bmw m5
problem fixed
thx guys for info,car runs great again.still got 1 problem.evaporative emissions purge valve.it was the cps sensor exhaust 5-8 drivers side. doh.now i got 1 spare sensor. lucky girlfriend works for bmw. parts are at wholesale.
thx Tim R
Vanos problem ilundber E39 M5 and E52 Z8 Discussion 15 3rd November 2005 00:30
Engine hesitation problem ArrestMeRed E39 M5 and E52 Z8 Discussion 10 9th May 2005 21:45
Sticky brake problem?? baldy_bonce E39 M5 and E52 Z8 Discussion 0 12th March 2005 18:08
Update on clutch/tranny problem... lsdvm E39 M5 and E52 Z8 Discussion 3 27th January 2005 05:05
"AUX" mode (lack-of) volume problem for I-PODs & DVD movies........ FAST 5 E39 M5 and E52 Z8 Discussion 8 16th September 2004 08:06
