my Passengerside fog light went out, so I went out and got a
replacement bulb. Now just have to replace it.
Yes I did search and read the owners manual.
But still kinda vague.
Ok..
According to the owners manual. The plastic Panel next to the
fog light housing need to be removed. But in another thread
that discusses the DIY bulb change didn't refer to that.
If you do have to remove the plastic panel next to the fog lamp
assembly. How do you remove it? Owners manual didn't say.
After inspecting the area. I don't see how the plastic panel can be removed.
is there a certain way?? Or do you just wedge a flat head screw driver and
pry it out?? <-- really would not like to do that.
Now the fog light assembly.. The black ring around the actual Lamp.
Does that have to removed. If so.. Does it just snap out??
and do I use the little hole on the side to pull it out?
Once I take off the black ring.. It exposes the screw behind the
black ring. Once I unscrew that.. Im assuming the light assembly
should come out. Then I can replace the bulb.
any insight /pictures/linked threads/advice would be greatly appreciated.
thanks in advance..
and Happy New years Eve eve.....
