Filling windshield washer fluid? - BMW M5 Forum and M6 Forums
Old 29th December 2005, 16:58   #1
3rd One
3rd One's Avatar
Garage: 2000 M5, 06 Range Rover Supercharged, 2008 Nissan Titan
windshield washer fluid???
So about a week ago I used my washer fluid for the first time since ownership (4 months now) and it left a nast greasy film on the window and then the "low washer fluid" warning came up. I poured an entire bottle into the reservoir and then tried to work the washers again.........nothing. I poured more in with the same result.
I then noticed another washer fluid reservoir and deiced to just pour water into since I was out of fluid. all of a sudden the washers were working again. Is there some sort of mixing system in this car for the fluids in to different spots. I am now out of water (after 2 days) in the waht I am calling the "extra" tank...............and I am beggining to think that my system is not drawing from the "real" reservoir at all.
can someone explain how this all works. I must have well over a gallon in the car that I can't seem to access.
Dwight
3rd One is offline   Reply With Quote
Old 29th December 2005, 17:22   #2
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
Re: windshield washer fluid???
Two tanks. One is the "intensive" spray tank, in theory used for heavy dirt. The other is the "regular" tank. Used for normal washing. Either will work. The main tank has a cap with a pictogram and is a long necked black tank. Strictly from memory, the intensive tank is clear and may have a red cap.
After looking at the two, you should be able to tell which is which.
And I believe pulling the stalk squirts regular fluid, pushing the end button squirts intensive fluid. It should all be in the Owners Manual (if you don't have one, it can be downloaded from the BMW site).
gsfent is online now   Reply With Quote
Old 29th December 2005, 17:26   #3
3rd One
3rd One's Avatar
excellent...thanks for the info. I felt I would get a clearer explanation here than bothering with the owners manual.....i was right.
I never bothered to "pull" the stalk towards me...I have always just used the button on the end.
learned something new.
Old 29th December 2005, 17:54   #4
TiSiBeast
TiSiBeast's Avatar
Garage: 2000 E39 M5 TiSi, 2002 Jeep GC Gray
Two different sprays - how cool is that!
Current Toys: 2000 M5 with lots of goodies, 1997 993 Targa mostly stock, 2002 Jeep GC all set for offroad, 2004 Acura TL bone stock
TiSiBeast is offline   Reply With Quote
Old 30th December 2005, 13:01   #5
alantd
alantd's Avatar
Garage: 09/02 E39 M5; Carbon Black; Stock
I think the general idea is to fill the sandard tank with water + cleaner/antifreeze.
The second tank is filled purely with antifreeze.
Pulling the stalk draws from the main tank (6 liters if you have the headlamp washing system). The end-of-stalk button draws from the smaller, secondary tank (1 L).
Here's the diagram from the manual for which is which
02 Carbon Black Stock
05 Land Rover Defender
alantd is offline   Reply With Quote
Old 30th December 2005, 14:05   #6
Ashok Arora
Ashok Arora's Avatar
Please understand that the two fluids are to be used for different applications.
For normal (light) use, pull the stalk forward and deploy the regular fluid.
For heavy use, eg. when your screen is smeared or greasy, use the intensive fluid (by pushing the button on the stalk). Do not use the intensive fluid all the time & do not dilute it.
I suggest you empty out your reservoirs as much as possible then fill up with the correct fluids which are available from your dealer; part numbers are as follows:
BMW Windshield Washer Concentrate (regular)
82 14 1 468 858
BMW Intensive Windshield Cleaner
82 14 1 468 859
Ashok
next up.. 2013 F30 Alpina B3
http://www.m5board.com/vbulletin/e60...kend-hell.html
Ashok Arora is online now   Reply With Quote
Old 3rd January 2006, 16:52   #7
3rd One
3rd One's Avatar
it seems I actually have a larger problem than I thought. I went to use the sprayer on saturday after I had just dumped another gallon into it. sure enoug it started leaking out all over the ground. I will lift the car up to see if I can figure this one out.........but has anyone heard of this? the spilling is coming from right underneathe the tank and it came out like crazy when I pulled the sprayer trigger. i have never noticed a spill otherwise.
thanks
Old 3rd January 2006, 16:57   #8
emccallum
emccallum's Avatar
Garage: 2001 m5, 2003 525it
Sounds like a loose hose going to the nozzles.
it seems I actually have a larger problem than I thought. I went to use the sprayer on saturday after I had just dumped another gallon into it. sure enoug it started leaking out all over the ground. I will lift the car up to see if I can figure this one out.........but has anyone heard of this? the spilling is coming from right underneathe the tank and it came out like crazy when I pulled the sprayer trigger. i have never noticed a link otherwise.
thanks
emccallum is offline   Reply With Quote
Old 3rd January 2006, 17:33   #9
SeeSure
Garage: M5 Le Mans Blue
thanks
I had the same problem, and it was a loose connection, visually it looked okay, it was only the pressure from the pump that revealed the problem. Had my garage do the work as it is a stupidly difficult place to get access to. (Cost £20 cash to get sorted).
Why is the slowest person always at the front of the queue ???
SeeSure is offline   Reply With Quote
Old 3rd January 2006, 18:00   #10
E55AMG2
Moderator Emeritus
E55AMG2's Avatar
The greasy film is from worn out blades...
E55AMG2 is offline   Reply With Quote
The Following User Says Thank You to E55AMG2 For This Useful Post:
StevieV22 (29th January 2012)
What's the recommended windshield washer fluid flush interval? ELEVENS E39 M5 and E52 Z8 Discussion 4 8th August 2004 14:28
Problem with washer fluid detergent pump fumaras E39 M5 and E52 Z8 Discussion 1 24th December 2003 17:52
Help!! dealer puts wrong washer fluid? beewang E39 M5 and E52 Z8 Discussion 8 27th September 2003 10:06
Electical bugs and the fix (washer fluid) BimmerBoyM5 E39 M5 and E52 Z8 Discussion 3 8th July 2002 14:37
factory washer fluid tfung E39 M5 and E52 Z8 Discussion 10 18th March 2001 07:10
