Old 22nd December 2005, 01:42   #1
E39 MFIVE
E39 MFIVE's Avatar
Garage: E39 M5, T78FD3S
my M5 Dead battery experience....
Ok I live in the Washington DC area.
Recently the NE region has been getting some wintery mix of
Snow/sleet/freezing rain. So like most enthusiast, I parked
the M5 to keep the Road salt and etc off the beast.
and Drove our Cherokee and Mitsubishi during the bad weather
and thaw out.
So last Sunday, my wife decides she wants to drive the M5 to church.
She wakes me up from my deep sleep, to tell me that
the Keys to the M5 isn't working.. Neither of them...
So I jumped out of bed threw on my heavy coat to see whats
the problem is on our beast.
1. the battery was completely dead. Not even the flashing light
on the rear view worked.
2. All the door locks were locked.
3. The door locks are electronic, so using the actual key in the lock
does no good.
4. I tried to open the trunk with the Key. Both directions. Didn't work.
So im there stumped.. WTF do we do when the car is locked and battery
is dead?? Can't getin the car to pop the hood to jump it.
Breaking the Window or anykind of damage was out of the question.
So my wife says Hell with it.. and Take the little one and her self to church
while I figure out this dilema.
I called BMW roadside assistance.. after calling 2 directories because nobody
had a listing. And all the phone #'s are in the car.
So I finally get thru.
Lady told me to do the electronic key override.. which is:
Lift the door handle, keep it lifted.
Put in the Key and turn counter clockwise, while door handle is lifted.
-- Was suppose to feel resistance and door unlock.
DID NOT WORK.. I tried it probably 100 times in all different variations.
So then they tell me.. Im S O L, its sunday and all the dealerships are closed.
and for me to call Next day and have the car towed to a dealership.
I thought to myself.. My Tow hook is in the car.. How is the tow guy
gonna pull the M5 on the bed with no tow hook??? He'll probably try to
use suspension components. and with the E brake on.. More potential
damage. I was pretty dang worried.
SO I finally gave up.. and got my day going..
So on the way out.. I decided.. Let me try one more time..
I did the Override thing. didn't work.. Then Tried the trunk, again.
But this time.. Put some muscle into it. Guess what...
The TRUNK is actually a Mechanical LOCK.. I had to twist it with some
uumph to counter clockwise and click it unlocked. So I finally
was able to get to teh battery in the trunk and jump start it and
eveything was fine.
But the whole experience conjured up some questions for me..
1. Even if the weather is at Freezing or below. Should the battery be dead
completely if it isn't driven for a week?? I know the E39 probably has
alot of electrical Draw, with teh alarm and OBC and all.. BUT to
die completely when it wasn't driven for 7 days.. Seems odd.
I looked at the little EYE on the battery. It say its fine.
Before the M5 was parked.. It was driven at least every day or every
other day.. before it was parked for 7 days.
2. I jumped my M5 using the battery in the trunks terminal. Which is
self explanatory. But if I had to jump the car from the front.
I know where teh Positive Cable would go, but Where would you guys
connect the NEgative terminal. Using the Engine compartment??
thanks
and a Merrry X mas, hanukka, Kwanzaa, Boxing day to All...
Stock E39 M5
T78 FD3S
zoom zoom...
E39 MFIVE is offline
Old 22nd December 2005, 01:53   #2
jclyman
jclyman's Avatar
Re: my M5 Dead battery experience....
Any unpainted bolt that is grounded ... a bolt on the engine, a bolt on the shock absorber housing ... that sort of bolt. And, the positive goes under the cap with the red cross on it's cover.
- Daniel Boorstin
Last edited by kees; 26th December 2005 at 13:58. Reason: Please don't quote the whole original post
jclyman is offline
Old 22nd December 2005, 02:03   #3
M Macht
M Macht's Avatar
Garage: 2001 Imola Red M5
[quote=E39 MFIVE]I know where the Positive Cable would go, but Where would you guys connect the NEgative terminal. Using the Engine compartment??/QUOTE]
The negative or ground cable should be connected to the bolt on the top of the passenger side shock tower. That's what it is for. You would also connect a Battery Tender negative or ground cable to it and the postive cable to the bolt under the plastic cap labled "+" on the top of the engine to the driver side of the intake plenum.
Nick
2001 E39 ///M5: Imola Red/Caramel/Walnut
PowerChip Gold 91
9.5x18 inch OE Rims On All Four Corners
275/35 Michelin PS2's
Brake Ducts and M Technik Splitter
UUC EVO3 Short Shifter and Double Shear Selector Rod
Rogue Transmission Mounts
BeastPower Sway Bar Brackets
Valentine One and Stealth One
Titanium Pedals
Angel iBright V3.0
Sylvania Silverstar High Beams and Fog Lamps
Platinumvision 2.0 Bulbs
Tinted Windows
"Spare" 8x18 inch OEM Rim and Tire With Jack and All Trunk Lid Tools
M5 Trunk Mat
Trunk Storage Bin
M License Plate Bracket
Too much horsepower is never enough.
M Macht is offline
Old 22nd December 2005, 02:05   #4
E39 MFIVE
E39 MFIVE's Avatar
Thanks guys..
Im just curious.
Hypothetically..
You lost your Key, and your Battery is Dead.
How would the dealership Open the car??
Stock E39 M5
T78 FD3S
zoom zoom...
Old 22nd December 2005, 02:10   #5
E55AMG2
E55AMG2's Avatar
Originally Posted by E39 MFIVE
Thanks guys..
Im just curious.
Hypothetically..
If you turn the trunk key to the extreme left (beyond where you'd think it stops), the trunk will pop open (there is a mechanical linkage there). Dealerships have master keys (and they can order a new key if necessary) to open cars up.
E55AMG2 is offline
Old 22nd December 2005, 02:14   #6
E39 MFIVE
E39 MFIVE's Avatar
oh yea..
Battery Dieing in 7 days... Even if the EYE say its a good battery..
Is this normal?? or no..
Stock E39 M5
T78 FD3S
zoom zoom...
Old 22nd December 2005, 02:16   #7
M Macht
M Macht's Avatar
Thanks guys..
Im just curious.
Hypothetically..
It seems to me that the owner's manuel describes a technique to unlock the car using the key...something similar to what you described. I just don't recall. I'll look into it when I get home.
If I know that I won't be driving my Beast for a few days, I'll hook up a Battery Tender to her to keep her fully charged. She just hates to feel "run down".
Nick
PowerChip Gold 91
Titanium Pedals
Angel iBright V3.0
Tinted Windows
M5 Trunk Mat
Trunk Storage Bin
M Macht is offline
Old 22nd December 2005, 02:21   #8
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
sounds like god was punishing you for not going to church with your wife
reminds me of that simpsons episode where homer talks to god and starts his own religion.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 22nd December 2005, 02:38   #9
M Macht
M Macht's Avatar
Mike, you're too much!
Nick
PowerChip Gold 91
Titanium Pedals
Angel iBright V3.0
Tinted Windows
M5 Trunk Mat
Trunk Storage Bin
M Macht is offline
Old 22nd December 2005, 02:48   #10
GLASIG
Garage: E39 M5 Anthacite
Thats to funny...
GLASIG is offline
Getting Nostalgic, E39 M5 rumours from bmwm5.com back in '97! Gustav E60 M5 and E61 M5 Touring Discussion 12 18th February 2008 07:03
New M5 information direct from Mr. Donnie Isley of the BMW Performance Center atomic80 E60 M5 and E61 M5 Touring Discussion 1 15th September 2004 10:45
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 22:23
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav Most Memorable Threads' 0 4th July 2004 22:13
Rumours about the E39 M5 pre 1998. Gustav Most Memorable Threads' 13 13th August 2002 03:29
Page generated in 0.19647 seconds with 12 queries
