Old 10th December 2005, 01:18   #1
erkq
erkq's Avatar
Garage: graphite 2000 M5
Climate Control drifts colder
I did a search about this and didn't find anything so...
My climate control drifts colder as I drive. I bump up the setting a few degrees at a time to maintain a comfortable temp. At the end of about 45 minutes I'm at 89 degrees (F) and that usually does it. Sometimes I have to go that last step to 90. Then I get a LOT of hot air. Go back to 89 and it generally becomes stable there, maintaining a cabin temp of about 70 degrees.
Any ideas? Bad thermocouple in the sensor? I know a thermocouple can drift like that.
erkq is offline
Old 10th December 2005, 01:24   #2
E55AMG2
E55AMG2's Avatar
Re: Climate Control drifts colder
do you use the dial in between the middle air vents?
E55AMG2 is online now
Old 10th December 2005, 01:35   #3
Digi
Digi's Avatar
Garage: 2006 M5 Silverstone II
Unusual heater functions in general (no fan, no temperature control, wide variations in fan or temperature setting, and otherwise wacky behaviour) is almost always the final stage resistor. This is a very common problem on all BMWs. This would be the first part to replace.
Digi is offline
Old 10th December 2005, 01:36   #4
erkq
erkq's Avatar
I leave that rolled all the way up to red (hot). The cold air comes out of the other vents too. Of course more cold air comes out of the center vents if the dial is rolled down.
erkq is offline
Old 10th December 2005, 01:38   #5
erkq
erkq's Avatar
So that resistor is behind the glovebox? Do I remember that correctly from other threads?
erkq is offline
Old 10th December 2005, 03:14   #6
Digi
Digi's Avatar
Here's a link with pics and instructions:
http://www.540i6.com/finalstagereplacement.html
Digi is offline
Old 10th December 2005, 06:26   #7
KBK
KBK's Avatar
Garage: E39/Anthracite Metallic
The hilarious part is when, in the winter, you put a hot cup of coffee in the cupholder, because you are trying to warm up.
Then you freeze, as the temp sensor..is directly beside the coffee cup...and the temperature in the car goes way down.
What doorknob designed that?
KBK is offline
Old 10th December 2005, 07:39   #8
erkq
erkq's Avatar
Digi: Thank you for the good info. I will try it.
KBK: Absolutely... a doorknob indeed. I couldn't believe they didn't think that one through. Not only what you say, but the cup holders are too small to hold a coke bottle... they only fit a can. PLUS they are so low on the can it can easily tip over if full. PLUS you have to clear the very handy tray underneath of all your change, pens, papers, etc. before you can use it.
I think it's funny. A very quirky oversight that gives the car some character. It can't all be pefection.
erkq is offline
Climate control issue (inside the car ) ilundber E34 M5 Discussion 2 21st November 2005 14:20
Climate control fault E39 M5/540 mossy M5 E39 and E60 tips & tricks 0 27th October 2005 22:13
BMW auto climate control - does it ever work? buymenow00 E39 M5 and E52 Z8 Discussion 12 30th September 2004 17:58
Page generated in 0.14740 seconds with 11 queries
