Thanks Dave. I just spoke with the tire rack and they assured me that the Borbet Type Es ($129 each) would fit over the calipers. I am pretty sure that I have the stock calipers, so it sounds like I should be fine with 17x8 on all 4 corners with the 245/45/17 snows that I have?
Any thoughts on the Vredestein Wintracs? I have heard nothing but good things about them, but there are not that many opinions out there.
Thanks again for your help!
Originally Posted by Teutonaddict
I have a set of Borbet Type-E's that I purchased from the Tire Rack. I happen to run a staggered setup (not likely what you want for winter snows) with 17x8.5 in front and 17x9.5 in back. I run 245/45-17 in front and 275/40-17 in back.
You could easily run the 235/45-17 on all four corners with those wheels. Mine fit both the stock calipers and over my newer StopTech big brakes up front.
Good luck!
-Dave
