Originally Posted by Sudesh Sharma
Where is the compressor located?? Any idea?? What is FREON?
Freon (or modern equivalent) is coolant fluid.
Even if you don't use your aircon, you should switch it on once in a while just to keep the entire system moving regularly. Knowing the M5, it probably is programmed to do this automatically anyway!
England is pretty damp. If you use the windscreen defroster, it usually turns your aircon system on, since the air coming out of it is very dry. This aids in quickly defogging your windows.
Salty.
