Old 7th December 2005, 00:23   #1
oto60
Garage: 2001 M5 Titanium Silver
DEALER DIAGNOSIS??????
I dropped off the beast because I was having loss of power issues. At times the car felt as if its running on only 4 cylinders and did not sound right! I get a call back from the dealer and they say the codes that come up are the CAM ANGLE SENSOR BANK TWO and a VANOS fault. The dealer sais that they are just going to replace the sensor first and see if the VANOS still give a fault code. The technician claims that a bad sensor can set off a VANOS fault. Is this true? It sounds to me like they are too lazy to replace the VANOS unit and just want to patch fix the car???? Any thoughts would be great.
oto60 is offline
Old 7th December 2005, 00:27   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Re: DEALER DIAGNOSIS??????
sounds like the right thing to do to me, especially if you're paying.
cps's fail often, vanos' do not, relatively speaking, and a bad cps can cause a vanos fault since cam timing could be off.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 7th December 2005, 00:28   #3
oto60
Actually its all under CPO warranty. I just dont understand how the cam angle sensor would have anything to do with the VANOS unit. Are they related in any way??
oto60 is offline
Old 7th December 2005, 01:19   #4
mottati
mottati's Avatar
Re: Dealer diagnosis - cam angle sensor
if i understand it correctly, the cam position sensor is involved in controling the vanos, if the cps is malfunctioning, it will result in vanos disfunction. You should run a search for 'cam position sensor' on this board, you'll find a lot of information, it's a common fault.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 7th December 2005, 01:36   #5
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
I understand they work together to get the variable timing. CPS fault will often show up as a VANOS code also. Since the CPS is relatively easy and cheap to fix, your dealer is being prudent to do the most likely repair from experience. It shouldn't matter who is paying. You certainly wouldn't want to pay to replace the VANOS on your nickel when a cheap CPS repair would do the trick.
gsfent is online now
Old 7th December 2005, 05:55   #6
hudson
hudson's Avatar
Garage: 2000 M5 Anthracite/Black
In order for the Vanos system to work properly it needs to know the precise position of the cam. It's very likely the replacment of the CPS will also make the Vanos system function properly again.
Joe
hudson is offline
Old 8th December 2005, 00:51   #7
verhagke
verhagke's Avatar
Garage: 2000 BMW M5 (Titanium Silver)
Kudos to your dealer. Sounds like the right diagnosis.
verhagke is offline
Dealer Responsibility - Your Opinions Please sarends E39 M5 and E52 Z8 Discussion 20 1st October 2006 18:59
Good service from dealer - no charges! SCORPIO E39 M5 and E52 Z8 Discussion 8 3rd June 2005 00:15
Ever skip dealer prep Mr. Grinch E39 M5 and E52 Z8 Discussion 9 9th October 2001 12:06
Bought out of state, Possible to have delivered to local dealer? ALittleLuck E39 M5 and E52 Z8 Discussion 6 27th September 2001 07:49
One screwed up dealer BoringFamilySedan E39 M5 and E52 Z8 Discussion 13 16th September 2001 10:29
Page generated in 0.13254 seconds with 11 queries
