E39 M5 Frequently Asked Questions (FAQ) - Page 6 - BMW M5 Forum and M6 Forums
Like Tree1Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 2nd January 2010, 22:55   #51
spoolin51
Garage: BMW M5
This thread is AWEsome
spoolin51 is offline   Reply With Quote
Old 31st January 2010, 21:06   #52
springer454
springer454's Avatar
Garage: 2001-LMB/blk INT,W-SILVER TRIM,DICE, IPOD,Shark,Timmy's tips,BIMMERNAV,W SNAPIN-1999-540I silver,WGREY 1994-740IL green,WSAND
Ditto
+1
springer454 is offline   Reply With Quote
Old 2nd June 2010, 12:53   #53
adventure
adventure's Avatar
Garage: e39 m5 anthrasit
needs updating..thanks.
adventure is offline   Reply With Quote
Old 13th November 2010, 19:38   #54
jamesrothwell
jamesrothwell's Avatar
Garage: Nothing but an E60 M5 soon...
Some very useful hints in there!
jamesrothwell is offline   Reply With Quote
Old 15th November 2010, 04:39   #55
TravisBurrell
TravisBurrell's Avatar
Garage: E39 M5 '00 Carbon Black
I just want say thank you to everyone who is an important part of M5board, and thank you to all the useful info in this thread. This is great!!!
D I N A N lllM5
E39 2000 Carbon Black/Black Interior
TravisBurrell is offline   Reply With Quote
Old 5th December 2010, 04:12   #56
MannyE39M5
Garage: 2002 M5 leMans blue
can someone please help me if an e34 m5 differential will fit my 02 e39 m5? thank in advance
MannyE39M5 is offline   Reply With Quote
Old 24th March 2011, 23:16   #57
chowdah
Super Moderator
Garage: sweetness
Sales Feedback: (4)
Archived prior to Mar'11 update
Seeing as many questions keep being asked over and over again by new members, this should answer most questions when first purchasing an E39 M5.
Manuals in English for the 2000, 2002 and 2003 models are attached in the bottom f this post.
M5board
HOWTO: Upload pictures to M5Board.com
General
Book recommendations
Website recommendations
Speeds, gears, torque, acceleration, rear-ends, etc.
ALL BMW technical documentation ONLINE!
MP3 disc creation guide
Aftermaket Warranty Information Database
General E39 M5
Download E39 M5 Owner's Manuals
List of Abbreviation/Terms
M5 E39 Body Style S62 engine FACTS
M5 Common Problems and Running Costs
M5board featured in TotalBMW Buyer's Guide
Places to look for rust when buying an E39 M5
Videos: Learning to Launch and Shift the M5
Greg's M5 driving school
Buying a car out of state tips?
Recall Campaign 01V-206: Engine Auxiliary/Cooling Fan
Drivetrain
Timmay's Official Muffler Delete Thread
Peake Research tool for reading ODB2 & BMW fault codes
Which model Peake reader to get
Knowledge base on Peake codes for E39 M5
Differential Leak
Vanos Issues
VANOS Solenoid Replacement DIY
How VANOS work
Oil Filter Housing Mount
Carbon Buildup FAQ (summary)
Carbon Buildup FAQ (long)
Software fix for Carbon Build-Up issue
PICS: Carbon Cleaning- secondary air passages
Oil FAQ
DIY guide for sparkplug replacement
Tips for changing spark plugs
Fuel Filter install DIY, observations and tips
Fuel Filter Replacement
TECH: How to accurately compression test an S62 engine
How to test the MAFs yourself and How MAFs work
Cleaning MAFS
US$ 115 MAF group buy, both for Europe and US
MAF sensor removal tool?
VW MAF install
Replacing oxygen sensors
Stripped oilpan bolt
Rod bearing DIY
Vanos solenoide removal
Clutch DIY
Propshaft center bearing DIY
Chain tensioner DIY
ABS sensor DIY
Clutch line DIY
Waterpump DIY
Long and technical: thoughts on cold air intakes and temp sensor relocation
How to reset your service indicator
Steve Dinan's White Paper on the Dinan S2-M5 and Dyno Testing
Jammed Transmission Selector Fix
Clean up shifter slop
Info: When installing Supersprint Headers
Zionsville Super Duty Radiator Installation
DIY Tech: CPS Replacement
DIY Tech: CPS Bank 2 Replacement
VANOS Warranty in California
DIY: Serpentine Drive Belt Replacement
Rod Bearing Replacement- In Car- Pictures and costs
Fuel Tank Breather DIY (Peake E8 code)
Another Fuel Tank Breather DIY (Peake E8 code)
Yet another Fuel Tank Breather DIY (Peake E8 code)
Timing Chain Replacement, VANOS replacement and setting timing
Thermostat Replacement 1
Oil Pan Thread Repair
DIY- O2 Sensor Change
Muffler Delete- ALL YOU NEED TO KNOW
Suspension & Brakes
Suspension alignment specifications
Rear Swaybar Brackets
Fixed steering wheel vibration!
X5 Thrust arm bushings
Installing X5 bushings
Possible front control arm bushing failure?
excellent brake article
Why aren't the OEM rotors cross-drilled?
Which Big Brake Kit (BBK)?
E39 M5 Brake Duct Modification
Brake/Clutch Bleed w/ATE Super Blue
Installing Ground Control suspension
DIY guide for Front Suspension Coil Over Install
DIY guide for Rear Suspension Coil Over Install
Wheels & Tires
Original Manufacturer of Chrome Shadow paint
Bodywork & Lights
Angel Eyes - Stock vs PIAA vs ICE [PICS]
Installing Celis Tail Lights
Step-by-step paint scratch removal guide
Failing Electrochromic Mirror- Warranty Info
Adventures with Headlight Adjusters
Passenger side mirror replacement
Battery Replacement Options: BMW, OE, etc..
Interior
NAV Hardware and Software Version
NAV Status Screen providing gyro data
4:3 to 16:9 navigation upgrade
Changing the viewing angle of the 16/9 navi screen
Oil Pressure Gauge Install
Missing Pixels on dashboard display
Repair guide for missing pixels in odometer display
Alternate Repair guide for missing pixels in odometer display - Ribbon Cable Replacement
Vent Fan Failure--Final Stage Unit replacement?
Troubleshooting non-working central locking system (key is not dead)
Troubleshooting remote trunk (boot) release
Tech: How to reset your service indicator
Secret menu
Rear Deck Rattle - DIY Fix
DIY guide for Rear Deck Removal
DIY guide for Bluetooth retrofit kit
Upgrading early M5's to MY2001 onwards look
00 --> 01 Front Headlight Conversion Instructions
Steering wheel / airbag upgrade
Navigation 4:3 to 16:9 - see Interior section
Special Projects
M5 UTE conversion
My thoughts on living with a Area 51 Supercharged M5
On acquiring “El Diablo”, Black M5/Discovery Automotive über-beast!
Buildstory of DINAN supercharged 540i Touring
540i 4.9 Kompressor buildstory
Nowack N-500
S3 #17 Is Back From Dinan
First Impressions with my Dinan S3 #18. Test Drive today......
Dinan S3 project has started......
Report on Delivery of Dinan S3 #22 (pics) [Very comprehensive write-up]
Dinan S3 #23 is back
Build of NYC S3 #24 (Pictures)
NOS on e39 M5?
Stealth One:
Software
Manual
chowdah is online now   Reply With Quote
The Following User Says Thank You to chowdah For This Useful Post:
havasusteve03Beast (11th April 2011)
Old 25th March 2011, 01:40   #58
chowdah
Super Moderator
Garage: sweetness
Sales Feedback: (4)
Added to the refreshed FAQ.
Old 10th August 2011, 19:58   #59
m5rosemont83
m5rosemont83's Avatar
Garage: 2002 M5 Chiaretto Red
Maybe this can find its way in there somehow
Everything you want/need to know about oil
2002 Chiaretto Red purchased with 58k 01/2011
03/02/13@ 99,400 miles
Getting closer to 100K each day..
Mods:
Valentine 1 hardwire
Muffler delete
Evolve AlphaN
Predator Ice V5 Halo bulbs
E60 SSK
ILLUMINATED ZHP shift knob
Slimm's CF finned diffuser
Slimm's Euro tilt/slide armrest
Slimm's Alcantara shift boot
Slimm's Alcantara full e-brake
Black Cubic trim
BC Racing BR coilovers
Evolve 4-1 Medusa Headers, cats, X pipe
Supercharger... (someday)
__________________________________________
My car/vehicle history:
1993 BMW 525i (sold)
1997 CBR1100XX Super Blackbird (sold)
1994 Firebird Formula V8(Total of 3 days )
2002 Jaguar X-type 3.0 Sport manual (sold)
1992 300ZX Twin Turbo (sold)
2002 BMW 530i Sport (sold)
2007 CBR1000RR (RIP)
1988 BMW 325i convertible (sold)
2002 BMW M5
(Current driver)
2002 Chevy Camaro Z28 35th anniversary(sold)
1991 300ZX Twin Turbo super white 130k Miles! (For sale soon! Contact me for details)
m5rosemont83 is offline   Reply With Quote
Old 11th September 2011, 01:35   #60
Terabass
Terabass's Avatar
Garage: M5 Matte Black
Add these to the list.
Fuel pump video DIY: DIY: Video: BMW M5 E39 Fuel Pump
Fuel filter video DIY: Video: BMW M5 E39 Fuel Filter
http://otomobile.com
Terabass is offline   Reply With Quote
M5 E39 Body Style S62 engine FACTS...Long V-10 4 Me E39 M5 and E52 Z8 Discussion 63 5th June 2012 22:00
e39 m5 is the undisputed champ cebu E39 M5 and E52 Z8 Discussion 7 1st February 2008 06:28
Few E39 M5 questions Kain E39 M5 and E52 Z8 Discussion 40 11th June 2006 15:16
Rumours about the E39 M5 pre 1998. Gustav Most Memorable Threads' 13 13th August 2002 02:29
