Restrictive stock air intakes - BMW M5 Forum and M6 Forums
Old 10th November 2005, 16:20   #1
stu-e-boy
Garage: BMW M5 CARBON BLACK
Restrictive stock air intakes!!!!!
I've just been checking out where the car gets its air from and I can't believe what I've seen. The only place the two air snorkels get flow from is through 6 small holes on the passenger side of the bumper. Everywhere else is completely closed off from sending air their way. Surely this can't be good for the engine starving it of so much air? Some of my customers have CSL M3's and they have a lovely ram air style tube feeding their mill, even my E36 Evo had air channeled directly to it through the front spoiler and into a tube for the air box. Why is it BMW decided to put the M5 intakes here???? It's like asking Maurice Green to run the 100 with a wet cloth over his mouth.
Bemused,
Stu.
ps. Will be creating some proper air flow through the spoiler units myself tonight.
stu-e-boy is offline   Reply With Quote
Old 10th November 2005, 16:26   #2
alantd
alantd's Avatar
Garage: 09/02 E39 M5; Carbon Black; Stock
Re: Restrictive stock air intakes!!!!!
Let me know how you get on.
I was checking this out myself the other night and couldn't see any decent air flow.
alantd is offline   Reply With Quote
Old 10th November 2005, 16:51   #3
stu-e-boy
Will do, my test was to get a small torch and when it was dark shine it in anything that resembled an opening and suprise, the only place light cam through was the 6 little holes.
Old 10th November 2005, 17:45   #4
cableguy
cableguy's Avatar
Garage: 2003 996 GT2
AA CAI is the way to go my friend.
C.
2003 996 GT2 - Brutal...
cableguy is offline   Reply With Quote
Old 10th November 2005, 18:04   #5
Jayson
Jayson's Avatar
Garage: m5
Acually the air intakes go from the air boxes down into the front of the bumper and the air that flows through the lower "mouth" if you will and into the air intakes, all the AA air intake does is stretch it further.
Shown here.
http://www.m5board.com/vbulletin/att...achmentid=9983
http://www.m5board.com/vbulletin/att...achmentid=9981
http://www.m5board.com/vbulletin/att...achmentid=9982
Jayson is offline   Reply With Quote
Old 10th November 2005, 18:46   #6
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II 93 M5 3.8 Sterling Silber
the opening to the airboxes are behind the headlamp assemblies, just outside of the grill area. Plenty of air in there....
mottati is offline   Reply With Quote
Old 11th November 2005, 05:08   #7
HDClown
HDClown's Avatar
Garage: 2002 M5
Shown here.
The stock intake trumpets sit behind the top portion of the bumper where this is no direct contact with outside air. So you are getting air that is pushed/sucked in from the lower opening and up to the intake trumpet openings. The AA moves the intakes for the trumpets directly into the pathway of air in the lower grill, which is going to be more efficient for getting air into the system. It also gives you a wide intake trumpet opening and air channel compared to the stock one
2002 LMB/LMB M5 - Alcantara Headliner, Electric Shades, Folder Down Seats, M-Audio
-Britalman Exhaust, Brembo GT 355f/345r Big Brake Kit, Centric Posi-Quiet Pads, AA CAI
-UF IATS Relocation, UUC Evo3 SSK + DSSR, UUC Clutch Stop 19" Breyton Spirit Rims
-TCD Rear Sway Brackets, Euro Angel Eyes, Angel iBright v3.0, Stealth Bulbs, Stealth One
-Valentine One, Roof Spoiler, OEM Voice Control, OEM Trunk Storage Bin, 13% Solar Gard HP Tint
HDClown is offline   Reply With Quote
Old 11th November 2005, 22:15   #8
ttboyvanc
ttboyvanc's Avatar
Garage: 1999 M5, Silverstone
I am going to run some vacuum tubing up from the foglight assemblies to the stock airboxes, and use the front grill for brake cooling ducts!
I think someone else on the board did the same and noticed better drivabilty... Threre might even be some pics... I'll post some when I'm done...
Mods:
Need an M5 before I can mod one!
ttboyvanc is offline   Reply With Quote
Old 11th November 2005, 23:35   #9
stu-e-boy
Update:
Yesterday I drilled out about 25 holes on each side of the spoiler where after market Cold Air Induction kits would exit. It was dark by the time I finished and so I used my torch to see how much light was now being let through to the area where the stock snorkels are and it's inifinitely better than before the operation. I then took her for a test run, temp outside was 11 degrees c, which is cold I know, but I swear she pulled harder all the way. It felt like the engine was giving loads more at about 4500 upwards where usually you can feel a slight weeziness to her. The engine felt as eager and happy to pull at high revs as my old 68 Road Runner did running a high rise Team G intake manifold. Total cost of my mods so far, £0.
Like the idea of the vacuum tubing, let me know how you get on.
Anybody wrapped their headers in heat proof tape yet to help with under hood heat?
Stu.
Old 12th November 2005, 01:48   #10
ttboyvanc
ttboyvanc's Avatar
Thanks will let you know, with pics, will be few weeks though, (I'll be out of town).
Also, a wise man once told me that anyone getting the supersprint headers should get them ceramic coated first, he said lots of people spend a lot of $$ on Supersprint headers but they release so much heat into the engine bay, why not spend a little extra and get them ceramic coated and keep engine bay temps WAY down. Anyways, never thought of doing it to the stock headers... good idea...
Days 3 and 4 - Final Heat Tests, Conclusions and Recommendations greg E39 M5 and E52 Z8 Discussion 51 28th June 2007 22:06
Long and technical: thoughts on cold air intakes and temp sensor relocation greg E39 M5 and E52 Z8 Discussion 48 4th August 2006 09:23
Location of OEM air temp sensor? help! vics E39 M5 and E52 Z8 Discussion 2 4th August 2005 17:54
Feeding the (factory) cold air intakes Teutonaddict E39 M5 and E52 Z8 Discussion 9 31st March 2001 15:30
TimW, Cold air intakes... DrKevM5 E39 M5 and E52 Z8 Discussion 1 20th February 2001 02:48
