Old 8th November 2005, 18:41   #1
cosioboy
cosioboy's Avatar
Garage: 2000 M5 Carbon Black
My StopTech BBK Install at Dave Z.
Well, I finally got to installing my front StopTech 335x32mm BBK, at no place other, than at our brake resident guru - Dave Zeckhausen. Had a wonderful experience dealing with him and absorbing a generous amount of knowledge in the area, thanks for everything, Dave!
The beautiful autumn day began with a very nice lunch at Panevino’s, little did we know we needed the extra calorie intake for later on when we had to drill through all 4 of the rotor retaining screws, which were just about baked into the hats. That was the only ‘unplanned’ action item, all else was smooth and according to plan.
I opted for the cross-drilled zinc plated rotors coupled with the red calipers shod with Axxis Ultimates pads (stainless steel lines of course included in the kit). Love the look (already received several compliments), and of course the improved brake feel. On that subject, here are my thoughts:
The brake pedal is certainly firmer than stock, but perhaps not as much as I originally anticipated. Not that I find it fading, on the contrary, but for some reason I thought it would be even firmer. I know once I upgrade the rears (to the two-piston rear that fits over the factory rims) with the stainless steel brake lines, it will be further improved. Perhaps I still have the ‘bias’ left of when I upgraded my (really horrible) stock front breaks on my CLK 430 with a 355mm Brembo Gran Turismo BBK - that's when I felt a night-and-day difference. Obviously, the stock M5 brakes are fairly good to begin with, so it was perhaps unreasonable for me to have expected the same 'wow' effect.
I also felt an improvement in overall braking, not surprising as the Axxis have a much better bite than the stock (dusty) pads. And interestingly enough, unsprung weight decreased by about 30 lbs or so. The OEM brakes are super heavy, partly because of the use of cast iron (for the hats and calipers), partly because the rotor itself is heavy given that it is single piece (hats integrated in rotor). This weight reduction upfront will nicely balance the rear weight reduction I got from installing the Supersprint X-Pipe and cans, so I am back to a factory spec 50/50 weight distribution.
Once again, thanks a bunch Dave Z. (and boardmember 01M5) for making this experience both insightful and a true pleasure.
Here are a few pics:
cosioboy is offline
Old 8th November 2005, 18:46   #2
M Macht
M Macht's Avatar
Garage: 2001 Imola Red M5
Re: My StopTech BBK Install at Dave Z.
Looks great. Are those stock front wheels?
Nick
2001 E39 ///M5: Imola Red/Caramel/Walnut
PowerChip Gold 91
9.5x18 inch OE Rims On All Four Corners
275/35 Michelin PS2's
Brake Ducts and M Technik Splitter
UUC EVO3 Short Shifter and Double Shear Selector Rod
Rogue Transmission Mounts
BeastPower Sway Bar Brackets
Valentine One and Stealth One
Titanium Pedals
Angel iBright V3.0
Sylvania Silverstar High Beams and Fog Lamps
Platinumvision 2.0 Bulbs
Tinted Windows
"Spare" 8x18 inch OEM Rim and Tire With Jack and All Trunk Lid Tools
M5 Trunk Mat
Trunk Storage Bin
M License Plate Bracket
Too much horsepower is never enough.
M Macht is offline
Old 8th November 2005, 18:53   #3
cosioboy
cosioboy's Avatar
Thanks. Yup, these are stock fronts.
I should mention that the zinc coating is still visible here (hence the yellowish discs) as this was immediately after install before we did the bedding in procedure. Naturally, the disks are silver in color now.
I followed Dave's recommendation on the zinc plating option, as they tend to last longer (specifically the hats are more durable and can be reused next time when replacing the rotors), look better (no rust becoming visible in the cross drilled holes), and is generally the way to go for 4-season climates where they might be salt and other elements on our roads.
cosioboy is offline
Old 8th November 2005, 18:59   #4
01M5
01M5's Avatar
Garage: 01 LeMans Blue M5
Very nice Constantine! I'm glad all worked out for you and that you are enjoying them.
01M5 is offline
Old 8th November 2005, 21:37   #5
KevinM
KevinM's Avatar
Garage: 2002 E39 M5, Sterling Gray/Caramel
Kevin
2007 M Coupe, Silver/Black
KevinM is offline
Old 8th November 2005, 21:52   #6
MT JTN
MT JTN's Avatar
Garage: 2002 Carbon Black BMW M5
Yes, I agree, they look great!
I'm jealous.
'02 M5 -- Carbon Black/Imola
____Supersprint X-Pipe & mufflers
____Dinan short-shift kit
'03 MINI Cooper -- Pure Silver/Black
MT JTN is offline
Old 8th November 2005, 23:10   #7
Habu
Garage: E39 M5 TiAg
Sales Feedback: (3)
cosioboy,
Nice looking conversion. I noticed some white stuff on top of your fender. What is that? Looking at it more closely, I think that a tree in the reflection. If that's correct, dang you take real good care of your car.
Bob
Habu is offline
Old 8th November 2005, 23:23   #8
Stickman
Stickman's Avatar
Garage: 2002 Black/Black M5, 91 535i Black/Black
Thank you so much for sharing your great experience. The upgrade looks great - I like the cross drilled rotors too.
Congratulations!
Stickman is offline
Old 9th November 2005, 00:29   #9
cosioboy
cosioboy's Avatar
Thanks a lot, guys.
Habu, the white stuff you see on the fender is a reflection of a cloud I believe, and actually, my car wasn't washed before that, but I do tend to try and keep the shine on the Carbon Black Beastas much as possible. It is a tough color to keep in shape, but if you do regularly, it is quite rewarding.
cosioboy is offline
Old 9th November 2005, 01:49   #10
DAD'sM5
DAD'sM5's Avatar
Garage: '00LemansBlueM5
Great pictures Tino.
Do you track the car as well?
They sure look sharp and I'm sure the performance with the rears converted will match the image.
Happy motoring (and stopping)
Jack B.
2000 M5
Lmns Blue
M - Audio
Silverstone
Angel Eyes
6000k bulbs
Sun-shades
60/40 seats
Chrome Trim
Dinan Exhaust
Dinan Software
K-40 Radar Detector
TEC Center Cupholder
B.P. Titanium Foot Pedals
(I'm the Dad who drives it!)
DAD'sM5 is offline
Bilstein PSS9, Stoptech BBK review (long) Jayson E39 M5 and E52 Z8 Discussion 62 7th November 2005 23:56
StopTech 4-wheel BBK - $750 off! Brand new, ready to ship! DZeckhausen M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 6 25th July 2005 18:40
Trouble Installing StopTech Front BBK Ridgeback_Pilot E39 M5 and E52 Z8 Discussion 22 5th March 2005 03:29
Is it art or is it StopTech? And, why you should go buy from Dave Z, ASAP! [PICS] Redshift E39 M5 and E52 Z8 Discussion 35 16th January 2005 06:28
Dinan BBK Install x703jko E39 M5 and E52 Z8 Discussion 4 16th October 2004 01:59
Page generated in 0.19465 seconds with 12 queries
