Curiousity: How long to let car warm up? - BMW M5 Forum and M6 Forums
Old 28th October 2005, 23:41   #1
ATLANTA M5
ATLANTA M5's Avatar
Garage: 2003 M5, 2005 330i, 2011 550i
Just a curiousity question here. When the M5 is cold, first start up in the morning, especially when the weather is cold too...how long do you guys and gals let the car sit and warm up? Just to be on the safe side I have been letting the car sit and warm up for at least one minute before actually driving away...that is recently upon cold start and the weather has also been more chilly in Atlanta and car is left outside.
Also, worth mentioning, my brother in law used to tell me that he needed to let his Ferrari 355 warm up for like 10 minutes! But, I guess that makes sense if the car has just been sitting around for days and you want to take it for a joyride better make sure that thing is well oiled up and warm.
I just can't tell you how much I love this M5. I am starting to wish my five minute drive to work was longer because the car is barely getting to full warm up when I pull into work!
2003 E39 M5 Titanium Silver/Black - A Few Mods
2005 E46 330i Alpine White/Sand - Wife's Daily
2011 F10 550i Alpine White/Oyster - Modded Daily
ATLANTA M5 is offline   Reply With Quote
Old 29th October 2005, 00:01   #2
Stickman
Stickman's Avatar
Garage: 2002 Black/Black M5, 91 535i Black/Black
Re: Curiousity: How long to let car warm up?
Of course, here in So California, it isn't really "cold". But anyway, I just fire her up and drive off. No idle warm-up. However, I keep the RPMs low until the lights go out on the tach (those that go out that is ).
Stickman is offline   Reply With Quote
Old 29th October 2005, 00:22   #3
Anzir
Anzir's Avatar
Garage: Silverstone 2000 M5
Ditto
Anzir is online now   Reply With Quote
Old 29th October 2005, 01:30   #4
GAS M5
Garage: M5 Titanium Silver
Lights & Oil Temp
I garage my car and drive off right away.
I do wait for the yellow RPM lights to go away (except the last one which always stays on) and also wait for the oil temp to get past the first line before I start pushing the car a little.
GAS M5 is offline   Reply With Quote
Old 29th October 2005, 01:36   #5
CEC
CEC's Avatar
Garage: 2002 BMW M5
In the winter I let it idle for a about 5 minutes - not really because I want to, but because 1st and 2nd are so stiff that it isn't easy to drive.
Chet
CEC is offline   Reply With Quote
Old 29th October 2005, 01:40   #6
JB_UK
Garage: 'OO M5 - Silverstone
I always let the car warm up until the oil temperature is right. Never push a cold engine!
10 mmins may seem about right, as I tend not to go aove 3000rpm (unless essential!!) regardless of what the lights on the rev counter say. Just over cautious I guess!
JB
JB_UK
'00 Silverstone
'99 323SE
'94 MX6
JB_UK is offline   Reply With Quote
Old 29th October 2005, 02:07   #7
M Macht
M Macht's Avatar
Garage: 2001 Imola Red M5
Same here in Northern CA. Modern engines are designed not to need a "warm up" period before driving off. Just be gentle with the throttle and keep the revs low until the oil is at operating temperature, i.e. when the yellow tach. lights go out. This is good advice for any modern engine. In effect, you are gently warming up the engine as you are heading toward your destination and saving fuel as a bonus.
Nick
2001 E39 ///M5: Imola Red/Caramel/Walnut
PowerChip Gold 91
9.5x18 inch OE Rims On All Four Corners
275/35 Michelin PS2's
Brake Ducts and M Technik Splitter
UUC EVO3 Short Shifter and Double Shear Selector Rod
Rogue Transmission Mounts
BeastPower Sway Bar Brackets
Valentine One and Stealth One
Titanium Pedals
Angel iBright V3.0
Sylvania Silverstar High Beams and Fog Lamps
Platinumvision 2.0 Bulbs
Tinted Windows
"Spare" 8x18 inch OEM Rim and Tire With Jack and All Trunk Lid Tools
M5 Trunk Mat
Trunk Storage Bin
M License Plate Bracket
Too much horsepower is never enough.
M Macht is offline   Reply With Quote
Old 29th October 2005, 03:02   #8
BKH
BKH's Avatar
Garage: 2000 BMW M5 Silverstone
I've been told by an Audi factory engine designer to just drive off after startup, gently, because oil pressure at idle is sufficiently low that higher engine speeds than idle significantly (and beneficially) increase oil flow.
2009 Mercedes-Benz C63 AMG
2006 Z4 M Coupe
2000 E39 M5
BKH is offline   Reply With Quote
Old 29th October 2005, 03:29   #9
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
I am with you. In south Florida, not much of an issue. I simply start the car, and in the time it takes to buckle my seat belt and hit the sport button is the time the car gets to warm up. Gentle driving until the oil warms up(tach lights are nice, but I want the oil warmer before I get on it, so I watch the gauge).
In colder climates, if the gearbox is notchy, let it idle a little bit to warm things up a bit, and then, drive gently. It will warm up quicker under load than just sitting in the driveway at idle.
gsfent is online now   Reply With Quote
Old 29th October 2005, 03:42   #10
6spd
6spd's Avatar
Garage: 73 Pinto Babypuke Green
I never knew there was any difference in a engine.
They all need to be warmed so pistons can expand and blowby is reduced.
I wait a few minutes till it is about a 1/4 of the way up then drive easy.
I stop at every stoplight I can at first.
I've already replaced leaky cam cover gaskets from being in a hurry.
I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way.
Modifications
Chipped paint
Worn tyres
Dirty Carpet
Chipped windshield
6spd is offline   Reply With Quote
Nice garage (McLaren F1) + interesting story about #69 Gustav GTBoard.com: General Sportscars 5 10th March 2005 03:11
The RUF experience, with a side order of M5 (very large and loads of pics :)) Adam Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com 42 15th May 2003 19:03
GERMANY 2003 PT.2 (Visit to RUF) alpinadvl E39 M5 and E52 Z8 Discussion 10 8th April 2003 21:58
3.6 owner meets a 3.8 car... IvanDias E34 M5 Discussion 16 9th April 2002 09:57
NY Auto Show Pics MEnthusiast E39 M5 and E52 Z8 Discussion 29 4th April 2002 04:42
