Does anyone have engine heater in E39 M5?
Electrical(Defa/Calix) or petrol (Webasto/Eberspacher)?
I would like to know is it possible to have one of those in M5?
Other option for my M5 is 6 months in garage every year and buying some older BMW like E34lovelove 525-535 for wintercar
One of our Scandanavian members (I think) wrote a detailed post several years ago about how he configured his car with block heaters and I remember it being a nicely done job utilizing the fog light cover for the electrical connection. Can't recall who but a search should bring it up.
After a nasty cold snap last year I had the oil sticking to the engine instead of returning to the pan. I bought a glue on pan heater, it does work but only heats the oil. It also is only used for a max of 1 hour which makes it a bit of a pain. No plug and forget you have to think about when you will be driving the car.
That said until it gets below -25 I have had no issues or need for heat.
Defa heater is external and fitted to oil pan, as it heats the oil/block from below, the heat transfers to top of the engine too and gets coolant fluid warmer too. It is meant to ve on at least 2 hours and basically there is no max time for it. Although even in coldest temperatures over 5-6hours is not needed.
http://youtu.be/Q4KWTIZYCMI I remembered +5c would be the temperature but apparently more recent studies have came to even higher temperature solution....
I have always wanted one of those Webasto heaters for the auxiliary heat feature.
That being said, for the week that we saw the oddly cold -10 to -28F weather last year, I had no issues with my M5.
I was more thinking of the Webasto setup from 540/740, fuel driven, heats water + runs aux fans with timer already in place in Nav unit. - I guess it was dropped out from M5 due to space limitations (I think watertank for wipers is using that space on M5?)
Had one on my 530d - it was great. Lived in rear of right hand side front wheel well (when viewed from drivers seat)... Really pumped some heat out. Probably no reason why you could not retrofit a webasto in that gap if space is there.
I added remote key fob that could trigger it from up to 2km's way!
BMW has offered their "own" Webasto, it's coolant heater. http://bmwfans.info/parts-catalog/E...and_air_conditioning/fuel_supply_pump_tubing/ Get those parts and heater from webasto. Seems like retrofit kit is not anymore available for e39.
I have one in my E61 and it's nice to have but these heat the interior only, unless you do small modification. Then it runs heated fluid also in the engine.
125.8K members
