Re: Changing spark plugs on the Beast. DIY or not?
sure it's diy. 4 bolts to remove the coil covers, then 4 nuts for each coil. Pop the coils off and you have access to the plugs. the rear most plugs are hardest to get at, of course, but i can do it in under an hour after a couple of times.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
