Old 17th October 2005, 04:01   #1
flyinryanr
Garage: 2003 silver m5, 1997 white 540i/6
velocity stacks
I was wondering if anybody has some info on the power increase of aftermarket velocity stacks. I have seen the discovery automotive/$2000, technik/$1000, dinan/$5400 but none post the hp/tq increase. Dinan does but it is in conjunction with the larger throttle bodies and many other mods. If there is a 5hp increase I can't justify the buy, any comments or dyno results.
flyinryanr is offline
Old 17th October 2005, 04:34   #2
toolape
Garage: Carbon Black 2001 M5
Re: velocity stacks
Just curious - do you have headers? I'm not sure, but I think this is the best bolt-on HP gain for your buck.
toolape is offline
Old 17th October 2005, 04:36   #3
adam28
adam28's Avatar
Garage: 01 PorscheTT
Re: velocity stacks
I think this mod works best w/ the intake, throttle bodies, MAFS...not as a stand alone.
adam28 is offline
Old 17th October 2005, 04:50   #4
Silverstone//M5
Garage: E39 M5 Silverstone
Re: velocity stacks
What's a good bang for the buck header? I was considering Dinan but would like to research more.
Thanks.
Wayne
Silverstone//M5 is offline
Old 17th October 2005, 06:05   #5
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Re: velocity stacks
dinan doesnt sell the velocity stacks as a stand alone, they are larger diameter and wouldn't fit. WIth the throttle bodies (after everything else in their catolog) dinan claims 38hp.
Headers will get you a real 30hp, dinans are nice, but expensive. supersprints will make similar hp, maybe with a little low end loss, for a bit under $3k.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 17th October 2005, 06:12   #6
BmwNut
BmwNut's Avatar
Garage: '01 540/6
Send a message via AIM to BmwNut
Re: velocity stacks
Wasnt there a thread around awhile ago where someone lost some low end with velocity stacks and didnt pick up much of anything on the high end? I'll try searching for that, as it would be a good read for anyone who is looking to do the mod.
-Brendan
'01 540/6
BmwNut is offline
Old 17th October 2005, 10:39   #7
Code3M5
Code3M5's Avatar
Garage: M5 Black
Send a message via MSN to Code3M5
Re: velocity stacks
Evosport did some tests and told me that there were some power gains on the high-end, but you will loose some everywhere else. Not a good mod.
Code3M5 is offline
Old 17th October 2005, 13:43   #8
Carrera2RS
Garage: M5
Re: velocity stacks
I have the velocity stacks, and a few other mods, compared to a standard car is offer more 'sparkle' up the top end and doesnt feel flat beyond 6,500 rpm. For me a nice mod as they sound fab, it propably loses a little at the bottom and picks up a touch at the top end. But lets face it how many people mash the throttle at 2,500 rpm ? If you drive the car with Sport on/off then this will have more effect at part throttle than any loss of torque from ram stacks. maybe you lose a few hp at full throttle sub 3,500 rpm, but worth the trade in my view
Its more of a balance change than mega performance mod comparing a stock car to the mods below
Carrera 2RS
Carrera2RS is offline
Old 17th October 2005, 16:28   #9
flyinryanr
Re: velocity stacks
I'm surprised to see you don't have headers yet on you mod list/why? What brand of velocity stacks did you get and did you get a custom chip with them.
Old 4th March 2006, 00:37   #10
warhaven
warhaven's Avatar
Garage: 2002 M5 Jet Black
Concur with the header issue. I am really wanting that mod just havent made the deciaion which way to go... Full Dinan or SS.
Warhaven's 2002 Dinan S2 M5
11/22/04 Dyno: 336.2RHP/329.2T (Exhaust only)
03/15/05 Dyno: 334.38HP/326.24T (+CAI)
06/22/06 Dyno: 348.76HP/331.33T (+ MAF)
Jet Black/Black
Super Sprint X-pipe
AA Front Grill
TC Racing Pedals
TCD Sway bar brackets
MK4 V28.1 NAV upgrade
Zenon 8000K Stage II upgrade
warhaven is offline
Velocity Stack Dyno results are in!!! BretCro E39 M5 and E52 Z8 Discussion 23 14th December 2005 19:10
Velocity stacks question kcdoyle E39 M5 and E52 Z8 Discussion 11 10th February 2005 00:28
Does anyone know how shorter velocity stacks differ from the longer OEM version? FAST 5 E39 M5 and E52 Z8 Discussion 8 17th July 2004 03:34
Velocity Stacks or Flywheel ? jplcbrm5 E39 M5 and E52 Z8 Discussion 4 4th February 2004 18:14
Just received velocity stacks and headers on the way VanM E39 M5 and E52 Z8 Discussion 42 5th December 2003 06:08
Page generated in 0.14534 seconds with 11 queries
