Old 14th October 2005, 09:06   #1
slowcar
slowcar's Avatar
Garage: 2000 m5 blue
carbon fiber intake
I see beast power is selling a carbon fiber upper intake has anyone tried one??
24-28 degrees is quite a bit cooler.
3.91 koala ms quaife diff
supersprint headers, cats, mufflers
aa cold air
power chip 93 gold
rogue shifter
cns flywheel/clutch
rogue pulleys
relocated temp sensor
ss brake lines
schrick cams
ground control coilovers
strong strut brace
zionnsville rad w elec fan
slowcar is offline
Old 14th October 2005, 12:12   #2
Code3M5
Code3M5's Avatar
Garage: M5 Black
Send a message via MSN to Code3M5
Re: carbon fiber intake
I did my research and found Advance Flow Engineering. When I called them they told me they hadn't done one yet, but they offered to use my car for the demo. I went down and got the car fitted and the intake looks really sweet. I'm going next week to have the system installed and put on the dyno before and after. Evosport and Powerchip are going to further the installation with some computer mods and test the car on their dyno before and after. I'll post all the dyno results and post some pictures in the next month. I'm positive they'll get some true rwhp and I'll be there for both dyno tests. I’ll have some real numbers to post on the message board.
John
Code3M5 is offline
Old 14th October 2005, 15:11   #3
mr_bock
mr_bock's Avatar
Garage: 2002 M5, Sterling Gray
John,
Sound like a plan.... hope the results prove positive. Looking forward to your posting when all is said and done.
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
My latest toy... a 2001 360 Modena Ferrari
My 'other' car is a supercharged 1996 911 C2 993
mr_bock is offline
Old 14th October 2005, 15:43   #4
Jayson
Jayson's Avatar
Garage: m5
Send a message via AIM to Jayson
DA discussed this, and its really just a looks mod.
Jayson is offline
Old 14th October 2005, 20:34   #5
Sean@D/A
Sean@D/A's Avatar
Garage: Several
Send a message via MSN to Sean@D/A
Can you be a little more specific.. is this a Grouppe M style C/F intake or just a plenum cover?
Sean@D/A is offline
Old 14th October 2005, 21:45   #6
slowcar
slowcar's Avatar
Thanks for input. Have a great weekend
aa cold air
power chip 93 gold
rogue shifter
cns flywheel/clutch
rogue pulleys
ss brake lines
schrick cams
strong strut brace
slowcar is offline
Carbon Fiber Plenum Covers from D/A Sean@D/A M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 11 17th July 2005 00:36
Element6: GB carbon fiber hood element6 M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 0 2nd September 2004 19:01
GruppeM E46 M3 Carbon Fiber Intake System Technik E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 8 29th October 2002 01:29
carbon fiber intake (cover)??? clauswagner E39 M5 and E52 Z8 Discussion 0 28th August 2002 07:24
Carbon Fiber Look Vinyl Inserts for your Roundels CountZero For Sale or Wanted 4 20th May 2002 09:06
Page generated in 0.11019 seconds with 11 queries
