Old 13th October 2005, 08:16   #1
M5Racer
M5Racer's Avatar
Garage: BMW M5 '02
Short Shifter installed....
I've installed the short shifter, my question is? now it hard to shift into gears! Is that normal and it's more stiff, or do you think there is something going on with my trans?
M5Racer is offline
Old 13th October 2005, 08:43   #2
bmwusa
bmwusa's Avatar
Garage: Waiting?????
Re: Short Shifter installed....
I dont know if hard is a correct description, but yes with a short shifter there should be more effort per say to throw the gears around, but as your shifter breaks in it should get a little better, give it a week and see if you still think it is difficult, I have a feeling you will adjust and like the new feel, but who knows maybe its just me, Josh
1/2 of the Southern Renegades....
I just love the smell of JP-5 in the morning
bmwusa is offline
Old 13th October 2005, 17:05   #3
TCM
TCM's Avatar
Since you are changing the angle on the shifter to make it shorter, you are going to have to use more power to acheive the shift. It is normal and will loosen up with time. Nothing to worry about. Hope this helps.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Old 13th October 2005, 19:34   #4
M5Racer
M5Racer's Avatar
Garage: BMW M5 '02
I will give anther week of so - Will keep you posted. Thanks
M5Racer is offline
Old 13th October 2005, 19:46   #5
Jayson
Jayson's Avatar
Garage: m5
Send a message via AIM to Jayson
Give it time, but in the mean time go to the gym
Fluids can help, but the getrag gearboxes are known for being stiff and the short shifter just brings this out more. You did the DSSR as well correct?
Jayson is offline
Old 13th October 2005, 20:08   #6
bimmer23
bimmer23's Avatar
Garage: 03 Titanium Silver M5
Got mine installed last week and I must say I love it. I on the other hand love the notchy feel. I really don't want it to get to loose or to easy to shift.
  • 08 GL 320 CDI (wife's car)
  • 03 M5 Titanium Silver; Grey/black Interior
    Mods:
    • Active Autowerke cold air intake w/ Brake Duct Cooling
    • UUC Evo III Short Shifter Kit w/DSSR
    • Supersprint Exhaust System
      • X-center pipe
    • IATS Relocation sensor
    • ShadowTech” DME reprogramming (i.e PowerChip 93, DA tuned)
    • Valentine V1 (hardwired
    • StealthOne display
bimmer23 is offline
Which B&M Short Throw Shifter to install...? chrisw E39 M5 and E52 Z8 Discussion 3 12th May 2005 00:37
New UUC clutch and Short Shifter cstucker1123 E39 M5 and E52 Z8 Discussion 1 11th April 2004 17:38
B & M short shifter TigerM5 E39 M5 and E52 Z8 Discussion 5 4th May 2002 07:04
UUC vs Rogue short shifter comparison Oak E39 M5 and E52 Z8 Discussion 15 2nd January 2002 04:02
Page generated in 0.13892 seconds with 11 queries
