Re: AutoTap ODB2 Software
I have one and have used it a few times, but I use the Peake much more often. The AutoTap is good if you want to graph/record various parameters (I used it to map MAF vs. engine RPM and intake air temp when testing the IATS relocation). However, if you want something that's small, easy to use and, I believe most importly, gives you BMW-specific information regarding OBDII codes and not just generic OBDII info, you can't beat the Peake. I keep it in my car.
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
