COMPLETE WATER PUMP FAILURE - BMW M5 Forum and M6 Forums
post #1 of 8 Old 12th October 2005, 07:40 PM Thread Starter
oto60
My beast will be in the shop for over a week. Had a complete water pump failure. Was driving home the other day and noticed the check coolant level indicator come on. Didnt think much of it. Parked the car in the garage and then an hour later went to check on the beast. The garage was full of COOLANT. Freaked out... Had the car towed to the dealer. Thank God for CPO.
Is this a common problem with the E39 M5's???? The car only has 21,000 miles. Any idea? Anything else I should have them look at since the car is already beng taken apart??? Any information would be appreciated. Thanks.
oto60 is offline
post #2 of 8 Old 12th October 2005, 08:41 PM
Hobbez
Hobbez's Avatar
Re: COMPLETE WATER PUMP FAILURE
Had mine go at 56k. Replaced along with radiator. Evidently the pump failing is a semi common thing.
Hobbez is offline
post #3 of 8 Old 12th October 2005, 08:51 PM
M Macht
M Macht's Avatar
With E39's, I've read that water pump and/or radiator failures are common (around 60-90K miles) and should be prophylactically replaced when that mileage is reached. 21,000 miles seems awfully early for this to occur.
Nick
2001 E39 ///M5: Imola Red/Caramel/Walnut
Dinan Cold Air Intake
Dinan High Flow Mass Air Flow Meters
Dinan Stage 3 Software
Dinan Exhaust
9.5x18 inch OE Rims On All Four Corners
275/35 Michelin Pilot Super Sports
Brake Ducts and M Technik Splitter
UUC EVO3 Short Shifter and Double Shear Selector Rod
Rogue Transmission Mounts
BeastPower Sway Bar Brackets
Valentine One and Stealth One
Titanium Pedals
Angel iBright V3.0
Sylvania Silverstar High Beams and Fog Lamps
Platinumvision 2.0 Bulbs
Tinted Windows
"Spare" 8x18 inch OEM Rim and Tire With Jack and All Trunk Lid Tools
M5 Trunk Mat
Trunk Storage Bin
M License Plate Bracket
2010 Porsche Cayman S
Too much horsepower is never enough.
M Macht is offline
post #4 of 8 Old 12th October 2005, 09:28 PM
Amjad Ali
Amjad Ali's Avatar
I have been lucky enough to have run bmw's since I was 19, and also have a big brother who is a mechanic.
He always told me the weak point of a BMW engine was the water pump. Anytime i bought a used one he would always change the water pump for me. He always made sure I changed them every 40K miles.
But 21K is way to low.
Amjad Ali is offline
post #5 of 8 Old 12th October 2005, 10:16 PM
TCM
TCM's Avatar
The cooling systems on BMWs are their weak points. Usually not untila round 60k before you need to worry about it though. Not a huge job, and be glad that you got the car home without overheating it.
T.C.
'01 Brushed Steel M5
front splitters
3.45 differential
'01 Silverstone M5- sold
SuperSprint:X-pipe
TCM is offline
post #6 of 8 Old 12th October 2005, 10:26 PM
MariettaM5
MariettaM5's Avatar
I changed mine at about 75k miles. It didn't fail completely but had started to leak around the bearing and was getting progressively worse.
MariettaM5 is offline
post #7 of 8 Old 13th October 2005, 12:21 AM
verhagke
verhagke's Avatar
most water pumps are designed to leak slowly once the bearings start to fail. This way you will notice an issue (low coolant level, coolant in engine compartment) before it becomes a significant problem.
verhagke is offline
post #8 of 8 Old 13th October 2005, 03:49 AM
robluvs2xlr8
robluvs2xlr8's Avatar
Water pumps seem like a common things in V8's.
My LS1 V8 camaro had a water pump failure also. at around 44000 miles
-2007 BMW Z4 M Roadster
(Interlagos Blue / Black)
stock
-1992 Honda Civic LX
(White / Tan)
30mpg
-2001 BMW M5
(Royal Red / Caramel)
-Sold-
robluvs2xlr8 is offline
E39 M5 2001 Complete Engine Failure! benragan E39 M5 and E52 Z8 Discussion 18 13th October 2005 12:26 AM
Straight from BMW on recent delays Gustav E60 M5 and E61 M5 Touring Discussion 37 4th July 2005 07:52 PM
water pump problem dalius E34 M5 Discussion 7 8th May 2005 04:25 PM
Seized water pump Ian E34 M5 Discussion 6 28th October 2001 01:10 AM
Electric water pump to increase HP RYAN E34 M5 Discussion 5 25th September 2000 09:25 AM
