• Latest threads
    • Custom feed
      • News
        • Updates
          Old 11th October 2005, 04:30   #1 (permalink)
          tmlesko
          tmlesko's Avatar
          SES light on, "Secondary Air Flow Low" Fault
          I recently had the SES light on, with the "Secondary Air Flow Low", fault code "AA" on the Peake Research Code Reader, a different # for the dealer's code reader, apparently those may be PO410 through PO419.
          I am starting this thread because I first thought, and the service advisor at the dealer told me, that the secondary air pump and shut off valve need to be replaced. Then, after reading the "Poll on Carbon Build-up Issue - All Members Please Read" thread and the " FAQ on Carbon Build-Up Issue (First Attempt)", especially the next to last page where LLcoolM5 documents his DIY repair, that it may not be the pump but rather a blocked secondary air tube and possibly gummed up valve as well. If you are experiencing the SES light and "Secondary Air Flow Low" fault, please read those 2 threads prior to having the dealer just replace the pump. If the pump is not making a loud noise on cold start-up (pump is in front of the passengers front tire) then it may very well be good. Try the tube cleaning approach before having the dealer clean your heads for $8k, or fighting them for a "good will" repair or having them replace the pump and valve only to find out that your SES comes back on a couple days later.
          Just my 0.0166243 EURO's.
          Tom Lesko
          Hingham, MA usa
          tmlesko is offline
          Forum Jump
          EML (SES) light on and off GTRPaul E39 M5 and E52 Z8 Discussion 0 31st May 2005 19:20
          Question for guys that have Dinan CAI & air flow meters or anyone knowledgable....... FAST 5 E39 M5 and E52 Z8 Discussion 61 31st December 2003 15:45
          My SES light saga continues... BostonRocket E39 M5 and E52 Z8 Discussion 16 18th May 2002 18:05
          TECH: SES light on... BlueBomber E39 M5 and E52 Z8 Discussion 5 9th May 2002 18:21
          SES light: DME returned from Germany ALX E39 M5 and E52 Z8 Discussion 12 6th April 2002 09:04
          Page generated in 0.20351 seconds with 11 queries
