Old 12th July 2000, 08:35   #1
alpywhite
alpywhite's Avatar
Garage: 2006 BMW M5, Silverstone
M5 Deficiencies - A Recap
How about taking a moment to form a consensus on common E39 deficiencies to date, so that we can complain to our respective dealers en masse and get the recall machine rolling. I'm sure I've overlooked plenty; please feel free to contribute. I'll compile a final in a few days.
- Outside temperature sensor
- Real wheel well / tire problem
- Sporadic nav system performance
- Vanos noise at idle
- Titanium shift knob flaking
- Initial oil consumption in general
Alps
alpywhite is offline
Old 12th July 2000, 11:04   #2
Holger
Post
I agree nearly with your list. I got a dozen other major problems in addition. But here're my 0.02$ on your topics:
This is an general issue were BMW will be unable to solve. They already positioned the sensor itself at the best position they could find, but the engine just heaten everything around.
What do you mean by this???
BMW should have already send an internal technical letter to the dealers to exchange this. My Vanos will be exchanged for free next week.
This is an known issue and has been resolved by BMW. Kick your dealer to exchange it for free to the new part.
All M models have kind of race engines inside and all of them are eating oil during the first 5000 miles. If you want a sport car which doesn't eat oil, than buy an Porsche.
Holger is offline
Old 12th July 2000, 15:25   #3
SteveP
Post
Here're my nits to pick.
Pronounced "whine" under light acceleration. To hear it, close sunroof and windows. turn off stereo. drive in any gear from 4th to 6th, depending on road and speed. let off throttle and coast, then just lightly apply throttle.
Rear seat armrest pops down if you drive with sunroof and windows open, and ski sack unfurls into car.
SteveP is offline
Old 12th July 2000, 17:53   #4
KKelly
KKelly's Avatar
Garage: 91 M5 Alpine White
Post
Is the whine a problem or just engine noise? My old M whines also and I once had a passenger ask if it was a turbo. Another E34 owner had his friends nickname his car "the jet." Personally, I love it.
KKelly is offline
Old 12th July 2000, 18:06   #5
MEnthusiast
MEnthusiast's Avatar
Garage: 03 M5
Exclamation
Good idea. Here are my thoughts
I have this "issue" also. I agree, this might be completely unfixable since the car makes a lot of heat- after a 20 minute drive, when I get out I can feel literally a nice "ploom" of heat around the car. Well, at least in winter the car will say its like 80 degrees!
Ive read about this, but I have yet to experience it. I had a full car yesterday and even going over bumpy roads I did not notice this.
Have not encountered this at all.
Vanos noise at idle
Ive got the diesel sound also
dont know as I have the wood.
I think this is something all M engines will do.
heres one Ill add:
correct tire pressures
the door says one thing, the manual says another, and the dealer says yet another. Who is right?
ME
MEnthusiast is offline
Old 12th July 2000, 18:42   #6
alpywhite
alpywhite's Avatar
Exclamation
NB that these are issues I've scanned and compiled from the board and not problems with my car...I only mention them because of their apparent consistency.
Alps
Old 12th July 2000, 19:59   #7
SteveP
Post
I think the whine sound is a problem, as the car didn't make the sound at all until after 3000 miles. If your car were doing it, you'd know. It's definitely NOT normal engine sounds (although it is coming from somewhere in the drivetrain, neither I nor my dealer could find it). It has been reported to BMWNA, and they've had other reports of the same sound, but no imminent fix.
SteveP is offline
Old 12th July 2000, 20:49   #8
D.Wiggs
Post
I had the aluminum coating flake off but my dealer replaced all of that for free since BMW made a production change to solve the problem. Also, I had the car's timing in the 5th cylinder screw up which caused the engine to work against itself, luckily I was only 500 yards from my dealer when this happened. I do have the diesel soudn but thought that that was normal for the car, and as for the oil consumption, the technicians at the BMW performance center said that the pistons are designed slightly smaller than the block so that when they expand and settle over time, a perfect fit will occur and engine damage will be avoided.
D.Wiggs is offline
Old 13th July 2000, 02:22   #9
Anzir
Anzir's Avatar
Garage: Silverstone 2000 M5
Post
My fellow M5ers and I asked most of these questions at the Spartanburg program, and here are the answers I got:
Oil consumption: exactly what D. Wiggs said.
Diesel sound: normal. This was beautifully described by Richard, the head technician at BMW NA, but here's my poor rendition: Caused by the fact that the head of the piston (which is smaller in length than normal design) has room to slightly vibrate while running, and the sound will vary from car to car, based on the intricacies of the specific engine and how the piston is seated. There is nothing wrong with it, and it might go away after the engine has "aged" properly, but if it doesn't, there's nothing wrong with it.
Tire pressure: Maximum pressure is recommended.. 44/48 I think.. not positive, but whatever it says on the tire.
Titanium: the cars that I saw in Spartanburg were all flaking on the knob, and I have heard they replace these with new ones. I have wood as well, so I can't comment on my car.
Haven't had any trouble with the nav system.
I haven't tried listening for the whine yet, but haven't heard anything as of late, and I am quite nit-picky about how the car feels and sounds.
Hope that helps somewhat.
Anzir is offline
Old 13th July 2000, 02:52   #10
MEnthusiast
Garage: 03 M5
Post
The thing about the pressures is this:
the tires say "max pressure=51psi"
the door says "44/48"
the manual says "35/38"
my dealer says "32/39"
so whats right? I tried 44/48 and thats too high- I can see the tire wear is not across the entire tire surface. I decided to kind of average these to 40/42. The front seems right but the rears still dont have wear to the edge- its about 1/2" from the edge.
Ive always been of the mindset to use the pressures on the door, but when I called BMW NA, they even couldnt give me a straight answer.
ME
Wooo tfung gone off deep end... EBMCS03 Off Topic Forum 4496 22nd November 2009 09:15
German AMS magazine tests M5 suspension kits lofstrom E39 M5 and E52 Z8 Discussion 25 11th April 2008 13:24
Rumours about the E39 M5 pre 1998. Gustav Most Memorable Threads' 13 13th August 2002 03:29
Page generated in 0.17347 seconds with 11 queries
