Installing Android touch widescreen 10.25inch NAV into E39 M5
20K views 21 replies 10 participants last post by  Bmwe39528i
#1 · (Edited)
This is a post for discussion and food for thought on upgrading Navigation systems.
Looking at a way to really 1-up and modernize our navigation systems.
The coolest answer so far is to install the NBT-based system into the E39. Such as the one below.
This features a full wide screen and no buttons, giving a look that competes in year 2020.
Cons of NBT:
  • Touch-screen is unavailable.
  • People say the NBT web-browser works poorly due to low ram on NBT system.
  • Typing into keyboard using BMW's iDrive button is real hassle
  • Can't run apps such as Torque
For a full size screen with no buttons there are couple options, that I came across:
1st option: Smarty Trend
BMW 5 Series E39 Android Car Stereo Navigation In-Dash Head Unit
This unit appears to have the X5 bezel and no DSP functionality. .
DSP:
To fix the DSP/OBC/iBUS functionality there is Resler interface & iBus app
The idea is that the Resler USB interface wires to iBus, and plugs into the Android unit USB port, and the iBus app can then talk to iBus and control DSP and OBC functions.
Question is when the Resler iBus interface controls DSP, if it will also send audio signal to amplifier. Maybe someone has input on this?
Bezel:
I am considering 3D scanning the E39 standard bezel and the one that comes along the Smarty unit, then use both to construct and 3D print a proper fitting one for E39, so it looks stock, not like the out of place X5 bezel.
2nd option: Avin Android 10.25 for F16 retrofitted into E39
There is another idea I have to take the Avin Android 10.25 inch system for F15 or F16. Pictured below:
https://avinusa.com/10-25-bmw-x5-x6-series-f15-f16-android-multimedia-navigation-system.html
and remove the bezel completely, and create custom bezel with 3D scanning and printing. This would integrate a 10.25inch display and Android system into the E39, (same as the NBT system displayed above) making it look like the E39 M5 is yet to roll out of assembly line in year 2020.
Things to still needing research on fitting an F16 type unit into E39:
Sound quality:
DSP- Maybe someone has knowledge if the Resler interface and Android App can send audio to DSP amp from this Avin unit shown above. This would eliminate the need to re-wire the sound system.
Aftermarket sound - There is the idea to replace the entire DSP system with a high end audio system, but since these aftermarket Android units are cheap electronics mostly, it would be important to get the sound digitally to a high end aftermarket amp/processing system.
Maybe someone here knows some good solutions for this, such as digital signal chord to amp from unit, optical audio?
Steering wheel controls-
How is steering wheel button being controlled? Would the Resler App cover this function and connect wheel and Android system?
Wiring - What wiring issues arise from installing the 10.25 F16 unit into E39?
If you have any good solutions on above questions/issues, please speak up :)
P.S. another good thread covering Android aftermarket unit install with lots of good info:
http://www.m5board.com/vbulletin/e3...m5-e52-z8-discussion/586378-xtrons-pb7639bp-android-head-unit-installation.html
#2 ·
Although NBT is really nice, I'd put Android system's first. Sure, I know they're Chinese and of questionable quality but they are by far the best in terms of cost, programmability, flexibility and upgradability. I'm pretty sure most Android unit have the same rear pinouts but just use different adapters for different cars, so you probably can get the Android unit for the F10 or whatever and use the E39 harness and Canbus from another android unit. Hopefully. That's been the case with me so far. The ease of upgrading these units is so nice. Just wait a few years, and buy the next best thing if you want by swapping out the old headunit and plugging in the new one. Rear camera, audio, microphone, GPS, controls, all transfer over seamlessly. It's nice being able to rip the car apart once and be done with it for the rest of the car's life. Along with Resler, the integration of Android units is a no brainer. I almost feel sad for those guys that invest $1000+ in NBT when Android systems will definitely outlast them in the long run (wait a year after a Android system comes out and they're less than $100 on eBay! You can constantly upgrade 10 times!). Now they're even coming out with iDrive controls. Talk about blatant copying...
#3 ·
Hi TB,
Following on from your other thread response !
In addition to the cons of the OEM NBT retrofit, there's the large cost factor, the OEM level of audio sound quality and the increased likelihood of issues/problems as mentioned by those who've done it on the bimmerforums thread.
Onto the 2nd option which is the cheap chinese units with the widescreen - 'Smarty' and 'Seicane' and perhaps other branded clones make these types of unit. As per the other thread, you won't find high(er) end features like optical out or high quality electronics internally. These are the same basic units as the other clones but simply have a wider 9 inch display on the front.
Onto your 3rd option. I think this one won't work as the protocols the unit uses are the same as used in later BMW's. The E39 doesn't have that protocol, so unless you wish to develop an interface then this idea won't go forward.
The Resler Interface takes the wire from the iBus and 'converts' it to a USB output. I don't think it has the capability to control the OEM DSP amplifier. Perhaps email into Mr Resler to ask. To this day, many BMW owners still ask about audio head units to say 'will it work with DSP'. DSP for church and stadium effects went out of fashion by the late 90's. Also over the years, physically, there's more of these DSP amplifer units that are failing and there's no 3rd party electronics specialists who fix them as BMW didn't release the schematics or components list externally. If you *must* keep the OEM DSP amplifier with the medicore DSP speaker drive units, then look to buy the Dynavin N7 or Avin Avant 3 if you want to stay with a chinese unit. IF you don't mind ditching the OEM DSP amp, then you can get a high quality head unit, a 5 channel amplifier, excellent 2 way component for the front, entry level 5.25 inch co-axials for the back and a 8/10/12 inch subwoofer in it's own small sealed enclosure that sits against the rear seat bulkhead and fires the output from the sub through the ski hatch. This setup will sound a LOT better than the the other routes. I'll drop you a PM soon !
BavarianE31 - The aspects of programmability and flexibility don't mean much when many of these chinese units themselves aren't reliable enough to work properly for longer term use. a 'handful' of owners have got fully working units that have continued to work longer term. A big proportion of purchasers didn't get that at all and experienced all sorts of issues/problems and frustration and this is before we get to the sound quality of them!
Cheers, Dennis!
#6 ·
Hi, There's a very long and in depth thread over on bimmerforums that shows and has feedback from those who've done this OEM NBT retrofit project. Whilst some owners have reported back all seems to be working well/ok, there's plenty where various aspects aren't working or aren't working as well as anticipated.
Here's the thread - https://www.bimmerforums.com/forum/showthread.php?2153382-NBT-CIC-CCC-retrofit-in-E39-E38-E53
If you decide to go along with this project, please do create a thread about it, the install and your findings etc both when it's initially done and perhaps over regular quarterly intervals to get your feedback for it longer term.
Personally, I would love the NBT retrofit if it could run a few select Android applications, chiefly among a few, a navigation application. I could get past lacking that ability, however. I abhor touchscreens in any vehicle and find the iDrive controller very easy and intuitive to use although the location shown above seems awkward in the E39. For me, the only real negative is the eventual obsolescence issue that will always plague OE solutions.
I'd gladly ditch DSP, install new amplifier(s), retain the M Audio subs and install one of these Android head units. They naturally work well with Bluetooth and Apple products, have updated GPS maps and are flexible. For the E39 and even more so for the E70, being locked in to a touchscreen is a non-starter for me. Fortunately, the E70 already has an iDrive controller that these units work with but for the E39, I'm not sure how one could be integrated.
I would pay a few thousand dollars for a proper Android-based head unit with separate controller.
The E70 OEM modules don't work directly with the E39, you'd need to go with the NBT retrofit as per the link above. If you mean there's a chinese unit for the E70 that works directly with the E39, could you link to which that is ?
The M Audio subs are sort of alright but don't provide solid, powerful, musical and actual 'musical' sub bass, and are thus easily outperformed by high quality aftermarket subwoofers. Trying to drive the M Audio subwoofers with quality aftermarket amplifiers is more of an issue as the M Audio subs only handle a paltry 70 W RMS I think it is, of audio power. You can of course turn the gain and bass levels right down on such an amplifier in the hope the M Audio drivers voice coils don't get overheated - but that of course is negating the point of using quality amplifiers. As for the chinese head unit's themselves, many owners who mention on various forums that they have the latest 'functionality' conveniently forget that it's the level of reliability and performance which is integral to the user experience. It's very well documented that these chinese units on the whole are low quality, pumped out en masse from perhaps 4/5 low grade electronics factories in China and have a high failure rate with little or zero support from the bedroom seller in Hong Kong that sold it to them. The brands that try and make out they're a larger outfit similarly don't help out those customers with issues and why they've been kicked off forums when they're called out. If you do wish to take the 'gamble' on a chinese unit, by all means do so, however do keep in mind that it's a higher chance that soon'ish you'll wish you hadn't bothered. Lastly, for the E39 community, there's very very, very few owners who want a 'idrive' like controller fitted in order to control the head unit. Those who don't mind and who have very deep pockets like yourself will/have done the NBT retrofit and the fabrication work required to make it a clean looking install. In the high quality aftermarket car audio world, things are moving to more integrated solutions ready for 5G communications coming in the next few years and I'm speculating a bit that voice and gesture control will become more prevalent.
Cheers, Dennis!
#5 ·
Reactions: Hdhntr23
#14 ·
Did you notice the carbon fiber steering wheel Josiah???
LOL
Reactions: josiahg52
#7 ·
A couple thoughts in no particular order:
- Touch screen as the only means of control seems questionable from a user interface perspective (to me at least). While we're all used to our phones/tablets not having physical buttons, trying to manipulate a touch screen while driving is easier said than done. I don't use all of of the hardware buttons on my Android unit, but the ones I do use (Home, back, volume, mute, etc) - I use frequently.
- The NBT works well because of the iDrive controller, which I've always found very intuitive to use in the newer BMWs I've driven. I believe there are a number of similar devices available on aliexpress & ebay, which connect via USB or wireless. The trick here is having application software which is usable with the knockoff iDrive controller. The BMW NBT software was developed with the iDrive controller in mind - Google Maps (for instance) was not. If you have to spin the wheel 3x around & press the button 20x to get to the Google Maps menu you want - I'm not sure it's a viable means of control while driving. I guess my point here is: keep in mind that nearly all of this integration is a 2-piece affair - hardware & software. And very little of it will be plug-and-play, so if you're not well versed in hardware & software manipulation - you may have a long road ahead of you.
- Steering wheel controls are handled via the "CAN Bus Interface" box that comes with most BMW-specific Android units. Although it's a somewhat redundant connection, it's completely separate from the Resler interface & iBus app
- Just to clarify a couple comments above: Mr. Resler simply manufactures a means to connect to the BMW iBus network. His interface has actually been around for a very, very long time - first as a RS232 serial interface and more recently USB. The reason most haven't heard of it is that there was no software available to really do much of anything with it. You had a couple laptop-based software options (NavCoder being the most common) or you wrote your own software using a Raspberry Pi or something like that. Not exactly basic level DIY stuff. Now that you can easily install an Android tablet in your dash & Adrian has developed the iBus app - you have a lot of options at your disposal
- DSP: People should be keeping DSP for one of 2 reasons - cost control and/or ease of installation. If sound quality is a big concern, there are exactly zero reasons to keep the factory DSP amp & speakers.
- I believe audio is not transmitted via the iBus network, just controls for the amp. The Android head unit extension plugs in place of the stock radio, so I can only assume that audio is input to the amp just like it would be stock.
- Dynavin is still the only natively compatible DSP system on the market, although the functionality is limited. Avin uses the Resler/iBus combo, which provides more functionality than Dynavin, but it's still not perfect. Sound quality is good enough for my uses, but if SQ was a bigger concern I'd just dump the amp & speakers and go aftermarket.
#9 ·
A
If Avin uses the Resler/iBus combo, but works with DSP... there must be a signal. I will check on this further.
#8 ·
Hi,
For those 'concerned' about using a Touchscreen head unit in the car;
When I went for a head unit in my E39, I initially went for the first 'shallower' depth Alpine iLX-W407BT unit. It had a row of hardware buttons along the bottom edge which controlled volume, track/station up down and settings menu access and direction arrow ones. It was a mix of using those mainly for volume and the rest was on the touchscreen. I found it extremely easy and most importantly, very quick to use. A quick prod on the volume buttons was all that was needed - meaning keeping eyes on the road was much easier. If wanting to change aspects whilst driving, then the glance away from the road for me, was again quick and simple to revert back. I found almost zero cause for concern that it was/had a touchscreen interface.
I then moved over to the Parrot Asteroid Smart the day it had it's official UK release. Fitment was better as it's shallow depth was much better than the Alpine 407. This unit has no physical hardware buttons on the front giving it a very clean and uncluttered look. In practice and use, I found it very very easy to use when driving. A 'swipe' up on the screen, just like when using a smartphone, adjusted the volume up/down - zero time for eyes off the road. Another way was to touch the screen for a second or so and a volume slider bar appeared which could then be moved left/right for volume. Again, this was very very easy and simple to master in a very short space of time so when/if being used whilst on the move, it quickly became second nature.
I personally don't need to play games or have loads of apps on my head unit, nor watch video/tv all whilst driving. I simply connect both my phones to the unit for phone calls, and when I wish to listen to the radio, I use the free TuneIN app on one phone with unlimited data, and stream via bluetooth the station I want. Other times I'm listening off my ipod or sometimes will BT audio stream.
A combination of the above brings me to a main point. For those who *must* keep the OEM audio then those who add things like the Intravee for ipod control and when inputting address details on the Navigation, must take their eyes away when from the road for longer due to the amount of twisting of the rotary control knobs on the monitor unit, the 'prodding' to select a letter or number and then having to repeat it all many times to select numbers/letters/characters. This is far more 'risky' nowadays given the more numbers of cars on the road today compared to 1997/2000 when these OEM units began to appear in E39's. The various western countries have standards for driving and potential distractions whilst doing so. The 'idrive' type interface is still within guidelines as to what is legal and acceptable and thus, aftermarket unit's are also within those standards with touchscreens. The older OEM units I think are more (most) distracting nowadays.
Cheers, Dennis!
#17 ·
TB Thanks for the writeup.
I have the similar considerations. Agreed the NBT retrofit looks beautiful installed, but I would never want to install an iDrive based solution. The cost is over the top, and by 2018 we got used to touchscreens.
So I would definitely opt for a touchscreen based solution, with a similar look to the NBT and yes the SMARTY looks like it could be a solution. Unfortunately I watched a youtube install video of the product and it ended up looking really cheap... possibly because of the frame?? Maybe the installer used the X5 frame? Also the screen glare looked awful...
We need a high end product that can be retrofitted. I will stay tuned to this channel :)
Regards J
#18 ·
Sorry for posting in 2 threads.
This thread is more appropriate but I only found it after posting in Avin 4 thread.
So basically Avin released the E39 10.25 screen. It looks awesome on the pictures but not sure if anyone tried it yet?
Not sure when it was released either
10.25" Multimedia Navigation System for BMW 5-Series E39 / M5 Model: HHPX5801025E39
#19 ·
Hi Bmwe39528i,
Now where do I recognise that name from ?!
This unit is the same as the Avant 4 but with the larger screen attached to the front. If you are thinking about buying it, just research more about feedback from Avant 4 owners, check the E46 Fanatics forum and the audio sub forum where there's a few threads about them and then make a more informed choice. If you do buy it, put up a review and then update over the next 3/6/12/24+ months :)
Cheers, Dennis!
#20 ·
Hi Dennis :)
You got me lol
I've already looked into reviews for Avant 4 and they were quite satisfactory to me.
If I'm to expect the same quality on this screen, I'll be getting it.
If I order through Amazon, that should give me an option to return the unit in case it doesn't work well.
Since I got that pesky DSP system I need to run an extra wire to the trunk of the car.
That means getting under the carpet. I will combine the installation together with adding rear foglights as they also need to be wired from the front to the trunk.
I won't be doing that right away as I need to finish my wheels first but I will definitely post a very thorough review once I get it installed.
#22 ·
Do they work with DSP?
I found a couple of options, seems pretty cheap
I'm just trying to figure out which unit to buy that will work with DSP system.
Avinusa and Xtrons were selling them for some time as well. Avinusa is not selling the 10.25 screen for e39 anymore for some reason, after selling them for a very short time.
This unit has great reviews on aliexpress
