Tips for changing spark plugs on E39 M5 - BMW M5 Forum and M6 Forums
 12Likes
post #1 of 45 Old 11th September 2005, 03:41 AM Thread Starter
jaj
jaj's Avatar
I did a change today and there were a couple of things I figured out that made it easier.
1. Get a 1/4" drive stubby flex-head ratchet. The one I picked up is about 4 inches long, and it made the job SO much easier!
2. All of the screws and nuts for the cover, the electrical harness retainers and the ignition coils are 10mm. It's the only size socket you need for that part of the job. You will find that having a deep socket and a regular socket is helpful. If the deep socket is a 3/8 drive with a 3/8 to 1/4 drive adapter, that's even better.
3. A standard "small" spark plug socket works fine. You need one with a rubber insert that will hold a plug and not drop it, and that won't come out when you pull it off the back of the plug after installation.
4. You need to have a long extension for the spark plug socket - I used a 9" and a 12" together. Use the "wobble" kind from Craftsman - you can't get a straight shot at any of the plugs, but the angles you need are small.
5. The existing plugs are tight. Use a long handled ratchet or breaker bar on the long extension to crack them loose. They'll unscrew easily after that.
6. Use a torque wrench to tighten the new plugs. 30 N-M is the spec, and if you use BMW spark plugs, the torque is on the box.
7. Do the driver's side first. It's the most challenging (it's not that hard, just tedious) and so you should get it out of the way first.
Disassembly instructions:
Starting on the driver's side, pop the cabin air filter box off (I won't provide instructions, but it's easy - same process you use to gain access to the brake master cylinder). Rotate the cabin air intake air snorkel toward the engine to make a little more room. Don't remove the snorkel, you don't need to.
Undo the two cap nuts that hold the cover on. This will be your first opportunity to use the stubby 1/4 drive ratchet. The rubber bushings around the nuts and the washers are all separate and loose, but they stick together from the heat. Don't drop them when you take it apart. Pull the cover loose from it's gasket and slide it forward and out.
Undo the two nuts that hold the wiring harness for the coils. I cracked withm with the stubby ratched and a socket, and then used the 3/8 drive deep socket as a nut-driver to remove the nuts. Using the socket allows you to turn the nuts without the risk of dropping them.
Pull the harness away from its studs, and then remove all 8 nuts that hold the coils in place. Again, each one will have a different challenge because of the cramped quarters. I used the stubby ratchet and a socket to crack them, and then used the deep socket as a hand tool to remove them.
Once the coils are loose, but still in place, use a screwdriver blade to pop the shiny metal brackets on the coils up. Slip it into the slot below the bracket and twist gently - the brackets lock the connectors, so pull the brackets up as far as they'll come (about 1/2 inch or so) and then gently pull or push the black connector off toward the rear of the car. They're EASY to take apart, so you shouldn't be struggling with them. Starting from the front of the engine (Cylinder 5) undo the connectors and grab the coils under the "ears" that go over the studs, and pull them out - again, you can be gentle because they come out quite easily. I took all four out and set them aside.
At this point, you're looking at the four spark plugs deep (really deep - remember the 21 inch extension?) in their openings in the cylinder head. Using the long extension, remove the old plugs and screw in the new ones. Torque to 30 newton meters. This is the easiest part of the job!
Once the plugs are changed, put it back together in the reverse order to taking it apart. Install the coils from the back of the engine to the front. The way I did it, I slipped the coil back onto its studs and did up the electrical connection. The push down on the bracket to lock the electrical connection also seats the coil onto the top of the plug.
Once all the coils are in and hooked up, put all the nuts back on the coils and tighten them. Then reposition the wiring harness and install the two nuts that hold it in place.
With all the wiring, coils and plugs back where they belong, it's time to put the outer cover back on.
On the driver's side, but not the passenger's side, you will have to wrestle with the rubber sealing boot where the wiring harness enters the outer cover at the back near the firewall. On the drivers side, the brake lines keep the cover close to the head, and you have to coax the rubber boot, which has a slot in it, to pop into the corresponding opening in the cover. The natural tendency is for the "top" to slip in nicely, and for the bottom to firmly resist going back into place. The trick is to push the top of the boot back and seat the "bottom" and then wiggle the top forward into place. That works!
On the passenger side, there's enough room to just pull the cover back and slip it over the boot. No struggling required.
Anyway, once you have the boot properly seated in the cover, put the two cover cap nuts back on and tighten them. They bottom, so torque them gently after they stop turning and you're done.
Now do the other side. There's more room on the passenger's side, so it goes quicker with less contortions.
Total time - 1.5 to 2 hours.
jaj is offline
The Following 10 Users Say Thank You to jaj For This Useful Post:
-BEASTMW- (11th April 2009), Fatman76 (14th January 2016), MasaK (14th December 2012), NoMoreAutomatics (25th April 2013), OldDawg (14th January 2016), Phil M5 (30th April 2011), Redshift (18th January 2011), Scott the Pict (30th March 2011), Ted (27th February 2009), TimInNOVA (21st September 2010)
post #2 of 45 Old 2nd December 2005, 01:46 AM
KBK
KBK's Avatar
Re: Tips for changing spark plugs on E39 M5
I think this one should be in the FAQ.
KBK is offline
post #3 of 45 Old 22nd February 2006, 09:24 PM
DavidS
Moderator Emeritus
DavidS's Avatar
Excellent write-up. I agree, it is definitely FAQ quality!
I want to add this:
1. Remove snorkels.
It can be very difficult to get the rubber grommets found at the rear of the spark plug covers in thier places during reassembly, unless one completely removes the snorkels. Doing this right at the beginning makes more room for working too, and on the whole saves time.
When removing the snorkels first take a flashlight and get a good look at how those are seated against the wall towards the passenger compartment.
2. Pay attention to what spark plug comes from what cylinder, and save the old spark plugs.
The cylinders are numbered from 1 to 8 as follows:
Front of car
Left side - right side
Cylinder Bank 2 - Cyliner Bank 1
5 - 1
6 - 2
7 - 3
8 - 4
Rear of car
The reason for keeping track of the old spark-plugs is it can later provide important information to a person who knows how to "read" spark-plugs, if the engine ever develops a problem.
Also it is good practice to put the coils back in the same places those were.
Cheers,
David
DavidS is offline
The Following 4 Users Say Thank You to DavidS For This Useful Post:
Redshift (18th January 2011), rroberrto (6th June 2011), Ted (27th February 2009), Terabass (28th May 2014)
post #4 of 45 Old 20th April 2006, 05:21 PM
simonpa77
Useful post - thanks. I just did mine. It certainly helped the driveability when cold (no juddering/kangaroo-ing).
Can I add that you don't need to remove the coils. Just undo the nuts on the coils and the extra bar holding the earth wires. Then, gently pull the coils away from the head until the pop off the spark plugs. Twist them slightly and lay them back in place, but not over the spark plugs. There should be plenty of room to get at the spark plugs to remove/replace them now.
The whole process took me under an hour. Fiddliest job was getting the rubber seal at the rear of the cover to stay where it's meant to be. I noticed it hadn't been put back in place when it had rocker gaskets changed under warranty last year...
Good luck!
Simon
simonpa77 is offline
post #5 of 45 Old 20th April 2006, 06:06 PM Thread Starter
jaj
jaj's Avatar
Thanks all for the appreciative noises - it's an easy job, but there are few lessons that I learned on my first try that make it easier for the rest of the DIY types like me.
The LH (driver's side) rubber boot is the trickiest part, for sure.
On my first try, I did it the obvious way, I put the boot into the opening on the cover (top and sides) as I was putting the cover in place. Problem was, it would go in fine on the cover, but I couldn't get the bottom edge against the cylinder head to go in after the cover was in place. After a few tries, I changed my approach.
What I did was pull the boot into place and hook it onto the cylinder head (the lower fixed edge) first, then as I gently put the cover in place, without dislodging the lower edge of the boot, I just pulled the sides and top of the boot "forward" into the opening. It just popped right in. Being right-handed helps, I suppose.
On the passenger's side, the same approach works - just put the edge against the head in place first, then slide the cover down onto the slot on the boot. No contortions required because there's room to do it this way.
This approach works equally well with the snorkels in or the snorkels out.
Cheers
JJ
jaj is offline
post #6 of 45 Old 2nd November 2006, 07:57 AM
a_ok2me
a_ok2me's Avatar
Originally Posted by jaj
I did a change today and there were a couple of things I figured out that made it easier...
Wondering if I'd be better off getting a universal joint and then use my existing 1/4" rachet. Also, the universal joint could serve as a "wobble" when you combine two regular extensions. I could save money by not having to buy a flex head rachet. Would you think the universal joint works for this application?
a_ok2me is offline
post #7 of 45 Old 3rd November 2006, 04:06 AM Thread Starter
jaj
jaj's Avatar
The 1/4" stubby flex ratchet is for all the 10mm head screws that hold things together. It makes the job easier but is not required - a regular ratchet will work fine.
The 21" extension is 3/8" for the spark plug socket - a universal joint would work but it would be frustrating because you couldn't guide the socket onto the spark plugs easily. As with the 1/4 stubby ratchet, it's handy but not essential. Use what you have - it'll be fine!
Cheers
JJ
jaj is offline
post #8 of 45 Old 3rd November 2006, 07:33 AM
a_ok2me
a_ok2me's Avatar
Cheers
JJ
JJ - Thanks
I have quite a few extentions to get me to 21". They're hybrid wobble/fixed, but they're 1/2". I have a 3/8" to 1/2" adapter for the spark plug socket. I haven't opened it up yet, but do you remember if 1/2" extensions will fit. I'm guessing it would, but it would make it hard to guide the spark plug through.
a_ok2me is offline
post #9 of 45 Old 3rd November 2006, 10:30 AM
richie_rvf
richie_rvf's Avatar
Excellent post JJ!!
I was going to change the plugs this weekend
Are there many choices for spark plugs?
I was going to get them from the main dealer but if there is a better option out there I would rather do that.
Cheers,
Richie.
richie_rvf is offline
post #10 of 45 Old 5th November 2006, 03:50 AM
a_ok2me
a_ok2me's Avatar
#2 Undo the two cap nuts that hold the cover on. This will be your first opportunity to use the stubby 1/4 drive ratchet. The rubber bushings around the nuts and the washers are all separate and loose, but they stick together from the heat. Don't drop them when you take it apart. Pull the cover loose from it's gasket and slide it forward and out...
#5 Once the coils are loose, but still in place, use a screwdriver blade to pop the shiny metal brackets on the coils up. Slip it into the slot below the bracket and twist gently - the brackets lock the connectors, so pull the brackets up as far as they'll come (about 1/2 inch or so) and then gently pull or push the black connector off toward the rear of the car. They're EASY to take apart, so you shouldn't be struggling with them. Starting from the front of the engine (Cylinder 5) undo the connectors and grab the coils under the "ears" that go over the studs, and pull them out - again, you can be gentle because they come out quite easily. I took all four out and set them aside.
#6 At this point, you're looking at the four spark plugs deep (really deep - remember the 21 inch extension?) in their openings in the cylinder head. Using the long extension, remove the old plugs and screw in the new ones. Torque to 30 newton meters. This is the easiest part of the job!
Here are pictures to #2, #5 and #6. The universal joint gave me more flexiblilty than the wobble extension; I did not need to remove the air filter box.
Edit:
The spark plug socket, two 6" regular extensions, one 3" regular extension and a universal joint to join the 6" extensions.
a_ok2me is offline
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 12:11 AM
2 weeks old: My impressions of the SL 55 vs. M5 (very long) Rezf E39 M5 and E52 Z8 Discussion 34 30th September 2006 01:30 AM
BMW M Manager Bruhnke at Stockholm Open, Sweden and answer to your questions Gustav Most Memorable Threads' 43 1st November 2004 07:16 PM
BMW M Manager Bruhnke at Stockholm Open, Sweden and answer to your questions Gustav E39 M5 and E52 Z8 Discussion 11 30th October 2004 02:36 PM
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 09:13 PM
