Old 9th September 2005, 20:35   #1
bbfl
bbfl's Avatar
Garage: 2001 M5 Carbon Black
Indicator Bars...
I have 3 green indicator lights left however it has been ~5k since my last oil change. I am wondering how many miles I have left until Inspection II if I drive fairly easy...trying to see if I should wait for oil change through Inspection II or if I should just do it myself...
bbfl is offline
Old 9th September 2005, 21:07   #2
Jayson
Jayson's Avatar
Garage: m5
Send a message via AIM to Jayson
Re: Indicator Bars...
Search and the manny in the glove box would answer this.
15k miles for oil changes. 1st inspection 30k, 2nd 60k.
Jayson is offline
Old 9th September 2005, 21:16   #3
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
if you have 3 green lights left, it's going to be a while for your next service. If you drive easy, and plan on keeping the car long term, it's probably a good idea to do an oil change about halfway thru the light's schedule, which works out to every 6-8k miles depending on conditions.
You don't mention how many miles you have, but for me, inspection 2 came up around 52k miles.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 9th September 2005, 22:17   #4
bbfl
bbfl's Avatar
thanks for the reply...I have 49,500 miles currently. So I think I can make the bars last to 54,000.
Thanks again
bbfl is offline
Old 10th September 2005, 03:09   #5
Ag02M5
Ag02M5's Avatar
Garage: O2 E39 M5 Blue Water Metallic
I have 59k miles and still 2 bars!!!!
I want my beast serviced!
What is the most bars people have had and gotten for Inp. 1 or 2?
Thanks.
Ryan
SOLD: 2002 M5, Bluewater Metallic, 65k miles, custom trim, runs great! Click on the below link.
http://www.m5board.com/vbulletin/sho...62#post1088562
Ag02M5 is offline
Old 10th September 2005, 08:30   #6
mottati
mottati's Avatar
Thanks.
Ryan
If you're paying, your dealership will do it anytime. If you're trying to get it covered under the maintanence plan, the dealer won't do it until the yellow (in general).
It's funny how the 'no maintanance' attitude changes when it's your dime... extra oil/gearbox/diff/coolant changes are "a good idea."
mottati is offline
Page generated in 0.12275 seconds with 10 queries
