7th September 2005, 15:38
#2
01 M5 Black/caramel
Re: Using a different size tire/wheel as spare
Originally Posted by fess
I need to get a set of winter tires and wheels for my '03. It currently has the stock 18" wheels. I've heard 17" tires are better for snow, but I would like the option of being able use a wheel from 1 set to act as a spare for the other set in an emergency.
If I get 17" wheels, would I be able to put one on with the 18's or visa-versa in an emergency without screwing something up?
Rolling diameter of stock tire is about 25.7 inches. So as long as the diameter is substantially the same, you can use a different wheel size. a 245/45-17 is the same size, although I don't know if that is a size regularly stocked. For snows a narrower (narrower is better) 225/50-17 at 25.9 inches, if a current stocked size, would be close enough.
