Oil filter housing rubber mount broken (also steering servo fluid reservoir) - BMW M5 Forum and M6 Forums
Old 2nd September 2005, 00:03   #1
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
I have noticed a broken oil filter housing mount on my car (and fixed it) and then today I saw the exact same problem on another M5, so I post some info.
I think the reason the rubber mount broke might be stress from when tightening the oil filter cap with a torque wrench without holding the housing with the other hand thus letting the rubber mounts absorb the torque.
The oil filter housing is held in place by two rubber mounts. There are two screws moulded into each rubber mount.
Th eoil filter housing is secured to the rubber mount by two nuts. the nuts are reusable.
The rubber mountings are screwed into nuts which are welded to the holder.
To remove an unbroken but cracked rubber mount, just grip its top side screw with a pair of pliers and turn it.
To remove a broken rubber mount, grip the screw on the BOTTOM SIDE of the holder with a suitably small pair of pliers. (If you try to grip the broken rubber part on the top side, you will probably just scratch the holder. Bin there...)
BMW part number : Rubber mount 11 42 1 407 441 (2 pcs)
The steering servo fluid reservoir is located next to the oil filter housing. It is mounted in a similair way. On both cars the rubber mounts for thr servo fluid reservoir showed cracks.
BMW part number is 64 12 1 365 602 (2 pcs)
David
DavidS is offline   Reply With Quote
Old 2nd September 2005, 05:51   #2
TCM
TCM's Avatar
Garage: 2001 BMW M5 Silverstone/Black luxury and 2001 M5 Jet Black/Black Luxury
Re: Oil filter housing rubber mount broken (also steering servo fluid reservoir)
This is very common on the E39 V8s. I think I have replaced 3 on my M5 alone, and countless others. It is an important thing to check out as without the oil filter housing pulls on the oil lines and can create a massive oil leak. Thanks for posting this David.
T.C.
'01 Brushed Steel M5
front splitters
3.45 differential
'01 Silverstone M5- sold
SuperSprint:X-pipe
TCM is offline   Reply With Quote
Old 2nd September 2005, 06:34   #3
greg
greg's Avatar
Garage: 2000 Anthracite
But why would you ever re-tighten the oil filter with a torque wrench? It has an o-ring. Hand tight + 1/8 turn is PLENTY.
greg is offline   Reply With Quote
Old 2nd September 2005, 08:18   #4
DavidS
DavidS's Avatar
Sales Feedback: (4)
It says in the BMW workshop manual to either hand-tighthen or torque to 25 Nm with a torque wrench.
With both methods you will need to counterbalance the torque by holding the oil filter housing with your hand, or there will be considerable stress on the rubber mounts.
David
Old 3rd September 2005, 04:39   #5
mchin
mchin's Avatar
Garage: 97 M3
I just had my oil changed at a local dealer last weekend.
I go to check the oil the following Tuesday and find the same problem. It was clearly done when the tech tightened the cap.
Returned to the dealer and I am waiting for the part.
I was actually considering trying to fix the problem by drilling through the remainig rubber on the broken side and pushing a longer screw through the hole and using the old bolt. but then again, if I did not break it why should I try and fix it.
funny thing is I was wondering if this happens frequently since the design seems open to this type of failure. Does anyone know why BMW wanted to have the filter housing mounted on rubber bushings instead of being attached to the block like an E36?
Thanks, Michael.
mchin is offline   Reply With Quote
Old 9th April 2006, 05:33   #6
bgregg
bgregg's Avatar
Garage: M5 Titanium Silver
Wish I had read this post sooner. Thanks for posting it DavidS.
Today was oil change day and this post was useful. Part #20 on the diagram is very suceptible, but at least it is inexpensive.
http://www.realoem.com/bmw/showparts...64&hg=11&fg=30
Now I can say, been there done that. -Bill
'01 Ti Ag / Black full-leather interior w/M-audio
Mods: Axxis Ultimate pads, M-Technic brake duct/grill insert, Rogue Octane SS w/WSR & transmission mounts, TC Design swaybar brackets, Dinan Stage 3 suspension, UFM IATS, SS brake lines
'07 MINI Cooper S w/JCW mods
bgregg is offline   Reply With Quote
Old 9th April 2006, 15:40   #7
HDClown
HDClown's Avatar
Garage: 2002 M5
Gotta love this board. I would have never thought to check that until when I went to change my oil in another 6k miles or so as I just had Inspection II done at the dealer. Well, I go out to check and what do I find, one of the mounts is broken. It was not broken when I changed the oil 7k miles ago, so the dealer did it.
I'm just going to fix it myself though. A few bucks in parts is worth the hours I'll have to waste with the dealer.
2002 LMB/LMB M5 - Alcantara Headliner, Electric Shades, Folder Down Seats, M-Audio
-Britalman Exhaust, Brembo GT 355f/345r Big Brake Kit, Centric Posi-Quiet Pads, AA CAI
-UF IATS Relocation, UUC Evo3 SSK + DSSR, UUC Clutch Stop 19" Breyton Spirit Rims
-TCD Rear Sway Brackets, Euro Angel Eyes, Angel iBright v3.0, Stealth Bulbs, Stealth One
-Valentine One, Roof Spoiler, OEM Voice Control, OEM Trunk Storage Bin, 13% Solar Gard HP Tint
HDClown is offline   Reply With Quote
Old 10th April 2006, 14:38   #8
bayerischemotor
bayerischemotor's Avatar
Garage: M5 E60 Interlagos Blue
Mine has the same defects. Parts ordered.
° Evolve Alpha N
° RPi ram air induction kit
° RPi ST pulley kit
° Supersprint exhaust and resonator
° Secondary cat delete
° (Evolve long tube headers coming!)
bayerischemotor is offline   Reply With Quote
Old 18th April 2007, 03:42   #9
M5finally
M5finally's Avatar
Garage: 2002 M5 Silver
Was going to start a new thread about this, but thank god I didn't... Did the oil on my girls car and found both mounts broken. I had to tie wrap the filter housing for now, but I need those mounts. Anywhere other than BMW, or maybe online ?????
Tom
Oil filter housing rubber mount broken (also steering servo fluid reservoir)-oil-filter-mounts-1.jpg
Oil filter housing rubber mount broken (also steering servo fluid reservoir)-oil-filter-mounts-2.jpg
Oil filter housing rubber mount broken (also steering servo fluid reservoir)-oil-filter-mounts-3.jpg
2002 Silver M5
20% Tint
6000k upgraded fogs, low beams, halos
DONE!!!!
M5finally is offline   Reply With Quote
Old 18th April 2007, 06:10   #10
Need4Spd
Need4Spd's Avatar
I've had to replace mine, too. One broke and the other was marginal. It's easy to get oil on the rubber, which over time weakens them.
No place to get them other than the dealer (including those who sell on the Internet or by mail order).
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is online now   Reply With Quote
How Much $$ Do You Pay for an Oil Change?? cohenfive E39 M5 and E52 Z8 Discussion 42 12th January 2011 19:18
Official press release: Engine / Drive System enots E60 M5 and E61 M5 Touring Discussion 9 24th June 2004 00:50
Peter Pan BMW -- bad service, No 1200 mile oil change on 03 jdh E39 M5 and E52 Z8 Discussion 29 21st May 2004 16:49
Some air filter info from BMWE34.net BKH E39 M5 and E52 Z8 Discussion 1 30th October 2003 19:39
