Old 25th August 2005, 04:44   #1
BKH
BKH's Avatar
Garage: 2000 BMW M5 Silverstone
Insulating the airbox (airfilter housing)
The thread below got me thinking about using a heat-reflective tape on the underside of the airbox. I found an high-temperature aluminum tape that utilizes a silicone adhesive, made by 3M, that I'm in the process of sourcing. Do any of the engineers here have a suggestion (something simple) as to how I can measure before/after temperatures inside the airbox w/o drilling holes or buying anything that would be a one-shot usage item? I'll probably do it when I'm in California so I can have similar, back-to-back days to take readings. Is there a stick-on temperature indicator that changes color that I can attach to the air filter, for example?
BKH is offline
Old 25th August 2005, 09:31   #2
Need4Spd
Need4Spd's Avatar
Re: Insulating the airbox (airfilter housing)
Do a search. I remember Greg did an extensive test of the air temp inside the air filter box to get a sense for how IATS relocation worked. He bought a cooking thermometer or something but I don't remember how he hooked it up.
Need4Spd
Need4Spd is offline
Old 25th August 2005, 19:45   #3
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Like Darryl said, do a search for 'greg' and heat testing. He did a pretty comprehensive write up with various probes in and around the intake tracts. I think there would be more value in insulating the underside of the plenum, it's metal and it gets hot. The coldest air in the airboxes will heat up as it arrives in the plenum.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 25th August 2005, 20:10   #4
BKH
BKH's Avatar
Missed that, thx.
BKH is offline
Airfilter options for 1985 B7 Turbo GaAlpinaowner ALPINABoard.com | BMW Alpina Discussion 1 20th July 2005 04:26
24 degress less intake air temp Pete E39 M5 and E52 Z8 Discussion 35 5th July 2004 05:49
Help, need used airbox clauswagner E39 M5 and E52 Z8 Discussion 14 21st May 2003 05:54
Stock airbox top velocity stack.... TriflowM5+M3 E39 M5 and E52 Z8 Discussion 12 31st March 2003 02:07
Reflective material under airbox raland9 E39 M5 and E52 Z8 Discussion 0 28th April 2001 06:04
Page generated in 0.08912 seconds with 11 queries
