Old 5th September 2005, 18:47   #21
Ronin M5
Ronin M5's Avatar
Garage: 2001 BMW M5, Carbon Black Metallic
Re: DSC Light and Brake ABS Lights On - Advice?
Originally Posted by a_ok2me
Anyway, get it rebuilt for $425. I shipped it to this place and got it back about a week later.
Auto & Truck Electronics
(800) 257-3395
6500 Georgia Avenue
West Palm Beach, Florida 33405
Rebuild control module $425
1yr Warranty
Shipping $28
Thanks for the detailed response. This will definitely be helpful for future readers of the post.
Glad to have my baby back and fully operational.
2008 BMW X5, 4.8i Sport (Our Family Hauler)
2006 Ford GT, Heffner Pulley, Heffner Tune, Accufab Exhaust, Ford Racing SSK, Halon Fire Suppression, Crow 6 Point Harnesses, Setrab Transaxle Cooler
2006 Dinan Mini Cooper S, Dinan Valved Koni Shocks, Eibach Springs, Dinan 3 Piece Forged Wheels, Dinan 15% reduction Supercharger pulley Kit, Dinan CAI, Dinan Exhaust, Dinan Stage V Software, Alta Intercooler, LSD, Sport Package
2001 M5, Carbon Black Metallic, LOTS of mods, gone but fondly remembered
Dyno 395.5 rwhp
2004 BMW K12S, Nurburgring Test Ride Event, 1 of 4 USA Test Riders selected
BMWs Sold: 1987 535is, 1997 M3 Sedan, 2000 K1200RS, 2000 R1200C, 1997 328i Sedan, 2004 R1100S BMW Boxer Cup Replika #3/300, 01 M5
Ronin M5 is offline
Old 6th December 2005, 07:05   #22
a_ok2me
a_ok2me's Avatar
Garage: M5
FYI:
Just got this from bimmerforums via member killcrap. It's another abs control module repair shop. This shop is $125 cheaper than the other shop I listed above. Even better is that this place has a 5yr warranty vs the 1yr at the other shop.
http://www.modulemaster.com/bmwabsrepair.html
a_ok2me is offline
Old 7th December 2005, 06:20   #23
Sudesh Sharma
Sudesh Sharma's Avatar
Garage: BMW M5-e39 plus 540i Sport both silver
Right I have had this problem a number of time and it always turned out to be the ABS sensors on the front wheels. The sensors are not expensive, Think £30 sterling each. Fitted them myself and reset the sensors myself. To reset the sensors,
1.switch your ignition off,
2.hold the Traction control button in, then turn your ignition to the last position on but dont start the car.
3.Take you finger off the Traction control button now
4.Turn the ignition on.
Now drive for about 100 yards or less and the lights should go off.
This method has worked for me.
Sudesh Sharma is offline
Old 14th July 2006, 01:36   #24
M5 Dave
M5 Dave's Avatar
Garage: 2000 M5 Ti-Silver
DSC, ABS and Brake indicators all on...
Bumping this thread up as I am having this problem now. Currently at the dealer, qoute is for $710 for the DSC Control Module and 90 min labor. Whish I had found this thread first as it looks like there are some places that rebuild the control module for far less. But as I understand it, there are some adjustments that have to be made when you replace the module hence the 90 min labor. I wouldn't know how to do that anyway. Turns out my third party warranty company wont cover it. They list everything that they do cover and if its not in the list, too bad. Under the brake system they list wheel speed sensors which input into the device (DSC Control module) but, only the ABS control unit is listed as covered. They said DSC and ABS modules are two different names, its not listed, its not covered.
By the way, I have additional symptoms as well as the DCS, ABS and Brake indicator lights that pop up (they all popo up up at the same time) when this happens, the speedometer goes down to zero and the Nav system shows me at the same spot on the map in which these symptoms appeared, even if I have traveled another 50 miles since they all popped up. $tealer says its all related, DSC module failure causes speedometer not to read, vehicle thinks its not moving due to the speedometer inop, so Nav system inop, crazy stuff.
Anyway, letting you know in case this happens to you and also wondering if these two additional symptoms happened to those in this thread before me.
M5 Dave
2000 TiSilver M5 - Supersprint Headers, Tubi Catback Exhaust, Active Autowerke Tuned ECU, Active Autowerke CAI, Custom Hi-Flow Air Filtration, UUC 11" Performance Organic Clutch/Aluminum Flywheel, UUC Short Shifter, UUC DSSR, UUC Clutch Stop, UUC Tranny Mounts, Strong Strut Front Strut Bar, Riken Raptor Tires, AXXIS Deluxe Plus Brake Pads, UUC Shifter Knob, DEPO Projector39 HID DDE Clear Corner Headlights, Xtec HID Xenon Low beams, High Beams and Fogs (six ballasts), MK4-16:9-V28 Nav Upgrade, Bimmian Interior Xenox Lighting, V1 Radar Locater.
M5 Dave is offline
Old 14th July 2006, 01:41   #25
Kin Mak
Kin Mak's Avatar
Garage: BMW E46 M3
Sales Feedback: (3)
Send a message via MSN to Kin Mak
At the price you are quoted it is looking like they are repairing the unit. There is a DSC repair kit they can get. It will be in the thousands if you were replacing the whole thing.
BMW E46 M3 SMG Carbon Black/Cinnamon
BMW E39 M5 Avus Blue - SOLD
KinMak.com - Loads of Photos - Elara Online
Kin Mak is offline
Old 11th February 2008, 14:34   #26
MPressed
MPressed's Avatar
Garage: Silver E39 M5
My turn...
Well, I've had these lights pop up:
DSC
BRAKE
ABS
Tire Control
My speedometer works just fine though. Sound expensive?
MPressed is offline
Old 11th February 2008, 16:30   #27
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
DSC
BRAKE
ABS
Tire Control
Old thread, i haven't gone through the old replies, but I would check glove box fuses. I think it is 17 and 30 or 31. You need to pull those to run on the dyno and you get similar fault codes.
Best part, it takes 5 minutes and costs nothing. Fuses can be tricky, so either use a spare fuse of the same rating or swap with a known good fuse with the same rating.
gsfent is offline
Old 1st March 2008, 20:30   #28
M5CCIE
M5CCIE's Avatar
Garage: 2003 M5 Sterling Gray
Sales Feedback: (5)
Had the DSC and Brake and ABS lights pop up yesterday, right after a smog check. I think it was due to the rear wheels were spinning but the fronts were not. After I drove about 50 yards, the lights turned off.
Dinan 3.45 differential
TMS Shark Injector - 91 Octane tune
IATS Relocation - Inside Air box
Strong Strut front brace
TC Design rear swaybar brackets
Bluetooth
V1
Aux port
M5CCIE is offline
Old 1st March 2008, 20:31   #29
M5CCIE
M5CCIE's Avatar
Sales Feedback: (5)
Maybe we should turn off the DSC before any dynos or smog tests...
M5CCIE is offline
Old 1st March 2008, 22:24   #30
jclyman
jclyman's Avatar
YES
- Daniel Boorstin
jclyman is offline
BRAKE light on dash is on....Question DIPLOMAT E39 M5 and E52 Z8 Discussion 1 17th March 2005 23:27
DSC light / ABS lights won't shut off- Please help? RKM E39 M5 and E52 Z8 Discussion 8 21st January 2005 16:25
Check Brake Lining light question. Stem E39 M5 and E52 Z8 Discussion 3 5th August 2004 16:07
How to install LED brake lights atomic80 M5 E39 and E60 tips & tricks 0 2nd September 2002 03:01
Page generated in 0.21984 seconds with 12 queries
