Old 12th August 2005, 21:17   #1
baf3472
baf3472's Avatar
Garage: 2000 M5
Replacing Thrust Arm Bushings
I need to replace my Thrust arm bushings due to a shimmy when braking. What other front end parts does everyone recommend I change while they’re doing this? I figure I should do a little preventative maintenance and i'm not sure what parts are considered consumables. thanx in advance
baf3472 is offline
Old 12th August 2005, 23:26   #2
baf3472
baf3472's Avatar
Garage: 2000 M5
Re: Replacing Thrust Arm Bushings
Shameless Bump
baf3472 is offline
Old 12th August 2005, 23:46   #3
Ocean's M5
Ocean's M5's Avatar
Garage: 2002 M5
Are you going to replace yourself? If so, then I would have a dealership tell you what they are going to replace in the "veil" of an estimate. Is that the right word?
At least you would have the proper info...
2002-05 Build Carbon Black ///M5
First Aid Kit ~ Warning Triangle ~ Full BMW Tool Kit
Rear Cupholders ~ Stubby Air Stems ~ Rear Shades ~ PDC
M Audio ~ Fold-Down Rears ~ Black Sport Int.~ Yokohama Advan Sport~
Beast Power Sway Brackets ~ Tinting-80% Strip Windshield
Center Armrest *Storage Bin ~ ///M Black Trunk Mat
Ocean's M5 is offline
Old 12th August 2005, 23:50   #4
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i had my thrust arm bushings replaced last week. It did cure my shimmy. there are other bushings, ball joints and wheel bearings of course, but i do not think they fail as routinley as the thrust arm bushings. If you are doing it yourself, i think you can buy the whole control arm with bushings, ball joint etc and replace the whole package.
My dealer seemed to be hesitant to start replacing parts in the front end, maybe because of my mods, who knows. I've been complaining about the shimmy (it was mild) and a little "looseness" in my front end for nearly a year, finally the bushings started leaking, which is the failure sign. (not a cpo part, i might add, wear and tear).
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 13th August 2005, 00:52   #5
baf3472
baf3472's Avatar
Garage: 2000 M5
Actually im having my trusted independant shop do it. The owner used to be a tech at the local BMW dealership and actually worked on my car while there. He left and opened his own shop. He diagnosed the problem and he suggested just changing the bushing but i figured since hes gonna be in that area working if something should get changed why not do it.
baf3472 is offline
Old 13th August 2005, 04:10   #6
Xcargo
Garage: 2003 M5 Black
All right another part that will need to be replaced. How many miles can I expect to have this one go on me?
Xcargo is offline
Old 13th August 2005, 09:50   #7
greg
greg's Avatar
Garage: 2000 Anthracite
If you can, please take pictures and document the procedure for those of us who may DIY in the future...
Thanks in advance
greg is offline
Old 13th August 2005, 17:02   #8
Lscman
Garage: E39
You may want to investigate the possibility of substituting X5 V8 bushings. They are rumored to be streetable but stronger, since they must withstand high CG with more weight and huge tire combo.
The M5 bushing is the standard design found in a 1997 5er.
Lscman is offline
Old 13th August 2005, 21:09   #9
Greco
Greco's Avatar
Garage: 1998 E39 540 Biarritz Blue/Beige SPP
Take a look at your tie-rods as well, left, right, and center. It contributes to shimmy's. Also the thrust arm itself has a ball joint so the arm might need replacement as well.
- Bill
>> Just an E39 540i/6 Biarritz Blue <<
Greco is offline
Ball Joints and Thrust Bearings Joe Lapicki E39 M5 and E52 Z8 Discussion 23 11th October 2005 07:34
Powerflex bushings Ohmess E39 M5 and E52 Z8 Discussion 11 14th May 2005 20:48
Track Report & Powerflex Bushings RRoberts E39 M5 and E52 Z8 Discussion 27 21st January 2005 18:26
Thrust Arm Bushing and Tie Rod Link x703jko E39 M5 and E52 Z8 Discussion 3 4th December 2004 04:55
Sway Bars? Do they Need Replacing? V-10 4 Me E39 M5 and E52 Z8 Discussion 22 19th November 2003 17:15
Page generated in 0.13476 seconds with 11 queries
