--Front Door Squeaks HELP-- - BMW M5 Forum and M6 Forums
Old 7th August 2005, 06:33   #1
ArsenalFC
Garage: 2008 - ///M5 - White
Hi guys my cars front passanger door squeaks everytime I open and close it... I tried WD 40 but did not work, anyone have any ideas.. Thanks for the replies
| Dixis| Gruppe M | Brembo | OZ Ultraleggera HLT |
ArsenalFC is offline   Reply With Quote
Old 7th August 2005, 13:44   #2
Xcargo
Garage: 2003 M5 Black
Re: --Front Door Squeaks HELP--
There is a black limiting rod that has a roller inside the door on it that will squeek if not lubricated. Open the door and at the hindge point look about in the midpoint and you will see the black rod surrounded by a rubber gasket on the door side. Take some lithium grease and apply it to the black rod and open / close the door a number of times and the sqeek should be gone. Notice that the grease will have a track in the middle of it when opened and closed from the roller. You may need to reapply to get sufficient coverage.
Xcargo is offline   Reply With Quote
Old 7th August 2005, 14:15   #3
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
Yes, that is the way to fix it!
Xcargo, you do know your stuff!
David
DavidS is offline   Reply With Quote
Old 7th August 2005, 17:33   #4
ArsenalFC
Thanks guys for your help. Where can I get this lithium spray?
Old 7th August 2005, 17:42   #5
DavidS
DavidS's Avatar
Sales Feedback: (4)
You donīt want the spray kind for this. You want the really thick lithium grease, and apply it with a wooden stick (or something similair).
Ask for wheel-bearing grease at any petrol station.
You will need to apply the grease, and the move the door a few times, and then repeat many times over until the squeek is gone.
When you are done with the driver door, put some grease in the same place on the other doors to. It is a lot faster when the rollers arenīt yet stuck.
David
Shadowman & Discovery Automotives Front Spoiler - Group Buy Sean@D/A M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 36 11th March 2009 14:56
BMW M6 Press Release no 5: Body, Design, Equipment: Light and Safe, Sporting and... Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 9 15th December 2004 21:25
Eibach coilovers and Dinan Stage III Carrera2RS E39 M5 and E52 Z8 Discussion 31 7th October 2004 00:50
275's up front! 1st impressions. CM5GO E39 M5 and E52 Z8 Discussion 16 15th December 2001 16:56
Missing front side airbags? wundercar E39 M5 and E52 Z8 Discussion 3 9th November 2001 16:32
