Just came back from holidays to a bit of a shock, put the M5 in to BMW for a bit of a problem I have had with selection of 3rd Gear, yikes the GEARBOX HAS GONE, agreed the replacement along with the dashboard due to pixel loss, now that have finished that they decide to check the car out and the real expense has started, rocker cover gasket needs replacing, engine mounts, hydraulic steering hoses sprung leaks, diff mounts need replacing, oil sender needs replacing, brake discs and pads need replacing, a lot of money to be spent, I am in catch 22 if I dont spend it I would not be able to sell it, but I dont want to sell it so I have to have the work done, not much change from $20,000 in total given the go-ahead and just trying to work out if I can keep it from the wife.
Any ideas for uprated brake drums or should I just stick with replacing the originals?
WillM5AD
