Old 29th August 2005, 22:58   #121
boostmiser
boostmiser's Avatar
Garage: 2002 Alpine White M5
Re: UUC direct fit replacement clutch
I think the install was today...
Patiently waiting news
The Upgrades: Dinan Stg. 1 / Dinan RSB / TCD Sway Bar Brackets / UUC Evo III SSK / UUC DSSR / UUC Tranny mounts / MKIV Nav Unit / JL 500.1 Amp / JL 12w6v2 Sub
boostmiser is offline
Old 30th August 2005, 00:49   #122
bmwusa
bmwusa's Avatar
Garage: Waiting?????
what install? its not me yet, I have yet to recive the new clutch, jopefully it comes soon though, unless your talking about something different , Josh
1/2 of the Southern Renegades....
I just love the smell of JP-5 in the morning
bmwusa is offline
Old 30th August 2005, 03:05   #123
boostmiser
boostmiser's Avatar
Oh, for some reason I remember Rob saying they were testing the 'fixed' clutch on Monday
Old 30th August 2005, 04:55   #124
bmwusa
bmwusa's Avatar
I called on friday and he was thinking that I would have it by the weekend, so as soon as I get it though I will have it installed asap, Josh
bmwusa is offline
Old 11th September 2005, 01:13   #125
dmccrary90025
dmccrary90025's Avatar
Garage: 2005 GT3 White/Black
Two weeks and no posts? Don't leave me hanging! Whats-up at UUC on the new set-up?
Lcsman, on the matter of flywheel replacement, maybe you have some suggestions for me. I just burned the crap out of my clutch in take-off 1st- 2 gear, with total slip and serious burning. I was trying to show-off by revving my car in front of a MB mechanic and then dropped the hammer somewhere between 2-4K RPMs, and nothing transfered to the wheels, first time trying something as stupid as this and first time I "felt" a clear slip. Stunk of burned material in my car for some time thereafter but worked fine once cooled. At 21K and 18 months old, sounds like I should be able to skip on the flywheel and just go with a new clutch. Avus says its $1200 for the OEM install of new clutch, and $2K if I want the Dinan lightweight flywheel. Obviously I rather not spend the additional money on a flywheel. Is the flywheel likely OK?
I don't see how others above feel its covered under the new warranty, I've been told no way!
dmccrary90025 is offline
Old 11th September 2005, 01:44   #126
boostmiser
boostmiser's Avatar
I'm also waiting. Talked with Rob Monday, I think it was, and he said another 5-6 days. So it should be any day now. I'm doing a stock flywheel anyhow.
Old 11th September 2005, 02:07   #127
Jayson
Jayson's Avatar
Garage: m5
Send a message via AIM to Jayson
When it's pulled out if it's discolored it's not ok and will need replaced. I would replace it either way though new clutch new flywheel is always best.
Jayson is offline
Old 11th September 2005, 02:11   #128
bmwusa
bmwusa's Avatar
I too am just waiting for UUC to send the clutch, as soon as its here I will have it in the shop, trust me, nobody wants it it more then me , Josh
bmwusa is offline
Old 11th September 2005, 05:14   #129
Lscman
Garage: E39
Flywheels can generally be reused if the surface shows no evidence of radial microcracks, checking or scoring from overheat or rivet contact. As Jayson noted, new flywheel is always the safest bet.
Lscman is offline
Old 11th September 2005, 06:14   #130
Need4Spd
Need4Spd's Avatar
Part of the reason for this is the high cost of labor for clutch replacement. You don't want to skimp on parts then find out that you have to tear it all apart again, effectively doubling the labor cost.
Need4Spd
Need4Spd is offline
Clutch Replacement canysmc E39 M5 and E52 Z8 Discussion 42 22nd January 2009 22:05
New Install UUC Stage III Clutch and Light Flywheel. QUESTIONS! Kings MotorSport E39 M5 and E52 Z8 Discussion 32 31st August 2005 07:49
New Sachs Power Clutch tripleD E39 M5 and E52 Z8 Discussion 13 12th April 2005 22:04
Clutch replacement in the UK Rampage E39 M5 and E52 Z8 Discussion 15 13th February 2005 10:48
Apples need clutch.."she's not gunna make it captain" Apples E39 M5 and E52 Z8 Discussion 50 10th March 2004 06:27
Page generated in 0.20963 seconds with 11 queries
