Aircon stopped help ! - BMW M5 Forum and M6 Forums
Old 7th July 2005, 18:42   #1
Carrera2RS
Garage: M5
Any thoughts on problematic aircon ? It just stopped blowing today for the first time ever. All controls appear to work, no dash faults coming up no blower and no cool air !!
My local dealer (Bath) can't see me for 3 weeks !!!!
Carrera 2RS
Carrera2RS is offline   Reply With Quote
Old 7th July 2005, 19:25   #2
verhagke
verhagke's Avatar
Garage: 2000 BMW M5 (Titanium Silver)
could be final stage unit. Easy and inexpensive repair
If the fan is not working properly, it could be the final stage unit which controls the fan speed. Do a search for more info on this issue. It's common to all E39's
verhagke is offline   Reply With Quote
Old 7th July 2005, 19:49   #3
ard
Super Moderator
ard's Avatar
Re: Aircon stopped help !
I've HEARD that the fan blower resistor pack is a weak link.
Supposedly cheap and mounted behind the glove box.
Maybe search for that term here for more info...
A
Old 7th July 2005, 22:12   #4
KevinM
KevinM's Avatar
Garage: 2002 E39 M5, Sterling Gray/Caramel; 2007 Z4M Coupe
Yep, this is almost definately the final stage resistor pack. It is a small fuse type device above the front passenger well that is a known problem for BMWs. There is a how-to-change it picture essay on a 540 site. There is a link to this on this site - you will find it if you do a search. Apparently you can change it yourself in 15 minutes.
Good luck.
Kevin
2007 Z4M Coupe (#2) Silver Gray/Black
Too many kids' cars...
KevinM is offline   Reply With Quote
Old 8th July 2005, 00:03   #5
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
Good luck.
Yes. Price should be under $100.
Old 8th July 2005, 09:30   #6
Carrera2RS
Garage: M5
Thanks,
I have found a dealer (Dick Lovett) who will loo at the car straight away
Should get sorted before te weekend
Aircon not working Cyrus E34 M5 Discussion 8 7th June 2005 22:14
Electric Head Rest, stopped working. (help) plisken E34 M5 Discussion 24 31st May 2005 09:45
B10 Climate Control / Aircon problem Mary Mary ALPINABoard.com | BMW Alpina Discussion 3 9th August 2004 10:12
AirCon Power usage. IvanDias E34 M5 Discussion 2 4th October 2001 19:06
I stopped burning oil! dave E39 M5 and E52 Z8 Discussion 6 19th July 2001 01:40
