Old 7th July 2005, 01:04   #1
HDClown
HDClown's Avatar
Garage: 2002 M5
Any tips for AA CAI install, and question on IATS install
I got my AA CAI and I hope to install it this weekend. Any tips or the steps indicated in the directions accurate?
Can I do it with the car on the ground and tires on (until I have to cut slots for the brake ducts)
Since I have to pull the bumper to install the AA CAI, should I go with the recommended mount for the IATS as indicated in the instructions, or should I put it up in an air box? Since the bumper will be off, it really doesn't matter to me. If I wasn't doing the AA CAI, I'd put it in the airbox.
HDClown is offline
Old 7th July 2005, 02:31   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Re: Any tips for AA CAI install, and question on IATS install
personally, i think putting it in the airbox, or in the ducting going into the airbox is more acurate. Maybe in the duct to the airbox outside of the engine compartment would be ideal. Realistic data from the intake air stream, no potential for heat soak. I'm thinking in the plastic elbow just before the airbox in the fenderwell area.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 7th July 2005, 02:42   #3
mr_bock
mr_bock's Avatar
Garage: 2002 M5, Sterling Gray
IMHO cutting holes for the brakes is a waste of time as the air flow really does not get to the rotor, pads, or caliper. Unless of course you are ducted right to the backing plate! In fact I did not use the aluminum air boxes, nor the plastic trumpets they supplied. I just ran the flex hose directly to the aluminum funnels in the grill. BTW, I took extreem care in removing the stock grill so it could be reused or sold. The little plastic tips can break.
I felt that the direct mount hose would provide the most RAM air effect. No leaking joints, brake ducts, etc...
Anyway, good luck!
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
My latest toy... a 2001 360 Modena Ferrari
My 'other' car is a supercharged 1996 911 C2 993
mr_bock is offline
Old 7th July 2005, 19:22   #4
SC'dKellenersM5
SC'dKellenersM5's Avatar
Garage: Red White and Blue
Talk to BMWUSA (Josh) I came in at the tail end of his install and helped to put things back in after he and another buddy of his did most of the install...
Im in the highspeed aluminum business
SC'dKellenersM5 is offline
Old 8th July 2005, 02:30   #5
bmwusa
bmwusa's Avatar
Garage: Waiting?????
I thought it was pretty easy, me and some friends did it in just under two hours, and we worked on it in the drive way with tires on, no lifts or jacks, I thought it was easier to do one side at a time start to finish, and turning the steering wheel, to have easier access to the screws, if you have any questions during your install just ask on the board this weekend, I will be more then willing to help, Josh
1/2 of the Southern Renegades....
I just love the smell of JP-5 in the morning
bmwusa is offline
Old 8th July 2005, 04:25   #6
HDClown
HDClown's Avatar
Garage: 2002 M5
Instructions looky straight forward and easy to follow. Where there any gotcha's that took you some time to figure out what to do or you came up with a better way then listed in the instructions? I'm probably going to tackle this myself, and use the wife as a set of hands to help with the bumper on/off.
HDClown is offline
Old 8th July 2005, 14:21   #7
mr_bock
mr_bock's Avatar
When you are about to pull the bumper off... I put a pile of old cushions/blankets to support it. Also make sure you unplug ALL of the electrical connections. I used a hose pinch clamp to close off the washer lineas once you disconnect the hoses (at the connection) the fluid will keep flowing. One thing I did for looks was to mask the new grill and paint flat black this insides of the aluminum funnels. I only have the small out side ring shinny. Take your time, do a nice job.
UUC Clutch Stop
NAV MKIV DVD
mr_bock is offline
Old 8th July 2005, 20:05   #8
bmwusa
bmwusa's Avatar
What bock said about sums it up, the dircetions I believe have you do step by step for both sides at the same time, I would do the entire side start to finish then tackle the otherside, dont have to turn the wheels as often, good luck youll be fine, Josh
bmwusa is offline
Old 8th January 2006, 11:33   #9
aaronmiles
aaronmiles's Avatar
Garage: 1999 Imola Red M5
Send a message via MSN to aaronmiles
I did mine this weekend ... When I put the bumper back on it was lower on one side so I tried to adjust it with the 14mm hex but alas it stripped so now I am going to have to replace the mount ( bloody bugger that !!!! ). I can vouch for the cuts and such like. Given the previous owner of my car drove it up and down a dirt road there was dust and crud EVERYWHERE which made it a bit harder as I kept on getting dust in my eyes because I did not have jack stands etc, just a trolly jack.
Get it done for you I reckon.... its worth the money if for no other reason than it passes the hassle to someone else
1999 Imola Red M5. Extended Caramel Interior
Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
aaronmiles is offline
Old 8th January 2006, 15:32   #10
mr_bock
mr_bock's Avatar
Another 'look for' tip. The left and right ends of the bumper assembly have plastic guides that have to be engaged at the same time as the bumper is slid 'home'. Not sure if this has anything to do with the up/down problem, but all should be in the right position before tightining the two large vertical bolts.
Good Luck Man (Mate). The finished look is worth it.
UUC Clutch Stop
NAV MKIV DVD
mr_bock is offline
Tubi install question M5M5 E39 M5 and E52 Z8 Discussion 4 8th April 2005 09:08
TUBI install question mnhead E39 M5 and E52 Z8 Discussion 6 4th May 2004 20:40
Stealth One Install question for those that have done it already Lincoln E39 M5 and E52 Z8 Discussion 3 6th April 2004 18:24
Basic X-pipe Install w/Kelleners Question ElusiveJay E39 M5 and E52 Z8 Discussion 9 1st November 2003 20:49
A question regarding AA CAI GregC E39 M5 and E52 Z8 Discussion 10 7th September 2003 18:02
Page generated in 0.14089 seconds with 11 queries
