Mockup of sub enclosure ...
What color do you think best matches the trunk? heather, silver pearl, silver or just black?
http://www.ultrastyledesigns.com/soft_color_chart.htm
I designed my sub box today and will most likely be covering it with ultrasuede. Actually, there will be a board that divides the trunk from top to bottom, side to side, that will be covered with the ultrasuede. This board will connect to the sub which is behind the divider. A sub cover will be showing and the amp will probably be mounted to this board. Essentailly, when you open the trunk, there will be open space and an ultrasuede covered wall. Similar to this mockup I made out of 3/4" mdf then PS's a bit.
The Upgrades: Dinan Stg. 1 / Dinan RSB / TCD Sway Bar Brackets / UUC Evo III SSK / UUC DSSR / UUC Tranny mounts / MKIV Nav Unit / JL 500.1 Amp / JL 12w6v2 Sub
