Old 6th July 2005, 19:40   #1
Larry's M5
Larry's M5's Avatar
Garage: '02 Carbon Black E39 M5
Auxilary fan kicks in late?
I had this happened to me a few times already, during slow traffic, the temp would raise to just a bit before overheating (red zone) before the auxilary fan would kick in, but once it kicked in, it operates normally afterwards for the rest of the trip even in stop and go traffic.
Does this sound normal or is my auxilary fan fan is about to go? Should the temp be stay rock solid at the middle range???
02 ///M5 Carbon Black/Silverstone Sport
02 C32 /////AMG Brilliant Silver/Charcoal
08 328i Black/Black
Larry's M5 is offline
Old 6th July 2005, 19:53   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Re: Auxilary fan kicks in late?
i'd say there is something wrong. My temp gauge is pretty steady except under extreme conditions. After 6 or so hard laps at buttonwillow chasing a porsche in 106F heat, my temp gauge started climbing. When it's warm, or i'm in traffic, the aux fan seems to be running more often than not.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 6th July 2005, 20:24   #3
M5_SMG
M5_SMG's Avatar
Garage: E39 Silver
Send a message via MSN to M5_SMG
I have the same problem from time to time, seems to happen when I am extremely gentle with the car while it is still warming-up (stuck in traffic). Its gets to a bit over 3/4 on the temp. gauge.
Thermostat would be my guess?
M5_SMG is offline
Old 6th July 2005, 21:33   #4
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Is it possible what you are really seeing is the thermostat initially opening on a warming up engine? On many cars, the gauge will get a little over normal because no water is flowing. Once water starts to flow, gauge comes down within seconds. I wouldn't expect the aux fan to kick on when the thermostat first opens since the car is really not hot yet. Admittedly, I have not noticed it in the Beast, but I have seen this on my other vehicles.
gsfent is online now
Old 6th July 2005, 22:49   #5
Ag Surfer
Ag Surfer's Avatar
Garage: 996 TT - Black
On a somewhat related note, I dont have problems with my temp spiking, but my aux fan turns on as soon as I start the car (even in the morning). Anyone else have an overeager fan?
Sean
02 996TT
Cargraphic Exhaust (Loud)
02 M5 - Titanium Silver (Sold to Brother)
UUC V12 Clutch Conversion
Bilstein PSS9 Coilovers
Eibach Sway Bars (front and rear)
Tranny Mounts
Pinnacle Ceramic Tint
Britalman Exhaust
Icelink iPod
BSW Stage 1 (Rainbow)
BSW Rear-deck Sub
Powerchip Gold 91
Ground Control Adjustable Camber Plates
Strong Strut Front Brace (Silver with holes)
04 Ducati Monster S4R
Too many mods to list...
Ag Surfer is offline
Old 7th July 2005, 00:12   #6
gsfent
gsfent's Avatar
I'll have to check mine in the morning, but I think it runs if the AC is on.
Old 7th July 2005, 02:23   #7
mottati
mottati's Avatar
they aux fan should run at varying speeds. It goes on with the ac, but kicks into high speed when the temp gets above a certain level. There have been issues and possibly a recall for 01 model years fans.(not sure, might want to search)
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 7th July 2005, 13:28   #8
Larry's M5
Larry's M5's Avatar
Hmm... I talk to my local dealer and they said the fan recall does not apply to my car according to the VIN number. So I'm guessing thermostat then
08 328i Black/Black
Old 7th July 2005, 13:42   #9
M5_SMG
M5_SMG's Avatar
Garage: E39 Silver
If its during warmup I would think its the thermostat just opening a bit on the late side, so water is not circulating to the radiator. The aux fan could already be running (depending on where the temp. sensor is), but no coolant to cool. Once the thermostat cracks open, all systems go. Slight mechanical delay from the thermostat.
M5_SMG is offline
Removed my Fan! mottati E39 M5 and E52 Z8 Discussion 32 8th January 2005 00:13
Lose the mechanical fan mr_bock E39 M5 and E52 Z8 Discussion 10 4th January 2005 14:37
Part number for engine fan & Fan shroud B3ND3R E34 M5 Discussion 9 28th November 2004 02:26
Heating/Cooling fan acting nuts............... FAST 5 E39 M5 and E52 Z8 Discussion 4 25th August 2004 04:03
Heater A/C - Fan Blower - Fuse???? sctazmon E39 M5 and E52 Z8 Discussion 1 27th June 2004 22:19
Page generated in 0.13211 seconds with 11 queries
