Charlotte, Raleigh, Durham in NC, anyone here can shed light on humidity and rust? - BMW M5 Forum and M6 Forums
post #1 of 10 Old 17th May 2017, 06:59 AM Thread Starter
gixxer
Hi,
(sorry for posting this in the non-regional discussion)
Relocating to the Research Triangle Park (RTP) NC region, coming from Boise, Idaho (dryer climate), been researching on the affect of the RTP area's relative humidity and cars rusting.
And whether folks in this area go out of their way to apply say some sort of undercoating to their rides.
I intend to wash (and wax) regularly.
And this part of NC doesn't seem to have much of any salty road conditions. And i believe it's well into inland to have salty air. Nor is this region deep into the mountains.
But it's the moisture's in the air (i've heard the relative humidity can get "brutal" say in August, near ~100% ???) and effects on rust (eg. car just sitting in the garage overnight), that i have little experiences in.
Some folks seem to suggest this region in NC has fairly clean cars (whatever that means), but just thought i would be better prepared with better knowledge.
Anyone living in this region of NC care to share some of their experiences, etc. along this line of concerns?
Incidentally i've seen some cars sold from Florida and they were some of the clean, rust free cars i've seen (exterior wise). Go figure...
Thanks much,
gixxer is offline
post #2 of 10 Old 17th May 2017, 05:22 PM
jojo
jojo's Avatar
Hey there,
I've only lived in Raleigh for the past 6mo so I can't give you a whole lot of history. But I'm from NYC and I can tell you that I RARELY see rust around here. The biggest indicator for me are the license plate bracket bolts. All northeast cars' plate bracket bolts are rusted. Not here in NC.
Hope that helps.
jojo is offline
post #3 of 10 Old 17th May 2017, 07:10 PM
CSBM5
CSBM5's Avatar
If you don't drive on the 1-3 days/year when roads are salted due to ice/snow, you'll never see any corrosion even on the aluminum under the car much less "rust" of any sort. No worries here about humidity during the summer causing any issues that I've ever seen other than heat stroke when you want to do something outside in the middle of August. My M5 is pristine underneath and in all the "problem" areas some have with the E39, and it's been here for 14 years in this climate.
Current stable:
Dinan: springs, Konis, rear sway bar;
Ground Control camber plates, Brake ducts opened, Evolve tune
2011.5 M3 sedan 6MT Silverstone, slicktop
Dinan front swaybar, Eibach rear swaybar, pins-out-max-camber-up-front, Michelin PSS street/Nitto NT-01 time trials
2007 328i wagon Silver/gray
2006 330i E90 ZSP 6MT Electric Red/Black
1975 CanAm 125MX2
CSBM5 is offline
post #4 of 10 Old 18th May 2017, 12:06 AM
auaq
auaq is offline
post #5 of 10 Old 18th May 2017, 02:15 AM
Redshift
Redshift's Avatar
Welcome to the area. We'll have to meet up when you arrive!
No rust issues here. I've seen cars from mid VA and northward with rusty undersides but not from here southward. I've driven most of my cars even on the snowy days and then later rinsed the bottom off and I have no issues at all with rust on any of my cars.
2003 M5 Touring Mods // Videos // Pics
2001 M5 Sedan Mods
2003 M3 Touring
2002 330Cic (soon M3Cic)
Redshift is offline
post #6 of 10 Old 18th May 2017, 05:51 AM
jalop38
jalop38's Avatar
Welcome to North Carolina!
No rust issues for you to worry about here. Just make sure to rinse off the underside of the car after each of the 1-3 snow/ice storms we get a year and you'll be fine. I've been DD'ing an E46 in NC for over 10 years and have no rust to report.
jalop38 is offline
post #7 of 10 Old 19th May 2017, 10:50 AM
Sales Geek
Sales Geek's Avatar
I've lived in NC since 1993, been driving to RTP/CLT ever since and used my 2000 M5 since I got it in 2011. Pretty much what everyone else has said here but one addition: sometime around April the Pine pollen in the RTP gets truly dreadful. It's a green powder just a shade thicker than talc that will get into every nook and cranny of your car and will take a long, detailed cleaning to remove. If you don't then it builds up and moisture makes it it dry into an ever more difficult goo to remove.
The RTP area has something that's unique compared to either Charlotte or the Greensboro/Winston Salem areas: really heavy duty pine pollen. When it's pine pollen season in RTP you should A) Not park your car under any trees and B) garage park as much as possible. You can park your car out on a clear April morning and return to a vehicle that looks green and fuzzy at the end of the day. This also comes with a much higher chance of getting pine tar on your horizontal surfaces (hood, roof and trunk lid) that you need to remove ASAP since it hardens into something resembling super glue. Either way, it's a good excuse to spend some time detailing in early May.
When I was covering RTP I'd at least just hose my M5 down when I got home and get the shop vac out on the weekends to get the pine pollen out of the rain gutters and from around any of the rubber seals on the doors, hood and trunk.
My M5 came down from a life in the Northeastern US (last owner in Boston) where salt took its toll but since it's been in NC I haven't seen any significant changes. I'm under the car twice or so a year to check. They do brine the roads here when it looks like ice or snow is going to happen but it's nothing compared to the heavy salting in states like PA, NY, NJ etc. The only rust I've had to deal with is around the gas cap which is arguably a design flaw rather than something attributable to use of salt.
I'll disagree mildly on the comments about humidity. It's all relative and places like Charleston South Carolina, Savannah Georgia or the Orlando Florida area in mid-summer make North Carolina look like Arizona when it comes to humidity.
Sales Geek
2000 Titanium Silver on Black Leather
Sales Geek is offline
post #8 of 10 Old 19th May 2017, 02:14 PM
caspian65
caspian65's Avatar
Same here, lived in Raleigh since '88. Daily drove the M5 for about 8 years, no rust issues. Earlier this year I cleaned the undercarriage and all was good, no corrosion at all.
caspian65 is offline
post #9 of 10 Old 19th May 2017, 03:28 PM
Rontgen
Rontgen's Avatar
In my limited experience in RTP during "winter", it's usually best not to drive at all - if for no other reason than to avoid the natives, most of whom have zero winter driving abilities.
- Darrell
2001 M5 - Jet Black / Black Nappa
Dynavin N6, Dinan Exhaust, AutoSolutions SSK
Rontgen is online now
post #10 of 10 Old 19th May 2017, 06:28 PM
ECB
ECB's Avatar
I responded to your same thread on m3f. Do you have an m5 in addition to the m3? Welcome to NC. As others have said, no major issues with rust.
03 M5 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C 92mm pulley, Supersprint headers and Race cats, Eisenmann Sport Exhaust, RK Autowerks/Evolve tune,
Aquamist HFS-3 water methanol injection, Rogue SSK w/ RP Synchromax fluid, fog light delete,
H&R Springs, Dinan 17mm rear sway bar, TCD sway bar brackets, Ultimate Pedals, Euro Armrest,
Hardwired V1, Angel iBrights v.2, 6000K Low beams, 70W High beams,BSW Speaker Upgrade & 10" Sub
04 M3 Jet Black/Black Nappa/6 spd
Max PSI Turbo, Aquamist HFS-3 water methanol injection
Rogue Exhaust dump valve, Eisenmann Race Muffler
Rogue SSK, H&R springs, Koni Yellows, Squared 18's
ECB is offline
Raleigh or Charlotte M5 owners: Parts run to Clemster (Adam) this Sunday Redshift E39 M5 and E52 Z8 Discussion 6 3rd May 2017 03:56 PM
DIY: '03 540iTSC auto -> manual swap weekend: Apr 18-19 (Raleigh/Durham peeps, come hang! Redshift E39 M5 and E52 Z8 Discussion 4 6th April 2015 09:19 PM
Shed some light for SA M5's Whacko E60 M5 and E61 M5 Touring Discussion 0 20th September 2012 11:06 AM
Shops in Raleigh Durham NC area? JayC E39 M5 and E52 Z8 Discussion 2 4th June 2006 01:51 AM
Shed some light please! Where do these brackets go? vespam5 E34 M5 Discussion 2 20th March 2006 07:10 PM
