Re: Saftey Warning! Do you use Metal Air Caps?
This is only using the heavy caps with the logos on them. The weight repeatedly bends the longer rubber stems and eventually causes them to crack. This could lead to catastrophic failure.
The lightweight stock metal caps are better than plastic ones because they serve as a backstop to the valve to keep it from leaking. They are light enough that they don't have the same tendency to bend the stems. When you get new tires and stems, get the short ones. The long ones really aren't necessary on the stock M5 wheels. (And go for rubber stems not the metal stems. I'm told by my tire guy that the metal ones tend to leak over time because they depend on a small O ring to seal the valve to the wheel. The O ring tends to shrivel over time and leak. The rubber ones should last at least as long as the tires. Always get new valves when getting new tires.)
Need4Spd
