Old 6th July 2005, 05:00   #1
ALEV8
ALEV8's Avatar
Garage: 2003 S500 AMG
Send a message via AIM to ALEV8
My NAV has freakin' LOST IT!!!!
Hey Guys,
Suddenly my Mk4 NAV system is way off calibration. It won't follow the streetmap while I drive, instead it just cuts across it, not following it at all some times, other times following but like a quarter mile east of my actual location!
Has anyone experienced this?
Never happened until the Icelink+ went in.....
ALEV8 is offline
Old 6th July 2005, 05:18   #2
03E39M5
03E39M5's Avatar
Garage: 03 Titanium M5
Re: My NAV has freakin' LOST IT!!!!
Im going to take a wild stab at this knowing that I may very well be wrong, but the symptoms you mention sounds just like what happens when a GPS unit has a faulty or intermittent antenna connection.
03E39M5 is offline
Old 6th July 2005, 05:26   #3
ard
ard's Avatar
ditto. My thought as well. Bad antenna signal.
ard is offline
Old 6th July 2005, 07:20   #4
ALEV8
ALEV8's Avatar
I'll double check the trunk connections in the AM..............
ALEV8 is offline
Old 6th July 2005, 07:56   #5
CB2002
CB2002's Avatar
Garage: CB 2002 M5
Also, check how many satellites are showing up in the little GPS window at the top right on the nav screen. It's hard to describe the icon, but each satellite that the GPS system reads a signal from shows up as a white "star" around the planet. If your antenna is not working correctly, or the GPS receiver is out, then you may not see the proper images on the icon.
This happens whenever I drive in my parking structure at work. With no signal, the system estimates your location by steering and speed, and your problems sound very similar.
2002 CB Sport, PDC, Sunshades, M-Audio, Ski bag
CB2002 is offline
Old 6th July 2005, 10:27   #6
kwalls
kwalls's Avatar
Garage: Silver 03 M5 (sold)
Originally Posted by CB2002
Also, check how many satellites are showing up in the little GPS window at the top right on the nav screen..... This happens whenever I drive in my parking structure at work. With no signal, the system estimates your location by steering and speed, and your problems sound very similar.
Yes but there are other problems that can produce similar symptoms.
First slow processor speed resulting from a conflict of data being analyzed and lack of GPS satellite reception is one source, but having a conflict with map movement and vehicle location as verified from ABS input would be another, would look the same inside the car. The second example can best be observed if you traverse a section of road that has been ‘relocated’ by construction since being digitized into the nav CD. These normally don’t last long as the system normally ‘finds’ itself again but can result in voice prompts that seem in conflict with your perceived position. While most OEM systems have dedicated power sources to reduce the possibility of slow processor speeds, you might have a problem induced by a momentary short. Since this all started after your Icelink+ install it probably is associated with wires that were either directly or indirectly affected by your install. The most likely would be the GPS antenna but there are other possibilities beyond the obvious.
Ken
03 BMW M5 ein gut fahrt
02 Volvo V70 XC der Frauto
Life may not be always be the party
I thought it would be, but while I am
here I'm going to DANCE
kwalls is offline
Old 7th July 2005, 05:27   #7
ALEV8
ALEV8's Avatar
..........and what did I do? hard reset by removing fuse 56 & 58, and it is FIXED. Hmmmm.
ALEV8 is offline
Old 7th July 2005, 07:10   #8
ard
ard's Avatar
So you didn't touch any connectors?
Interesting... the bmwnav group has a few posts about bad antennas/connectors creating the 'fixed offset' issue...
ard is offline
Old 7th July 2005, 07:27   #9
ALEV8
ALEV8's Avatar
I doubled checked all visible connections. I think my antenna became unplugged at some point and I was distracted lately while driving. Bad I know, but I plugged the antenna back in, and then the reset made everything right again, as the satellites are back and the GPS logo are in the corner again. Whew!
ALEV8 is offline
Old 8th July 2005, 00:07   #10
bluemax
bluemax's Avatar
Garage: 2002 m5 lemans blue
Alex, I pm you about the wheel you wanted to buy for over a month. Whats the deal do you want it or not. I am going to put it back up for sale if i don't here from you!! Mr Flake.
Robert
2002 Lemans Blue/Silverstone( SOLD )
B&B Tri-flows with SS X Pipe
Rogue Octane SSK & WSR
Royal Purple & Rogue Trans Mounts
Dinan Stage 2 Software
Dinan Stage 3 suspension
Dinan Front & Rear Strut Braces
Active Autowerke CAI
Mintex Dustless Pad's
UFMotorsport IATS Relocation Kit
2004 SRT-10 Silver (R.I.P. 12/18/04)
96 Dodge Viper GTS
07 Mercedes E63 (R.I.P. 12/28/07)
bluemax is offline
SPLIT SCREEN WITH V23 NAV SOFTWARE ON MK4 PAN5R E39 M5 and E52 Z8 Discussion 6 2nd August 2004 17:32
Is it possible to switch from Nav w/cassette over to Nav w/CD player ? FAST 5 E39 M5 and E52 Z8 Discussion 6 6th April 2004 05:20
Comment & Question about our NAV software for the beast............ FAST 5 E39 M5 and E52 Z8 Discussion 21 24th May 2003 17:58
NAV - unable to enter street numbers in address book w/ v 3-1/40 ? Jacob Lee E39 M5 and E52 Z8 Discussion 2 24th February 2002 01:00
updating NAV software...very simple, quick, and painless. 6 minutes. Jacob Lee E39 M5 and E52 Z8 Discussion 7 2nd February 2002 16:27
Page generated in 0.15177 seconds with 11 queries
