Vanos board maintenance needed? - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By michaeldch
post #1 of 4 Old 15th May 2017, 01:52 AM Thread Starter
michaeldch
michaeldch's Avatar
While waiting for my new water pump parts to arrive, I thought I'd check some maintenance items off my list & the vanos was readily accessible. I don't have any errors related to vanos and I found (to my great surprise) there are no leaks ... as the pics show. So my question is on whether I should proceed to do board maintenance? Opinions appreciated.
Cheers,
Michael
2001 BMW M5
2004 911 C4S
michaeldch is offline
post #2 of 4 Old 19th May 2017, 03:47 PM
Cohny
Cohny's Avatar
I would go ahead and do it. It's not that hard. Just make sure you really, really clean out the solenoids with brake fluid or something similar. You really want them to make a loud clicking sound, but you also really need to make sure they're dry to make an accurate assessment. Sometimes when the brake fluid is still inside they will click nicely, only to gum up again when dry. It takes a lot of fluid. I really thought I did a great job but I still failed the vanos test in DIS by about 5%. Don't worry about damaging the brown rings with the screens. You'll be throwing them out anyways.
Also make sure you get the soldering right. Vanos is a critical piece of the S62 puzzle and if you're ever trying to diagnose another issue down the road it's a good to know 100% that the vanos is in working order. I really didn't know how to tell if my soldering was any good so I made this thread. I hope this helps and good luck.
Cohny is online now
post #3 of 4 Old 20th May 2017, 05:58 AM Thread Starter
michaeldch
michaeldch's Avatar
Thanks for the encouragement - I have mostly done the board maintenance and am really glad I did.
Removing the solenoids was not too bad as I followed the advice on levering with a screwdriver on a neighboring solenoid and the lower slot on the solenoid being loosened.
Removed the filters - almost nothing left of them. I cleaned the solenoids using QD Electronic cleaner and compressed air and am getting good strong clicks now. I re-flowed the solder joints and spotted what I think might have been a dry joint (?). I added a bit of copper wire between the two terminals I was joining. Anyway, they are almost ready to reinstall! In case someone wants to do this too, I measured the resistance across each solenoid and found between 3.6 and 3.8 ohms. I was really double checking that I had not bridged any of the gaps between terminal pairs.
I guess that the bottom line is that despite looking pretty minty (with just the covers removed) and no vanos errors, its still advisable to do this maintenance. And not too difficult :-)
Cheers,
Michael
2001 BMW M5
2004 911 C4S
post #4 of 4 Old 20th May 2017, 04:56 PM
Sailor24
Sailor24's Avatar
The bottom photo, you are correct that is a bad joint. If you grabbed that wire with pliers and worked at it you would have it moving in no time.
It is the inside of the noid that will be less than pristine where do you think the fibers from the screen/filters go. No matter how perfect the outside looks.
Nice job.
Sailor24 is online now
Going to do VANOS maintenance, piston seals necessary? Cohny E39 M5 and E52 Z8 Discussion 16 17th November 2016 04:46 AM
Noob tackles S38 maintenance, HELP NEEDED! E30isKing E34 M5 Discussion 57 11th August 2014 08:59 PM
Using DIS to set VANOS to maintenance position liquidsmoke E39 M5 and E52 Z8 Discussion 2 11th March 2013 10:34 PM
HELP! Vanos replacement advice needed, is my vanos capoot?! M5aud E60 M5 and E61 M5 Touring Discussion 100 13th July 2010 12:18 PM
Advise needed...my full maintenance is running out... Lange E39 M5 and E52 Z8 Discussion 3 8th May 2007 06:01 AM
