Car not starting P0335 after clutch install - BMW M5 Forum and M6 Forums
post #1 of 24 Old 13th May 2017, 05:51 AM Thread Starter
Slick_m5
Changed the clutch along with all seals, fuel filter and front crankshaft seal. Battery has been on a tender for 5 months and I tried starting it and it wouldn't. Battery is dead. I tried jumping and it just turns over. I checked the codes and P0335 popped up. I can hear the fuel pump turning on. Did the code pop on because of the dead battery from the first initial startup and should I just replace the battery? Or is the sensor really bad? Chime in if you had this issue. I don't think I messed with timing or anything in the front. Any advice is appreciated.
Slick_m5 is offline
post #2 of 24 Old 13th May 2017, 06:30 AM
Silent
Silent's Avatar
Check the rear Cps sensors make sure you didn't break any of them
Da Machine
02 Blue WM Sport, S/C'd mofo - 566rwhp/462trq on 91 octane
Da Rocket
08 M5 SMG Alpine White/Black & Titanium Trim w/all options <-- For Sale
Sold
11 Alpine White/Black F10 550i ///M Package M Sport
09 Alpine
White/Black E60 550i ///M Package M Sport
08 Alpine White/Black E60 550i ///M Package M Sport
06 LMB/Black 4.8is
03 Imola Red/Black 4.8is
Silent is offline
post #3 of 24 Old 13th May 2017, 06:40 AM
Sailor24
Sailor24's Avatar
Until you get a battery it is moot likely. That code does not mean it is the sensor you might have pinched a wire. You will have to check everything including the distance off the flywheel. It might throw that code if it is not reading the sensor. If the sensor is too far away from your new flywheel it may send no signal rather than a weak one.
Sailor24 is online now
post #4 of 24 Old 13th May 2017, 06:56 AM Thread Starter
Slick_m5
I was messing around with the pulse sensor and even replaced it with one from another transmission and still no luck. Both had no washer or shims so it's kinda hard to check the clearance between the sensor and flywheel.
Slick_m5 is offline
post #5 of 24 Old 13th May 2017, 06:59 AM Thread Starter
Slick_m5
Is it possible the bellhousing could even reach those sensors? Transmission went in pretty smooth. I'll have to check in the morning when daylight approaches.
Slick_m5 is offline
post #6 of 24 Old 13th May 2017, 09:28 AM
Sailor24
Sailor24's Avatar
How is it hard? You remove the sensor measure the distance from where the sensor bares to the flywheel. You measure the sensor from where it bares to the tip and subtract that number from the first. It is hard if you don't have tools but even monkeys use sticks. Stick a stick in the hole until it touches the flywheel scribe a mark where the sensor bares, hold that next to the sensor measure the difference.
The Following User Says Thank You to Sailor24 For This Useful Post:
Slick_m5 (14th May 2017)
post #7 of 24 Old 13th May 2017, 10:18 PM Thread Starter
Slick_m5
You guys really give that constructive criticism on this forum. I guess I'll have to dish it out since this is the only place to get my questions answered. What I was referring to was that both sensors sat the same distance from the flywheel. A few thousands of an inch away. I brought up the sensor dilemma meaning if it sat too close I would shim it to pull it back some. Can you tell me if one sensor looks bad from the pics or what readings should it draw on a multimeter.
Slick_m5 is offline
post #8 of 24 Old 14th May 2017, 03:24 AM
Sailor24
Sailor24's Avatar
I forget what the distance is but it is small and needs to be in the range or no go. In the second pic it looks like that one has been touching the flywheel but hard to tell from a pic.
This is not magic it is only your input that will resolve the issue. You have the car in front of you. On that point do you remember the dowel that lines up the flywheel correctly? Do you specifically remember doing that in the install, that is the most common error.
Just since, it is also common to post the definition for the code so someone trying to help does not have to go to the extra effort to look it up. You have to give to receive. Now that we have that out of the way lets get on with trying to figure what might be wrong. Do you have a volt meter? Do you know how to get to the pins on the DME? You need to check the wires first, find the pin on the DME that relates to the Crank sensor and check it on OHMS. I can look up the pin outs for you.
post #9 of 24 Old 14th May 2017, 03:50 AM
mgdmb
mgdmb's Avatar
mgdmb is offline
post #10 of 24 Old 14th May 2017, 03:53 AM
mgdmb
mgdmb's Avatar
The one on the bottom looks like it might have made contact with the flywheel, but is that the new one or old one? Been a few years since I've pulled mine out...
mgdmb is offline
Clutch Change... Now not starting. Please help. XtahoeX E39 M5 and E52 Z8 Discussion 14 3rd March 2016 01:26 AM
How NOT to install a flywheel. Tim's failed clutch/flywheel/RMS install. timmay77 E39 M5 and E52 Z8 Discussion 83 12th February 2012 06:02 PM
The (SMG) Clutch is starting to feel very rough! M5 Authority E60 M5 and E61 M5 Touring Discussion 29 31st January 2012 10:21 PM
Intermittent clutch roughness when starting out on 1st gear jlee E60 M5 and E61 M5 Touring Discussion 15 21st April 2009 01:56 AM
Clutch Starting to Slip, best way to get a warrented replacement? Yupkwondo E39 M5 and E52 Z8 Discussion 2 15th January 2002 04:09 AM
