Old 5th July 2005, 08:13   #1
clean540i
Garage: 99 BMW 540i/6 Biarritz Blue
Slight Problem
So i got an SES light today and the car started running very bad (misfiring). I get it home to find the spark plug cover all busted up on the left side. I pull it and see that a spark plug had been shot out of the cylinder and the coil is shot. I'm going to replace the coil hopefully tomorrow. Will there be more to it than that? Do i need a rebuild? Car is a 99 540i, intake, exh, stage 2 soft. Thanks in advance
clean540i is offline
Old 5th July 2005, 08:45   #2
shadowman
shadowman's Avatar
Garage: Z8
Re: Slight Problem
This one sounds a bit extreme...... I have seen spark plugs take flight...however only after they were improperly installed. You gave no short term service history so I have to speculate.
As for other concerns, huuummmm.... if you were fortunate to have the plug leave and not take the threads within the head with it during the process you should be fine...... look closely at the threads....... awkward...... and if all looks good...... properly install the spark plug, torque it to spec......and consider yourself "Lucky"
Take care
Shadowman
shadowman is offline
Old 5th July 2005, 09:02   #3
TCM
TCM's Avatar
Re: Slight Problem
I have seen this happen on a couple 540s. All needed to have the heads be rethreaded. If this is the case, you can buy a new head ($$$$) or try to have a machinist rethread the spark plug hole for you. Also, be sure to inspect the piston head for any scaring from shards of the coil plastic and or spark plug pieces. Please let us know how you make you.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Old 6th July 2005, 04:33   #4
clean540i
Re: Slight Problem
well i bought a new boot, coil, and plug today and will put them in shortly. I appreciate the help and i'll be sure to let you guys know what happens.
Old 6th July 2005, 05:51   #5
clean540i
Re: Slight Problem
well it turns out that the threads are shot and i suppose i will need to pull the head off and take it to a machine shop. Would it be easier to have the car towed or take the head off myself? Is there a price range for this job? Thanks again.
Old 6th July 2005, 06:13   #6
TCM
TCM's Avatar
Re: Slight Problem
The head needs to come off either way. So probably best to try and remove it yourself and save the hassle of the towing. Not sure about the pricing of the machinist but as long as it is under the cost of a new head, you should be ok. Please keep us updated with how you make out.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Old 6th July 2005, 12:04   #7
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
Re: Slight Problem
Maybe you should talk sweetly with BMW NA? Threads failing like that on a not-very-old car is indeed extreme. Good thing the injector was shut down so you didnt get petrol sprayed all over and had a fire.
I would definitely think of getting a new head. The other threads could be weakened too.
David
DavidS is offline
Old 6th July 2005, 18:01   #8
ray540inyc
ray540inyc's Avatar
Garage: 1997 540i sport , jet black
Re: Slight Problem
there has been a set of 540i heads on ebay off and on for the last 3 months or so , try to search past auctions if it isnt listed.
i think they wanted 300 for the set.
good luck
ray540inyc is offline
Old 6th July 2005, 18:04   #9
DavidS
DavidS's Avatar
Sales Feedback: (4)
Re: Slight Problem
good luck
If it look like it would seal well, I would definitely go with that rather than renovating the damaged head.
David
http://www.m5board.com/vbulletin/showthread.php?t=54788
http://www.m5board.com/vbulletin/showthread.php?t=88323
DavidS is offline
Old 9th July 2005, 20:40   #10
clean540i
Re: Slight Problem
I got the car towed on a flatbed down to the local Bmw shop (not dealer). He said he'd be there at ten and wasn't so i guess i'll find out what the damage is once he gives me a call.
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 61 7th January 2009 11:06
Vanos problem ilundber E39 M5 and E52 Z8 Discussion 15 3rd November 2005 01:30
"AUX" mode (lack-of) volume problem for I-PODs & DVD movies........ FAST 5 E39 M5 and E52 Z8 Discussion 8 16th September 2004 09:06
Gas problem Ruffinit E39 M5 and E52 Z8 Discussion 10 25th August 2004 15:47
Radio Problem Solved? paulbondy E39 M5 and E52 Z8 Discussion 9 7th August 2004 20:27
Page generated in 0.16638 seconds with 11 queries
