Guibo torque - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 15 Old 6th May 2017, 06:16 PM Thread Starter
booster_
Guibo torque
The instructions state to tighten by nuts only. I don't think I can get the socket in with the torque wrench from the transmission side. Are there alternatives?
booster_ is offline
post #2 of 15 Old 6th May 2017, 07:40 PM
Sailor24
Sailor24's Avatar
There is a spot but you need a wobble extension. I don't know how experienced or strong you are but just use a wrench, box end. You are going to go tight, likely as hard as you can without adding extra leverage. They are locking nuts so check them again after diving some time. When your arm is sore you will likely be done.
Sailor24 is online now
post #3 of 15 Old 9th May 2017, 03:49 AM
peteyypab
Having done this a few weeks ago, I just removed the Transmission cross-member and supported the Trans with a jack. Not fun but do-able.
Current Fleet:
02 M5 Carbon Black
11 335d M-Sport Alpine White
69 F-100 Ranger Peacock Blue
The ones that got away:
02 M3 Vert Jet Black
04 A4 3.0 Quattro Brilliant Black
02 Range Rover Java Black
84 Mazda 626 Diesel
peteyypab is offline
post #4 of 15 Old 18th May 2017, 07:00 PM
Tremelune
Tremelune's Avatar
How can you get an accurate torque with a wobble extension?
This is disappointing. I'm just about to do mine.
Tremelune is offline
post #5 of 15 Old 18th May 2017, 07:07 PM Thread Starter
booster_
You can't, there isn't enough space.
I used the wrench on the nut side and torque wrench on the bolt side. I tried to turn only the nut side, but ended up tightening from both ends. It's hard by yourself, on your back.
booster_ is offline
post #6 of 15 Old 18th May 2017, 08:52 PM
Sailor24
Sailor24's Avatar
Yes torque is torque, but you don't need to worry. Torque is important in engines and when installing TTY bolts but some bolts just need to be tight and not get loose, this means torque does not have to be absolutely followed.
post #7 of 15 Old 18th May 2017, 08:58 PM
Sailor24
Sailor24's Avatar
That is not good. You definitely don't want to turn the metal spacer in the rubber. If the spacer stayed put and only the bolt moved no worries but... It will kill the guibo early, maybe not tomorrow but... You would be better leaving it where it is than allowing the chance of torquing that part in the rubber. If there was absolutely no choice then I would grease the chite out of that end.
post #8 of 15 Old 19th May 2017, 02:43 AM
TheShafro
TheShafro's Avatar
You would need a torque adaptor or extension like this:
But I always torque them from the bolt; never a problem.
-Shady H.
@theshafro
'02 TiAg/Blk E39 lllM5 - Pending Build
'08 JZB/FR E92
lllM3 - Daily Driver
TheShafro is online now
post #9 of 15 Old 19th May 2017, 03:06 AM
Tremelune
Tremelune's Avatar
You know, that might actually work if your wrench can torque in both directions. Otherwise, the transmission mount would still be in the way of the handle.
post #10 of 15 Old 19th May 2017, 03:22 PM Thread Starter
booster_
Hey, as far as I remember, all nuts on the guibo bolts are on the same side.
I see you reversed the ones on the flange facing the back of the car.
booster_ is offline
deviation setpoint torque from actual torque nakmuay E39 M5 and E52 Z8 Discussion 20 13th November 2015 04:05 AM
Guibo bhemi E39 M5 and E52 Z8 Discussion 3 22nd June 2015 05:43 AM
Guibo mattmor E39 M5 and E52 Z8 Discussion 17 3rd November 2012 03:22 PM
Torque torque torque. Im loving it :) Black M5 E60 M5 and E61 M5 Touring Discussion 13 13th June 2010 03:54 AM
Tightening torque for Guibo??? Mfreakin5 E39 M5 and E52 Z8 Discussion 0 19th August 2009 09:48 AM
