Old 3rd July 2005, 09:34   #1
M5Pageco
M5Pageco's Avatar
Garage: 2000 M5 - LeMans Blue
Fuel Filter Replacement
Where on the E39 M5 (year 2000) is the fuel filter? Does it have one or two of them? Anyone change one before? How do you do it?
I tried searching for this and came up with nothing. Has anyone changed one before?
Thanks!
M5Pageco is offline
Old 3rd July 2005, 12:30   #2
Ocean's M5
Ocean's M5's Avatar
Garage: 2002 M5
Re: Fuel Filter Replacement
I just ordered a fuel filter from 800-909-PART, and installed it yesterday.
In the Future Get This Before You Start Any Projects...
Pretty simple. First:
Turn car off and let sit for at least 5 minutes before disconnecting battery cable.(thought is that the computer can be still shuting down.)
Disconnect Battery Cable, in trunk.
Under the Drivers door from Rear of Front tire about 3 feet back remove Plastic Panel.
Unscrew 2 8mm nuts holding Fuel Filter in place.
Using 2 Wrenches, Loosen front part of filter as the Rear is held on by a Plastic tension clip that allows the filter to spin.
Using fuel line clips to minimize spilage, place clip on both front and rear of fuel lines. Be Careful not to pinch, just squeeze.
Unscrew front part of Fuel Filter.
Push white plastic clip on rear of Fuel Filter to remove old Fuel Filter.
Replace new filter. DON'T FORGET TO PLACE WASHER ON FRONT PART OF FILTER. Tighten, install rear hose to fuel filter. replace parts.
Install Battery Cable... All Done
2002-05 Build Carbon Black ///M5
First Aid Kit ~ Warning Triangle ~ Full BMW Tool Kit
Rear Cupholders ~ Stubby Air Stems ~ Rear Shades ~ PDC
M Audio ~ Fold-Down Rears ~ Black Sport Int.~ Yokohama Advan Sport~
Beast Power Sway Brackets ~ Tinting-80% Strip Windshield
Center Armrest *Storage Bin ~ ///M Black Trunk Mat
Ocean's M5 is offline
Old 3rd July 2005, 18:23   #3
paule
paule's Avatar
Garage: 2002 Sterling S2 M5
Originally Posted by Ocean's M5
Is there an addendum or other manual for the M5/S62?
2002 Sterling Gray (Dinan S2) - SOLD!
2006 E60 M5 Saphire Black/Perforated Full Sepang Leather/Madeira (Week 40 Production)
paule is offline
How to avoid paying $118 for a Fuel Filter? 00m5 E39 M5 and E52 Z8 Discussion 11 29th November 2005 19:47
Has anyone ever experimented with additives....... FAST 5 Off Topic Forum 15 20th September 2005 03:48
Straight from BMW on recent delays Gustav E60 M5 and E61 M5 Touring Discussion 37 4th July 2005 19:52
Tech. theory: Engine Power vs. Fuel Consumption MT JTN E39 M5 and E52 Z8 Discussion 5 10th March 2004 08:09
Some air filter info from BMWE34.net BKH E39 M5 and E52 Z8 Discussion 1 30th October 2003 20:39
Page generated in 0.14131 seconds with 11 queries
