I just purchased the AA CAI and IATS Relocation kit, and now I think I want to pick up an exhaust, which should tide me over on modding for a little while, I also have some extra cash to spend.
I tried to do some searching, but wasn't getting very far, maybe I wasn't using the correct keywords. I know Kelleners + SS X-Pipe is real popular, but I'm afraid it might end up being too loud for me, so I'd like some input on the other options. Coming from E46 M3 land, SS and Eisenmann where always top choices, does the same hold through on the M5?
I'd like something that doesn't drone, and beefs up the sound, without being obnoxious. I ultimately plan to get headers (SS probably).
The Tubi exhaust seems to be a popular exhaust as well. I do not have an aftermarket exhaust installed, but I have been doing my homework as I am looking to get one.
Since The Tubi is a full cat back it would elimate the cost of getting the X pipe. The Tubi Rumore verson will be a louder more V8 sounding exhaust whereas the standard will be more Ferarri sounding.
Hope that halps.
__________________ BMW E46 M3 SMG Carbon Black/Cinnamon BMW E39 M5 Avus Blue - SOLD
You can check www.beastpower.com and they offer Tubi, Supersprint, and others, they also offer sound clips of each exhaust
Hope this helps
Marion
Marion
ACS Roof Spoiler
Tubi Style Cat Back Exhuast
Custom Painted HRE 549 19x9 front 19x10.5 Rear
UUC Evo III SSK & DSR
UUC Transmission Mounts
UUC Direct Fit Clutch
Supersprint Headers and Connecting pipes
Active Autoworks CAI
Discovery Automotive Powerchip 93 software
Lidetak LE-30
Valentine One
Dension Ice>Link:Plus
Beastpower Brackets
Evosport Power Pullies
Stealth-One
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
I'm in the same boat - I want a 'less understated' high RPM sound but I don't want the musclecar boominess at idle. At higher RPM I think I prefer the "Nascar" throaty growl of the Kelleners over the raspy Ferrari-sounding Tubis, so if there is a way to soften the Kelleners at idle but still have them sound serious when running through the gears, I'd love to hear how.
I've heard a lot of different M5's and I really do think that my exhaust is excellent... wish I had something to record it with. It sounds exactly like what you described.
I think the Dinan exhaust was engineered to have the least cabin throb, vibration transmission, and to be closer to stock at idle. Still screams above 4000 rpms at full throttle. Also nice that if SES problems occur the dealer can't tell you to go figure it out yourself.
Tubi. Sounds sweet w/o being too loud. No nasty resonances because it comes with its own matched resonators. If you do any long distance driving at all (which the M5 excels at), you will really appreciate the "right" sound of a Tubi. Others sound more impressive b/c they are louder, but you WILL get tired of that on long trips. Just my very biased opinion of course.
Need4Spd
