28th June 2005, 07:02
#3
M5
Re: Driver side angel eyes dimmer then passenger side
A couple things to try first; (1) switch the left bulb to the right and vice versa and (2) detach the plugs and reattach again to ensure a good connection. Doing (1) is probably good enough. Maybe you could switch the wires too. I've had this problem a couple times on two different 5 series and this trick worked both times. Finally, it's very possible that one bulb is not as good as the other. Just buy a new pair so that they match.
